fosterjd79's WJ Build Thread - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > fosterjd79's WJ Build Thread
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitTHE NEW! VANCO DUAL MODE 15/16″ Big Brake Kit w/BlaFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 04-04-2013, 06:59 PM   #16
fosterjd79
I will measure tomorrow. I forgot to mention that also have 3/4" spacers so we'll have to account for that.
[URL=http://www.jeepforum.com/forum/f197/fosterjd79s-wj-build-thread-1498923/][COLOR="white"]Fosterjd79 Build Thread[/COLOR][/url]
fosterjd79 is offline   Reply With Quote
Unread 04-05-2013, 12:24 PM   #17
jpat30
According to Kolak, the HD coils are good for 3 inches of lift. I just ordered a set from him this morning.
jpat30 is offline   Reply With Quote
Unread 04-05-2013, 03:07 PM   #18
fosterjd79
Updated measurements. This is with the OME HD coils and 3/4" spacers. Center hub to fender...
Front Driver Side - 21.75"
Front Passenger Side - 21.5"
Rear Driver Side - 21"
Rear Passenger Side - 21.25"
I mounted the front OME (A) on the front driver side and the rear OME (A) on the rear passenger side.
Unread 04-05-2013, 03:15 PM   #19
fosterjd79
Some pics...Sorry, they didn't come out the best and yes, there are old tires/rims in the back. Also, tires are 245/75/17 Duratracs.
Unread 04-05-2013, 03:20 PM   #20
fosterjd79
Also, there is trimming required with these tires and lift. I had already shaved the front bumper for the old tires but now with taller, more agressive tread, and not having adj front LCA's I need to remove some of the sheet metal from the rocker panel and rock rails. Not much though. I will be doing this over the weekend. I already removed the rails and I'm glad I did because I caught the rust as it was just starting. I am going to use a wire wheel to remove the rust, sand them down and give them a good coat of primer and then black paint. Anyway, here is a pic of the rubbing. It just barely misses when stationary but add some flex and they grab.
Unread 04-05-2013, 03:24 PM   #21
adavis39
Originally Posted by fosterjd79 View Post
Also, there is trimming required with these tires and lift. I had already shaved the front bumper for the old tires but now with taller, more agressive tread, and not having adj front LCA's I need to remove some of the sheet metal from rocker panel and rock rails. Not much though. I will be doing this over the weekend. I already removed the rails and I'm glad I did because I caught the rust as it was just starting. I am going to use a wire wheel to remove the rust, sand them down and give them a good coat of primer and then black paint. Anyway, here is a pic of the rubbing. It just barely misses when stationary but add some flex and they grab.
angle grinder + BFH = No more rubbing looking good
2002 WJ Limited [B]4.7[/B]: 6" Clayton REALLY long arms....yep, they are longer than yours [B]SOLD : ([/B]
1998 Platinum [B]5.9[/B] DD
2007 WK Overland [B]5.7[/B] wifes DD
TNJEEPS.COM
BUILD: [B][url]http://www.jeepforum.com/forum/f197/utwj-build-other-crap-1399123/[/url][/B]
[B]"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"[/B]
adavis39 is offline   Reply With Quote
Unread 04-05-2013, 03:27 PM   #22
fosterjd79
Oh, one more thing today, the alignment. I snapped a pic of the jeep on the alignment lift cause I just thought it looked cool (crappy pic though). Also, here is a pic of the results. Not too bad but it looks like I could use some adjustables all around. She definitely pulls to the right a little.
Unread 04-05-2013, 03:28 PM   #23
fosterjd79
Thanks and you read my mind.
Unread 04-05-2013, 03:31 PM   #24
adavis39
be sure to knock the pinch seam all the way down while your at it
TNJEEPS.COM
Unread 04-05-2013, 03:34 PM   #25
fosterjd79
Oh, another thing happened today and I just have to say, tire rack is f***ing awesome. So, one of the new tires just wouldn't balance. The balancer was asking for about 20oz of weight and that is just bad news. We spun the empty rim and it was only asking for 1.25oz of weights. So anyway, I called tire rack and let them know. They are overnighting me a replacement, scheduling a pick up for the bad tire, and reimbursing me for the mount and balance of the 5th wheel/tire all free of charge. I was impressed.
Unread 04-05-2013, 03:35 PM   #26
fosterjd79
Yeah, good call. What's the process with that? I was thinking that if I give it some relief cuts between the tack welds and smack it with a BFH I should be good to go. Sound about right?
Unread 04-05-2013, 03:37 PM   #27
adavis39
yeah, i just put cuts in it about 1/2'' apart all the way up......then beat the snot out of it with a mini sledge
TNJEEPS.COM
Unread 04-05-2013, 03:40 PM   #28
fosterjd79
What did you use to seal all that raw metal? Did you just bedline the whole wheel well?
Unread 04-05-2013, 03:43 PM   #29
adavis39
yeah, i did it when I cut my fenders. I used some cheap rattle can bed liner. Its lasted for about a year or so. Its just starting to come off in a few spots so i will re-do it with dupli-color bed armor (seems to be the best ive come across so far) I just sprayed the entire wheel well
TNJEEPS.COM
Unread 04-05-2013, 06:08 PM   #30
WJFrank88
Looks like it's going to be an awesome build! Silver and black WJ crew Here's mine
2006|4.7|QDII|OME HD|265/70/17Grabber AT2|D-ring receiver|Magnaflow|3' Firestik|Steel Armadillo
WJFrank88 is offline   Reply With Quote
