Eric's '96 Jeep Grand Cherokee - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Eric's '96 Jeep Grand Cherokee
Free shipping on Rugged Ridge XHD bumpersBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 10-26-2010, 08:41 PM   #91
Technohead
Old School
Technohead's Avatar
Originally Posted by biggoofy View Post
Hey Eric can you post up some pics from the bottom on the pinch seem as well as the back tie in i will be doing this soon and am a tad curious also can you take pics of the uniframe tie ins?
Will do ASAP. I'm travelling the next few days and then wheeling it as-is this weekend. I can tell you right now that the pinch seam itself is gone; one of the cuts to get the old rocker skins off was just above the pinch seam. All that is left is the metal just above the factory pinch seam.
Technohead is offline   Reply With Quote Quick reply to this message
Unread 10-27-2010, 09:13 AM   #92
biggoofy
Ok sounds good the more pics the better. Looks great though man.
biggoofy is offline   Reply With Quote Quick reply to this message
Unread 11-01-2010, 06:27 PM   #93
Technohead
Old School
Technohead's Avatar
Tested out the sliders last weekend:
The video got cut short. For the record all it took was a tap of the brake to lock up the front Tru-Trac and I drove right off.
Unread 11-01-2010, 06:48 PM   #94
biggoofy
hey man any chance of the pics and what was the total length you used on the 4x4?
[CENTER]Zack
96 ZJ HP44 / 9"
90 XJ on 33s
RIP Troy aka BigBlueZJ94
FroBot Fab FTW
[URL="http://www.mallcrawlin.com/forum/showthread.php?22776-Biggoofy-s-96-ZJ-build!-**Building-axles**"]My Build[/URL]
Need quality parts call Andy at Ironman4x4fab!!!!!
[url]http://ironman4x4fab.com/index.html[/url]
[/CENTER]
Unread 11-01-2010, 06:54 PM   #95
Technohead
Old School
Technohead's Avatar
Originally Posted by Technohead View Post
. . . I used 4"x4"x3/16" square section for the main structure and 1-1/2" x 0.120 wall tubing for the steps. The overall length is 72". . .
Will get the pictures ASAP. Its dark when I leave for work and dark when I get home.
Unread 11-01-2010, 07:08 PM   #96
biggoofy
lol yeah i know the feeling man thanks for the help
[CENTER]Zack
96 ZJ HP44 / 9"
90 XJ on 33s
FroBot Fab FTW
[/CENTER]
Unread 11-12-2010, 05:52 PM   #97
Technohead
Old School
Technohead's Avatar
Ok Goofy, are these the pictures you were looking for:
I still have not installed tubing from the sliders to the frame and at this point probably will not. The way they are tied into the body through the pillars is plenty strong enough. The remaining tasks are to stitch the rocker sheet metal to the sliders and then finish with seam sealer & Herculiner. The following picture shows the trimmed and cleaned sheet metal ready to fold onto the slider:
I also started building a belly skid plate. Here are the parts:
Fitting the parts together and tacking:
I welded a couple flanges to the Clayton frame stiffeners for mounting the skid plate. That cat sure will be happy to have some protection:
Now I just need to be patient and keep it from warping when completing the welds.
Unread 11-16-2010, 05:27 AM   #98
Technohead
Old School
Technohead's Avatar
Video footage from last Saturday's trail ride. A great time was had with minimal carnage.
Unread 11-16-2010, 08:50 AM   #99
biggoofy
looks fun man
[CENTER]Zack
96 ZJ HP44 / 9"
90 XJ on 33s
FroBot Fab FTW
[/CENTER]
Unread 11-16-2010, 02:00 PM   #100
Technohead
Old School
Technohead's Avatar
Here's some additional footage from last weekends trail ride. The group was small but we had a great time with minimal carnage: Blown brake line that was pinched off with vise-grips, bent Currie tie rod, tweaked driveshaft, smashed tail light, blown bead, a few small dents, and one slider ripped from the pinch seams.
Images (1-20):
If you are in the Southeastern New England area and want to do some wheeling then come check us out.
Unread 11-16-2010, 02:01 PM   #101
Technohead
Old School
Technohead's Avatar
Images (21-40):
Unread 11-16-2010, 02:02 PM   #102
Technohead
Old School
Technohead's Avatar
Images (41-58):
Unread 11-16-2010, 02:35 PM   #103
1993ZJ
looks like a blast!
1993 ZJ 4.0L AX-15 2" BB Rola Roof Rack, Warn 8274, 235/75/R15 BFG AT's, that's about all for now...
1993ZJ is offline   Reply With Quote Quick reply to this message
Unread 12-19-2010, 09:02 AM   #104
Technohead
Old School
Technohead's Avatar
Finally got around to fixing the brake line that blew out during Novembers trail ride. I've been putting it off because I knew it would be a nightmare accessing the fitting where the line enters the ABS pump. I had to remove the airbox and windshield washer reservoir in order to unbolt the ABS pump so that I could create enough clearance to get a wrench in there.
Here is what I found when I opened up the airbox:
This is on the BACK side of the air filter mind you. I have no idea how critters could have found their way in there.
Here is the brake line that blew out. The vice grips were the trail fix. Dead center in the second pic you can see the crack in the line. I used a piece of coat hanger as template to guide bending the new brake line:
Blue arrow points at the fitting I needed to access:
Everything ripped apart:
Done (for now):
This is actually a temporary fix. The plan is to rip out the ABS pump and plumb in an adjustable proportioning valve with all new brake lines.
Unread 12-19-2010, 09:23 AM   #105
Greengc4x4
Whats the story on that slider? how did it fall off?
Greengc4x4 is offline   Reply With Quote Quick reply to this message
