Eric's '96 Jeep Grand Cherokee - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Eric's '96 Jeep Grand Cherokee
Forever Wave Flags at JeepHutRubicon Express lift kits w/shocks are on sale!ORS4x4: New Product!
Unread 09-06-2010, 03:17 PM   #76
Technohead
Old School
Technohead's Avatar
Tires worked out great. Nice and sticky. I was running about 12 psi.
Technohead is offline   Reply With Quote Quick reply to this message
Unread 09-12-2010, 10:33 PM   #77
ZJPunk98
Eric,
let me know when you are cutting off the old rockers and installing the new. I'm slightly jealous of your step rail. I need to do that to mine.
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline   Reply With Quote Quick reply to this message
Unread 10-25-2010, 07:01 PM   #78
Technohead
Old School
Technohead's Avatar
I've been working on a rocker panel replacement for the last 6 weeks (I work slow) and finally made enough progress to show. Here's why I'm doing this project in the first place:
I used to have bolt-on sliders but did not like the loss of clearance so I got rid of them and rode this season without sliders knowing that I was eventually going to cut the rockers out.
First stage of the project was to build the new rails. I used 4"x4"x3/16" square section for the main structure and 1-1/2" x 0.120 wall tubing for the steps. The overall length is 72". These monsters weighed in at about 57 lbs each.
Fitting the end caps:
Fitting the steps:
Done:
The second stage of the project was cutting off the old rockers. The design calls for tieing directly into the pillars so I carefully cut out the old material which revealed solid structure for the a-b pillars but nothing much for the c-pillar.
Here's the b-pillar structure:
And here's the a-pillar structure. There was quite a bit of rust on the passengers side (shown). Not so bad on the drivers side. The sliders will also tie into that channel running under the floorboards to the frame:
The third stage of the project was making some mounting brackets. Here I used 4" wide by 1/8" thick sheet welded into an "angle iron". These brackets are welded to the pillars and the unibody structure as shown in the photos below. Lots of care was taken when fitting these brackets so that the sliders would line up perfectly. This was a real PITA but well worth the effort. The photos also show how I peeled back the remaining rocker panel metal for access. In the end I will fold this metal back into place and stitch-weld it directly to the slider rails.
Photo showing how the a-pillar bracket was attached. You can also see the other two brackets toward the rear:
Photo showing how the b-pillar bracket was attached. I used a similar bracket for the c-pillar area but since there was no pillar structure back there I could only weld onto what remained of the old rockers (i.e. similar to the vertical welds show here):
With the brackets fitted it was then a simple matter to hoist the rails into place and burn them on. The following photos show how the rails were attached to the top edge of the brackets. The same was done on the bottom edge of the brackets:
And this is where I stand today:
The remaining work includes folding the sheet metal down and stitch-welding it to the rails then some prep/seam sealer before coating the whole thing with Herculiner.
These things are incredibly strong. I can lift the whole side of the vehicle off the ground with a high-lift and there is zero deflection.
Unread 10-25-2010, 07:07 PM   #79
Mudzilla6661
2010 JK Wrangler
wow looks really good, I wish I knew how to weld so I could make myself some
check out my build of Mudzilla
2010 jk islander aka Mudzilla 2.5 AEV lift 35" kevlars, PSC front and rear bumpers Q10000 winch. More to come!
Mudzilla6661 is offline   Reply With Quote Quick reply to this message
Unread 10-25-2010, 07:17 PM   #80
biggoofy
looks great man thats the exact thing I want to do to mine. My passenger side got nice and beat during the last run.
[CENTER]Zack
96 ZJ HP44 / 9"
90 XJ on 33s
RIP Troy aka BigBlueZJ94
FroBot Fab FTW
[URL="http://www.mallcrawlin.com/forum/showthread.php?22776-Biggoofy-s-96-ZJ-build!-**Building-axles**"]My Build[/URL]
Need quality parts call Andy at Ironman4x4fab!!!!!
[url]http://ironman4x4fab.com/index.html[/url]
[/CENTER]
biggoofy is offline   Reply With Quote Quick reply to this message
Unread 10-25-2010, 09:17 PM   #81
ZJPunk98
Nice work Eric, i like how you used the pinch seam and a/b pillars to mount the tubing. I wish i used the a/b pillars with my design to prevent deflection, but oh well.
Erik
Unread 10-25-2010, 10:02 PM   #82
Spike300
hm, yup its decided, screw sliders im going with boat sides
[url]http://www.jeepforum.com/forum/f197/camo-beast-975063/[/url]
5.2-242 tcase-44a-30x9.50x15 MT/R-American Racing Burst Rims -[COLOR="Red"]Optima[/COLOR] -E3 plugs-[COLOR="DarkGreen"]Cu[/COLOR]st[COLOR="DarkGreen"]om[/COLOR] Pa[COLOR="DarkGreen"]in[/COLOR]t-Amsoil-Addco Front and Rear-polyurethane bushings
[B]To be installed[/B]: RE gen2 discos, military battery terminals
[B]To be rebuilt:[/B] HP30
[B]To be received:[/B]
[B]To be paid for:[/B]
[B]Next on the list:[/B] complete redo of brakes and
lines
[B]Needed:[/B] fittings, coil of brake tubing, Russel speed bleeders
Zombie Outbreak Response Unit #75
Spike300 is offline   Reply With Quote Quick reply to this message
Unread 10-26-2010, 06:06 AM   #83
squashman702
1994 ZJ
What are you using for a welder?
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote Quick reply to this message
Unread 10-26-2010, 07:06 AM   #84
Technohead
Old School
Technohead's Avatar
Hobart Handler 140 w/ 0.030" flux core wire.
Unread 10-26-2010, 07:49 AM   #85
squashman702
1994 ZJ
What do you think of it? My buddy has a Miller 140 that I've been using a lot, but I find that I think I might like the infinite voltage settings that the Miller offers over the Hobart.
Think Twice Garage
Unread 10-26-2010, 08:23 AM   #86
Technohead
Old School
Technohead's Avatar
The Hobart works fine for what I call "hobbyist" use. The contiuously variable voltage is nice but does cost a bit more. The main drawback to the Hobart (probably shared by the Miller) is small duty cycle. For more industrial strength use I think you really need something that runs on 220v with at least 180 amps. Again the contiuously variable voltage adjustment is nice but not critical.
Unread 10-26-2010, 09:54 AM   #87
squashman702
1994 ZJ
We've been using the 140 on everything up to 1/4" without an issue, although we normally have the voltage on 9 or 10 at this point. Either myself or my buddy will likely be purchasing a Miller 211 soon.
Think Twice Garage
Unread 10-26-2010, 05:01 PM   #88
CTeunuch
Looks nice, but do you have any plans to tie them back to the 'frame' rail? I would imagine they will start to push up into the doors after a few good hits if they're only supported by some 1/8" and the old rockers.
Think Twice Garage
"Yeah, that might work, pass me the grinder..."
94ZJ AX15/HP44/8.8/5.13's/35'' MTZ's SOLD
99XJ 4.0/AW4/HP30/8.25 build coming soon...
www.undergroundjeeps.net
CTeunuch is offline   Reply With Quote Quick reply to this message
Unread 10-26-2010, 05:27 PM   #89
Technohead
Old School
Technohead's Avatar
I already have tubes cut with flanges welded on for frame ties. But tieing into the frame will do almost nothing to stop them from pushing "up" into the doors. The a-b pillars loaded in compression are much stronger than frame ties loaded in bending. Tieing into the frame will help resist side loads from pushing them in but they are already tied into the two existing channels that run from the rockers to the frame. Since I have the frame ties ready I will probably use them.
Unread 10-26-2010, 05:55 PM   #90
biggoofy
Hey Eric can you post up some pics from the bottom on the pinch seem as well as the back tie in i will be doing this soon and am a tad curious also can you take pics of the uniframe tie ins?
[CENTER]Zack
96 ZJ HP44 / 9"
90 XJ on 33s
FroBot Fab FTW
[/CENTER]
