-   Grand Cherokee General Discussion (http://www.jeepforum.com/forum/f197/)
-   -   Eric's '96 Jeep Grand Cherokee (http://www.jeepforum.com/forum/f197/erics-96-jeep-grand-cherokee-917366/)
Technohead 12-04-2009 08:00 PM
This thread chronicles the transformation of my '96 Grand Cherokee from a daily driver into a (mostly) trail rig. I'm starting out with multiple posts because the content has been cobbled together from various sources dating back to 2004. I'm placing heavy emphasis on documenting actual trail use along with the resulting fixes & upgrades. This thread is getting lengthy and contains lots of pictures so for those of you who don't have the time to burn here's the current status in a nutshell:
Suspension: Clayton long-arm; 5.5" lift; Bilstein shocks; RE extreme-duty track bar; Currie steering, limit straps
Powertrain: 5.2 V8; NP231 w/ SYE; Iron D44 rear w/ Detroit locker & alloy shafts; HPD30 front w/ Tru-Trac & alloy shafts; 4.56 gears; Solid diff covers; custom driveshafts
Misc: 305-70R16 Maxxis Bighorns; Pro-Comp 7073 wheels; Magnaflow muffler/cat w/ custom tailpipe; Hanson bumpers; Superwinch; custom rocker & belly skid plates
In the works: Keeping it running.
And if you do have the time to burn then read on . . . I'm offering free beer if you make it through the whole thing.
On the trail:
http://i262.photobucket.com/albums/i...ug-2011-02.jpg
http://i262.photobucket.com/albums/i...e-2011-003.jpg
Technohead 12-06-2009 02:42 PM
First, the basics. It’s a 1996 Grand Cherokee Laredo that I took ownership of in ’98 with 33,000 miles. The vehicle was a lease that the original ‘owner’ turned in early. It came to me in virtually showroom condition for $22,000 with a 5.2L V8, Quadra-Trac (NP 249), Infinity sound system, and overhead console. For the first 5 years the vehicle was my daily driver and remained 100% stock. During this time I did a fair amount of off-roading but mostly fire roads and sand, very limited rock crawling and mud. Here’s a pic of the stock vehicle:
http://i262.photobucket.com/albums/i...east-beach.jpg
The following pic shows what can happen if you park too close to the train tracks. I was visiting some old college buddies up in northern Maine and arrived at their place late at night during a blizzard. I parked on the side of the road never realizing the tracks were there. In the morning I heard the train coming, blowing its whistle like crazy. I looked out the window just in time to see the railing on the locomotive scraping across the front end. This little mishap landed me on the evening news. The fix cost about $4,500 which thankfully was covered by insurance. If I had parked a few more inches closer to the tracks then I’m sure the vehicle would have been a total loss.
http://i262.photobucket.com/albums/i...j-vs-train.jpg
In 2004 I picked up a Mazda6 for my daily driver and kept the Jeep for camping, towing, and winter driving. At this time my Jeep had tallied just over 180,000 miles. The transmission and axles were showing their age so I installed a remanufactured transmission and rebuilt the axles to stock specifications (which, in retrospect, was a mistake). I wanted to get back into some more hard core wheeling after being out of the game for over 10 years so on went a RE Budget Boost with 31-10.50R15 BFG All-Terrains on the stock wheels. I liked the look and the Jeep could definitely go places that would be tough at the stock height but in my opinion the handling degraded much more than it should have given the relatively mild amount of lift. In an attempt to improve the handling, I widened the track with 1-1/4” Spidertrax wheel spacers. The spacers did help the handling a bit and also kept the tires from rubbing the suspension when the steering was fully locked. In fairly short order I decided that the BB was not cutting it and upgraded to the RE 3.5” Super-Flex suspension. At this time I also installed a RE adjustable front track bar, Rancho RS9000X shocks, and a Borla cat-back exhaust system. Here’s a pic with the RE 3.5” kit and BFG tires:
http://i262.photobucket.com/albums/i...gulf-hagas.jpg
Overall, I have been satisfied with the RE kit. The on-road ride is acceptable, noticeably more stable than the BB, and the off-road capabilities are greatly enhanced over stock. The bolt-on rear track bar relocation bracket that comes with the kit is definitely a weak link. Within months of installing the kit I noticed that the bracket was cracking. Fortunately, I noticed this before it broke completely off on the trail. I welded the bracket on and had no problems since. If I had to do it over again, I would scrap the bracket and go with an adjustable rear track bar. I’ve found the front sway bar disconnects to be the other weak link in the RE kit. The disconnects that came with the kit (Gen 1) were always sloppy and difficult to use. Eventually they corroded and became impossible to use so I upgraded to the RE Gen2 disconnects. The Gen2 disconnects look impressive but the design is weak; in less than a year they were trashed. Replaced them with Tereflex disconnects which look to be about as bulletproof as they come. Here’s a pic showing where the RE Gen2 disconnects failed:
http://i262.photobucket.com/albums/i...ct-failure.jpg
Several months ago the viscous coupling in my transfer case started going bad so I began researching the options. This is when I first stumbled across the NAGCA forum. Over the years I’ve grown attached to full-time 4WD. At the same time I was interested in having a 2WD option, primarily just for the fun factor. These requirements led me to go with the NP242 transfer case in place of the stock NP249. I scored a NP242 transfer case from a ’99 Grand Cherokee from a local parts yard for $200 and rebuilt it using new bearings, chain, and a Tom Wood’s slip yoke eliminator kit. I cannot speak highly enough about the quality of Tom Wood’s products. Here’s a couple pics of the transfer case in place:
http://i262.photobucket.com/albums/i...-242-sye-1.jpg
http://i262.photobucket.com/albums/i...-242-sye-2.jpg
The project was supposed to end with the transfer case but after seeing all the rigs on NAGCA I could not stop. Before I knew what had come over me new bumpers and tires were on the way. I went with Hanson bumpers front and rear. These bumpers are not cheap but in my opinion they are the best looking ZJ bumpers out there. Actually, I guess I should say they were the best looking bumpers out there because the line is apparently being discontinued! I was talking with a guy at the shop and he said they are too difficult to manufacture. Judging from the Hanson web site it looks like all they have left in stock is the rear bumper w/o tire carrier. For tires, I went with 265-75R16 BFG Mud-Terrains on 16x8 Pro-Comp 7023 cast-blast alloy wheels. The 265’s on wheels with 4” backspacing are a perfect fit for the 3.5” lift. With stock 3.73 gears the V8 has plenty of power to get this thing moving, there is no rubbing, and no trimming was required (although maybe the stock bumpers would have needed some trimming). Here’s a pic comparing the stock tires, 31’s, and 265’s:
http://i262.photobucket.com/albums/i...comparison.jpg
Here’s some poser pics with everything bolted on:
http://i262.photobucket.com/albums/i...erics-zj-1.jpg
http://i262.photobucket.com/albums/i...erics-zj-2.jpg
Here’s some pics of a few trail scars that have been picked up along the way:
http://i262.photobucket.com/albums/i...le-scars-1.jpg
http://i262.photobucket.com/albums/i...le-scars-2.jpg
http://i262.photobucket.com/albums/i...le-scars-3.jpg
Here’s some pics of the test drive with the NP242. Everything seemed to work fine in the driveway but when we got to the trail it would not shift into low range. I opted to go for it anyways:
http://i262.photobucket.com/albums/i...-29-2008-1.jpg
http://i262.photobucket.com/albums/i...-29-2008-2.jpg
http://i262.photobucket.com/albums/i...-29-2008-3.jpg
http://i262.photobucket.com/albums/i...-29-2008-4.jpg
And a couple videos. Low range and a locker definitely would have helped on the hill:
www.youtube.com/watch?v=ijI92ehiEeA
www.youtube.com/watch?v=MwUEv9Mg8Es
As for future mods, I have plenty of ideas. The most immediate (after fixing the transfer case shifter problem) are to paint the side cladding black and get some rock rails. I’m leaning towards JCR Offroad for the rails. I’ve decided to stick with the Dana 30 front axle but I'm thinking about upgrading the shafts to 30 spline with Spicer-style u-joints, add a limited slip (probably Detroit Tru-Trac), and beef the steering (bent the stock components twice already). I’ve got less than 40,000 miles on the rebuilt rear axle but I want to scrap the aluminum housing and go with a real Dana 44 and Detroit Locker. Lastly, the original engine now has over 220,000 miles on it. Even though it still runs like a champ and does not use any oil I figure it cannot last forever so will be looking for a remanufactured engine, probably from Jasper.
Stay tuned!
Technohead 12-06-2009 02:44 PM
April 2008:
The last wheelin' trip resulted in bent steering components . . . again. Thats three strikes on the stock V8 linkage so I finally decided an upgrade was required. I opted to go with the Currie HD tie rod system (CE9701) which uses the stock inverted Y configuration but is considerably stronger. I know that the inverted Y attracts some scorn in the wheelin' community but I think it has superior on-road characteristics compared to the alternatives and provides the best compromise for a dual-use vehicle. Initial impression on-road is that the Currie set-up is much more tight and responsive. Maybe thats not saying much given that the bent stock components reacted like a wet noodle. I need a new front driveshaft before giving it a test off-road. Hopefully this weekend. I should also note that the Currie system is listed for TJ, XJ, LJ, and MJ on the Currie website but it fits just fine on the ZJ. Here's some pics:
http://i262.photobucket.com/albums/i...s/Currie-1.jpg
http://i262.photobucket.com/albums/i...s/Currie-2.jpg
http://i262.photobucket.com/albums/i...s/Currie-7.jpg
http://i262.photobucket.com/albums/i...s/Currie-4.jpg
http://i262.photobucket.com/albums/i...s/Currie-5.jpg
http://i262.photobucket.com/albums/i...s/Currie-6.jpg
Technohead 12-06-2009 02:46 PM
May 2008:
Finally got around to installing my new front driveshaft. I've had the shaft for a few weeks now but have been putting the job off because I figured dealing with the pinion yoke would be a b*tch. I'm attending a trailride and campout hosted by the Rhode Island Off Highway Vehicle Association (RIOHVA) this weekend which forced the issue. Turned out the job went smoothly. Here's a pic of the new shaft next to the old CV shaft that blew its cookies:
http://i262.photobucket.com/albums/i...iveshaft-1.jpg
Pics of the installed shaft:
http://i262.photobucket.com/albums/i...iveshaft-2.jpg
http://i262.photobucket.com/albums/i...iveshaft-3.jpg
Also installed some new shocks. I went with the new Rancho RSX to replace the Rancho 9000XL's that have been on there for four years now. I ordered the shocks from 4 Wheel Parts. Unfortunately, when I went to bolt on the rears they were about 3" too short. Upon closer inspection it turns out they shipped the wrong part number. Kinda obvious from the pictures ain't it? Arrrrgh!
http://i262.photobucket.com/albums/i...s/shocks-1.jpg
http://i262.photobucket.com/albums/i...s/shocks-2.jpg
http://i262.photobucket.com/albums/i...s/shocks-3.jpg
A couple months ago I noticed a small crack where the inlet pipe enters the muffler on my Borla cat-back system. Borla has a "million mile" warranty on these things but I needed the original sales receipt in order to cash in. After four years I had no clue where the receipt was located so I contacted the original vendor (4 Wheel Drive Hardware) and asked if they could get me a copy. They did. I faxed the receipt to Borla figuring I would get jerked around. Much to my surprise a brand new system was sitting on my doorstep two weeks later no questions asked! Having knocked off the driveshaft and shocks (at least the front ones) no problem I went ahead and installed the exhaust as well:
http://i262.photobucket.com/albums/i...ust-skid-1.jpg
Technohead 12-06-2009 02:47 PM
November 2008:
It’s been a while since my last update; except for a handful of camping trips and brew festivals, saltwater fishing consumes my life between May and October. Fishing season is now over for me so I took a couple days last week and worked on my Jeep from sunrise to sundown. The modifications basically fall into three categories:
  1. Cosmetic (paint the cladding, replace fenders and front lights)
  2. New steering box
  3. Rock sliders
Here’s a pic of the final result:
http://i262.photobucket.com/albums/i...v-9-2008-1.jpg
I’ve wanted to paint the stupid looking gray cladding for months now and finally got the job done. After removing the cladding I washed it down with soap and water, wet-sanded it with 400 grit, washed it again with acetone, and then sprayed on 3 coats of flat black Rustoleum. It looks pretty good. Let’s see how long it holds out. Both of my front fenders were pretty well banged up so I picked up a couple same color replacements in near perfect condition from a local parts yard; $75 for the pair. One of my front side marker lights got smashed out this summer, one of the turn signal lenses was cracked, and both of the headlamp lenses were faded so I picked up all new aftermarket replacements from 4Wheel Drive Hardware. The header panel (headlamp mounting panel) was held together with duct tape from carnage a couple years ago so I picked up a new aftermarket replacement ($90 compared to $190 at the dealership).
Fitting up the header panel and fenders:
http://i262.photobucket.com/albums/i...el-fitment.jpg
Relocated charcoal canister:
http://i262.photobucket.com/albums/i...-cannister.jpg
It took quite of bit of tweaking (and something like six beers!) but everything finally fit together just about as good as the factory:
http://i262.photobucket.com/albums/i...mp-fitment.jpg
Next task was to replace the steering box. The stock box was rather sloppy after 220,000+ miles. I considered aftermarket boxes from AGR and PSC but in the end went with a remanufactured stock replacement from NAPA. I figure if the stock box can hang in there that long, and live through three bent tie rods, then it can’t be that bad. Besides, the AGR and PSC boxes go for $500-$600 whereas the NAPA box went for $200 after the $200 core charge.
http://i262.photobucket.com/albums/i...eering-box.jpg
I ran into a little complication pulling the pitman arm off the old box. Normally if I get the pitman arm puller nice and tight, then give the pitman arm a couple good wacks with a B.F.H it falls right off. This time I got the puller tight and just as I was about to wack it, BANG!, the puller fractured. You can see in the pic below a sharp corner that causes a stress concentration and which is a very poor design. Even just a small radius there would probably double the strength. I went and bought a new puller from NAPA (which had a smooth radius instead of the sharp corner) and the pitman arm popped right off.
http://i262.photobucket.com/albums/i...arm-puller.jpg
I coated the pitman arm splines with Never-Seez in case I’m the one that has to take it off the next time:
http://i262.photobucket.com/albums/i...pitman-arm.jpg
Here’s a pic of the installed box with new hoses:
The last task was to bolt on the JCR Stage II sliders. Here is a good example why you want to have sliders:
http://i262.photobucket.com/albums/i...ge-drivers.jpg
I guess its better to get sliders late than never. And good thing the cladding springs back into its original shape. The JCR sliders fit about as good as can be expected for this kind of part. Each slider mounts to the “frame” using two flanges and a total of eight bolts:
http://i262.photobucket.com/albums/i...ange-front.jpg
http://i262.photobucket.com/albums/i...lange-rear.jpg
Then they mount to the rocker panel pinch seam using 1/4” thick bar stock and five bolts:
http://i262.photobucket.com/albums/i...pinch-seam.jpg
With the flanges snug against the frame about 3/8” clearance existed between the pinch seam and the bar stock. I probably should have cut the bar stock off and welded it back on in the correct position. Instead I just drilled and bolted which caused the ends of the bar stock to bend a bit and separate from the pinch seam. No big deal:
http://i262.photobucket.com/albums/i...ll-fitment.jpg
Here’s a driveway pic of the installed sliders and painted cladding:
http://i262.photobucket.com/albums/i...tall-final.jpg
Now comes the fun part, wheeling it. You need to make it past this rock if you want to climb the hill:
http://i262.photobucket.com/albums/i...v-9-2008-2.jpg
At the top ready to come back down:
http://i262.photobucket.com/albums/i...v-9-2008-3.jpg
I landed on this rock hard enough to push the entire vehicle sideways. No damage to the sliders but some of the rock was turned into dust:
http://i262.photobucket.com/albums/i...v-9-2008-4.jpg
Another solid impact here, but no damage to the sliders:
http://i262.photobucket.com/albums/i...v-9-2008-5.jpg
I picked up this log from the bottom of a mud hole and it came very close to ripping off a brake line. The tire had to be removed in order to get the log out:
http://i262.photobucket.com/albums/i...v-9-2008-6.jpg
The only downside to the sliders is I lost a bit of clearance . . . but I know how to fix that! For a while now I’ve been toying with the idea of JK axles (which would require new wheels), a long-arm kit, and 5 1/2” coils. Unfortunately, I ended the fishing season with a blown powerhead on my boat motor and now I’m looking at a $5,000 repair bill. Therefore plan B, a long-arm kit and HP D30 front axle, is probably more feasible given the financial realities.
Technohead 12-06-2009 02:49 PM
December 2008:
For a while now I've been going back-and-forth between getting some JK D44's or building up my own axles. According to the guys at IROR the JK axles are now being sold a la carte (i.e. rotors, calipers, etc. sold separately) and the price has gone up considerably. I have thus committed to building my own. For the front I got a high pinion D30 from a '94 XJ and for the rear I got a D44 from an '87 XJ. These D44's are rare since they were only available on '87-'89 XJ's with the tow package and I needed to travel to New Hampshire to get it.
Front high pinion D30:
http://i262.photobucket.com/albums/i...ont-d30-hp.jpg
Rear D44:
http://i262.photobucket.com/albums/i...s/rear-d44.jpg
I paid $150 for the front and $200 for the rear which is dirt cheap around here. Most yards are selling the D30's for $300-$550 and D44's from TJ's for (well) over $1000.
I'm going to strip them down and do a complete rebuild so by the time I'm done the only parts remaining will be the housings, knuckles, and bearing caps. Gearing will be 4.56's with a Detriot Locker in the rear. The rear will of course be adapted to disc brakes and I want to keep ABS working all around. I'm considering a Superior Super 30 kit w/ ARB in the front but its not clear if this kit works with ABS. I called Superior and was told the axles are machined to accept a tone ring but the guy I was talking to did not give the impression he really knew what he was talking about. Its looking like I am on my own when it comes to ABS in the rear. The wildcard in all this is what to do with the suspension. I'm definitely stripping off all the mounting brackets and replacing them. The question is whether to stick with short-arms and 4 1/2" springs or go with long-arms and 4 1/2"-5 1/2" springs. If long-arms then triangulated 4-link, 5-link, or maybe something entirely different? Decisions, decisions. I'm even thinking about designing my own suspension.
While up in NH picking up the rear axle I had to wait a few hours while they pulled the axle so I asked them to direct me to some local trails. The sent me to some power lines a few miles away. Its was slippery out there! My daughter and I did not get a quarter mile down the trail before we ran into a kid who had his TJ (on street tires) mired. His mother and father were out there in a Land Rover trying to get him unstuck. They had already snapped a tow strap and tensions were running high. We spend the next hour or so shoveling and jacking and were finally able to pull him out with my tow strap. In the end we did not get much wheeling in and never took any action pictures because my daughter and I were to busy fighting about who got to drive.
http://i262.photobucket.com/albums/i...-mud-nov08.jpg
Technohead 12-06-2009 02:50 PM
March 2009:
Time for a quick update. Over the past couple months I've been accumulating all the parts needed for my axle build. I'm basically there now except for gear oil, some brake tubing, and outer rear wheel bearings. All I need now is time and a big dose of motivation; setting up gears sucks!
Brackets for the rear axle came from Mad 4WD. These brackets are for a 5-link set-up so this means I have committed to a 5-link set-up (almost certainly RE) when I install a long-arm kit:
http://i262.photobucket.com/albums/i...-build-001.jpg
Rubicon Express extreme duty adjustable front track bar and JKS adjustable rear track bar. Although these are not strictly required for the axle swap my current front track bar is not cutting it and I figure might as well get these now so I'll be ready when the long-arms go on:
http://i262.photobucket.com/albums/i...-build-002.jpg
Yukon 4.56 gears with master install kit and Detroit Tru-Trac for the front:
http://i262.photobucket.com/albums/i...-build-003.jpg
Yukon 4.56 gears with master install kit and Detroit Locker for the rear:
http://i262.photobucket.com/albums/i...-build-004.jpg
Heavy-duty front axle shafts with 297x u-joints and OEM replacement unit bearings:
http://i262.photobucket.com/albums/i...-build-005.jpg
Crown ball joints. The part number on the boxes was the same but the joints have a slightly different look. Need to check this out:
http://i262.photobucket.com/albums/i...-build-006.jpg
Rear disc brake kit from Teraflex:
http://i262.photobucket.com/albums/i...-build-007.jpg
Moser axle shafts:
http://i262.photobucket.com/albums/i...xle-shafts.jpg
I've got some runs with the Jeep club penciled in for April and May so now I just need to get it done!
May 2009:
Drove down to Waterbury, CT last week. Words are inferior so here's the pictures:
http://i262.photobucket.com/albums/i...n-visit-01.jpg
http://i262.photobucket.com/albums/i...n-visit-03.jpg
http://i262.photobucket.com/albums/i...n-visit-04.jpg
Change of plans in that I decided to go with Clayton's long-arm suspension. Since the rear has triangulated upper control arms I no longer need the JKS adjustable track bar and the upper link brackets.
Also made some real progress.
Detriot Locker installed in the rear axle:
http://i262.photobucket.com/albums/i...-may16-001.jpg
Detriot Tru-Trac installed in the front axle:
http://i262.photobucket.com/albums/i...-may16-002.jpg
Brackets welded on (some of them are just tacked/bolted in the photos):
http://i262.photobucket.com/albums/i...-may16-003.jpg
http://i262.photobucket.com/albums/i...-may16-004.jpg
http://i262.photobucket.com/albums/i...-may16-005.jpg
http://i262.photobucket.com/albums/i...-may25-001.jpg
To be continued . . .
Technohead 12-06-2009 02:52 PM
July 2009:
I pulled the trigger on the axle swap and Claytons suspension. Just a few more days now. . .
http://i262.photobucket.com/albums/i...ly-13-2009.jpg
http://i262.photobucket.com/albums/i...ly-22-2009.jpg
http://i262.photobucket.com/albums/i...uly-22-200.jpg
Technohead 12-06-2009 02:53 PM
August 2009:
I have the rear axle bolted in. All thats left is to connect the brakes lines and driveshaft then fill the diff with gear lube. The D44 is considerably shorter than the D44a so the rear driveshaft is at a local shop getting 1 1/2" added.
Axle shafts and brakes installed:
http://i262.photobucket.com/albums/i...ug-03-2009.jpg
Rear brake plumbing:
A few shots of the installed rear suspension:
Ran into some complications with the front. Got the axle out no problem:
http://i262.photobucket.com/albums/i...ly-28-2009.jpg
Went to remove the track bar bracket which is getting replaced with a double-shear unit and one of the bolts snapped off:
http://i262.photobucket.com/albums/i...oke-july-2.jpg
This bolt goes through to a nut that is welded to the engine mount bracket. Plan A was to remove the engine mount bracket and try to extract the broken bolt. I pulled the engine mount (what a PITA) and then proceeded to break off another one of the bolts holding on the engine mount bracket. Plan B is to just get that MF out of there and get a new bracket because I don't feel like screwing around extracting bolts. I just love it when what should be a 10 minute bolt-on job turns into a multi-hour ordeal.
Technohead 12-06-2009 02:54 PM
August 2009:
So close now. Worked on it sunrise-to-sunset through the weekend. I was not actually working on it the whole time because at least 6 hours of that time was spent dicking around running to various stores to pick up missing hardware etc. Plus I started drinking early both days.
Here's that f***ing motor mount bracket that caused so much pain:
http://i262.photobucket.com/albums/i...ug-08-2009.jpg
Motor mount bracket and track bar bracket bolted back on. Wasted alot of time tracking down the required metric 10.9 hardware:
Replacement front bump stops that the stealership gouged me $90 for:
Positioning the front axle:
Dialing in the caster angle. Factory calls for 7 degrees positive. With the larger tires I figure anywhere from 3-7 should be OK. I can tweak it later if necessary but I really don't want to because adjusting those control arms is a PITA:
Sliding the springs into place. Dropped the axle down off the jack stands and never needed the spring compressor:
Install knuckles, outer axle seals, axle shafts, and unit bearings:
Install brakes:
Bolted up the driveshaft. The old low pinion axle used a longer pinion gear while the new high pinion axle uses a short pinion gear. I was hoping the two effects would cancel. As you can see by the bare spot on the slip yoke they did not. Driveshaft is stretched about an inch with barely a half inch of extension left. I can probably get away with it for a while but before too much longer back to RI Driveshaft I go:
Adjusting the trackbar:
Technohead 12-06-2009 02:55 PM
August 2009:
Here she is sitting on all fours again:
Plenty of room in the wheelwells now. Those 32's are looking small. I could probably fit 35's but plan to stick with 33's (305/70/R16).
Still some work left; plumbing the rear brakes, shocks, and something for exhaust behind the cat.
Technohead 12-06-2009 02:56 PM
September 2009:
Some of the final details.
Built some custom rear bump stops from 3"x1.5"x0.120" rectangle tubing, bar stock, and 4" XJ "upcountry" rear bump stops:
http://i262.photobucket.com/albums/i...p-stop-001.jpg
http://i262.photobucket.com/albums/i...p-stop-002.jpg
You can see the intalled bumpstop in this picture along with the custom stainless tailpipe and Aero muffler:
http://i262.photobucket.com/albums/i...op-exhaust.jpg
Bilstein stocks all around. The mounts were designed so the same part number fits all four corners. Had to pull the ABS pump to install the driver's side JKS stud eliminator. No more dealing with those PITA studs:
http://i262.photobucket.com/albums/i...ug-12-2009.jpg
http://i262.photobucket.com/albums/i...inator-001.jpg
http://i262.photobucket.com/albums/i...on-aug-10-.jpg
Custom made some tabs for the steering stabilizer:
http://i262.photobucket.com/albums/i...ilizer-tab.jpg
Technohead 12-06-2009 02:57 PM
September 2009:
Went to the NEA4WD's Fall Crawl up in NH last weekend. First wheeling trip with the new axles and suspension. Everything worked flawlessly except on the way up Friday night I smoked the waterpump 16 miles from the registration desk. Luckily the parts store was still open and a local garage opened up to help me fix it:
http://i262.photobucket.com/albums/i...-waterpump.jpg
The Ocean State Jeepsters campsite:
http://i262.photobucket.com/albums/i...mpsite-002.jpg
Some pics from the trails:
http://i262.photobucket.com/albums/i...arnage-002.jpg
http://i262.photobucket.com/albums/i...arnage-003.jpg
http://i262.photobucket.com/albums/i...ass-VI-001.jpg
http://i262.photobucket.com/albums/i...ass-VI-002.jpg
http://i262.photobucket.com/albums/i...9/IMG_0330.jpg
Video of my buddies XJ on one of the slippery downhill sections. You want to squeeze your pucker hole on this one:
www.youtube.com/watch?v=h2M1-oKGeY8
Got a customized tailpipe and small dent on the door from the Carnage Hill trail:
http://i262.photobucket.com/albums/i...xhaust-tip.jpg
http://i262.photobucket.com/albums/i...-dent-door.jpg
Technohead 12-06-2009 02:58 PM
October 2009:
Ocean State Jeepsters did a trail ride last weekend on some new land we call G2. The trails are fairly mild now but there is potential to cut some new (more challenging) trails if the relationship with the land owner works out. Lots of stumps and I hate stumps! There were a couple fun hill climbs one of which cleaned out the drivers door when my daughter lost control:
www.youtube.com/watch?v=8CES4H8xcLo
Oops:
http://i262.photobucket.com/albums/i...-oct09-013.jpg
http://i262.photobucket.com/albums/i...-oct09-014.jpg
Made it up on the second attempt but I screwed up the video:
www.youtube.com/watch?v=m0zznzPvjRk
A steep downhill section made extremely slippery from about 2" of rain the day before. As always still photos do not convey the real scenario but the video gives a good feel for it:
http://i262.photobucket.com/albums/i...-oct09-002.jpg
www.youtube.com/watch?v=RykbkdqXC5o
http://i262.photobucket.com/albums/i...-oct09-010.jpg
http://i262.photobucket.com/albums/i...-oct09-016.jpg
The time now is 08:55 PM.
