ejschultz Build Thread - Page 7 - JeepForum.com
 1Likes
post #91 of 204 Old 02-29-2012, 12:35 PM Thread Starter
ejschultz
Nah. It should be pretty easy. I just don't want to have to do it. Lol. I'm lazy when it comes to stuff like that.
ejschultz is offline
post #92 of 204 Old 03-08-2012, 05:35 PM
Tre3
hey i know your on a budget and want tires at the same time, and when talking to someone about cheaper tires and they sent me this:
https://www.treadwright.com/p-4-30-9-50r15-mud.aspx
i dont know if you want retreaded tires, but thought in case you liked em you could find some cheap 31's
Tre3 is offline
post #93 of 204 Old 03-08-2012, 06:12 PM Thread Starter
ejschultz
Sweet man. Thanks. I'll definitely look into that. I'm pretty sure I decided I'm going to keep my 16s and go with 245/75/16s. They have some on that site that I'm going to check out. I definitely appreciate the link.
post #94 of 204 Old 03-11-2012, 10:32 AM
bmlzj86
if i were you i would go with a 265/75/16 or 285/75/16 i had 245/75/16's and they looked tiny with my lift so i went with a 285 cooper stt and it filled the wheel well nice
bmlzj86 is offline
post #95 of 204 Old 03-11-2012, 10:45 AM Thread Starter
ejschultz
For most tires, 245/75/16 measure identically to a standard 31 diameter wise. Most 31s are about 30.5" in diameter. These calculate to be the same. For the Duratracs, they are identical given Goodyear's specs. The width is obviously less, but a 245 mm width pairs up perfectly with a 7" wide rim. Most manufactures measure this size on a 7" wide rim. I'm pretty set on that size. Anything is going to look bigger/better than the 29s I have on there now. Take into consideration that I still want to be able to flex without trimming. 265/75/16 is 31.6" and 285/75/16 is 32.8". No way would I put my D30 up to the task of spinning 33s. I also don't want to lose a bunch of power going up in tire size.
post #96 of 204 Old 03-11-2012, 06:49 PM
bmlzj86
I wouldn't worry about the d30 and 33's I know guys running 35's with a locked d30 and don't have an issue
bmlzj86 is offline
post #97 of 204 Old 03-11-2012, 07:03 PM Thread Starter
ejschultz
I don't plan on upgrading or changing my gears though. I think they'd give me too much of a power loss. I'm definitely sticking with a 31" tire. Can I fit bigger? Probably. I don't necessarily want to though.
post #98 of 204 Old 03-11-2012, 10:27 PM
bmlzj86
I hear ya. I knew I wanted at least 33's I was kinda worried about the loss in power but honestly I didn't notice a big difference but either way you go is better than 29"tires
bmlzj86 is offline
post #99 of 204 Old 03-27-2012, 02:06 PM Thread Starter
ejschultz
Black wheels? Sure...
post #100 of 204 Old 03-27-2012, 02:24 PM
Tre3
dang.. that looks great!
Tre3 is offline
post #101 of 204 Old 03-27-2012, 02:52 PM Thread Starter
ejschultz
Thanks a lot. I had to resand and paint one of the wheels on it, but they all turned out pretty decent. What more could I want for $25 worth of wheel paint and a couple hours time?
For anyone that's wondering, I did paint the spare too. I actually practiced on that wheel first, then moved onto the back wheels. The first wheel I did after the spare turned out so good was the one I needed to redo. All in all, I'm pretty happy with the turnout.
post #102 of 204 Old 03-27-2012, 02:59 PM
nickpequignot
I think on my spring break I'm going to paint mine. How did you do it I though about a wire wheel or some sand paper then like flat black spray paint. And I read somwere to put p.aying cards around the edge of the rim to cover the tires. And do a few coats once they are dry.
nickpequignot is offline
post #103 of 204 Old 03-27-2012, 03:08 PM Thread Starter
ejschultz
I sanded the wheels with 60 grit sand paper. Honestly, it kinda killed me a little to start sanding. I then used Rustoleum wheel paint. Harbor Freight had some matte black on clearance because they're changing the design on the can. I picked up 6 cans. I only used 2, including the spare. I have about 4 coats on each wheel. I didn't mask off the tires. The paint will wear off them in a couple weeks after driving it. I don't really care much that there's paint on them. I'm getting new tires sometime before the end of summer.
post #104 of 204 Old 03-27-2012, 03:29 PM
nickpequignot
Oh so you can send me the other cans then right?lol. I didn't even plan on doing the spare cause it's all ready black. But I think my limited would look god with black rims. Then this summer black cladding
post #105 of 204 Old 03-27-2012, 03:33 PM Thread Starter
ejschultz
My spare is identical to my other wheels. My tire is a stock size Goodyear Eagle RS-A though. I'm getting 5 new tires to fix that when I get my new ones. As far as black cladding goes, mine came with that. The TSi's had body colored plastic cladding on them from the factory. If it didn't, painting it black would have been one of my first mods.
Nelson1248-build thread nelson1248 Grand Cherokee General Discussion 242 02-18-2015 08:27 AM
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
