Double Triangulated Question. - JeepForum.com
post #1 of 10 Old 07-02-2013, 05:59 PM Thread Starter
macbethpoe1
So I was under my Jeep looking for LA mounting possibilities, and realized that there aren't a lot. I notice on Claytons kit, the LCAs run basically straight from frame bracket to axle mount. The uppers are triangulated, but I am wondering if anyone has found a way to do this with the lowers? It seems like it would help with any lateral axle movement, and I'm sure others things like roll axis and stuff. First thought was a rear crossmember, but the distance between "frame" rails is pretty wide, seems wider then where the TC/trans crossmember is, and am not sure if this would be possible for strength reasons. Anyway, just wondering if anyone has been able to do this, I have searched quite a bit and haven't come up with anything.
macbethpoe1 is offline
post #2 of 10 Old 07-02-2013, 06:15 PM
dillonjm
2013 WK
If you're talking the rear arms, Clayton's lowers don't run straight from the frame, they angle out.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #3 of 10 Old 07-02-2013, 06:31 PM Thread Starter
macbethpoe1
So are the brackets mounted on the inside of the frame? Do you happen to know what degree angle it is? I looked at yours and it looked straight, but it must have just been the angle of the picture or something, thanks for clearing that up.
post #4 of 10 Old 07-02-2013, 06:33 PM
dillonjm
2013 WK
Not sure on the degree, here is a better angle, compare them to the fronts which do run in line with the frame.
dillonjm is offline
post #5 of 10 Old 07-02-2013, 06:43 PM Thread Starter
macbethpoe1
That is like the exact picture I have been searching for high and low haha, thanks a lot man! I was just looking at the install insturctions, and it looks like its an 80* angle perpendicular to the frame rail, just FYI.
post #6 of 10 Old 07-02-2013, 09:46 PM
mtnmarc
Double triangluated 4 link will increase the roll axis, generally.
A single triangulated upper is pretty easy cuz you don't need to fab a rear cross member.
If you aren't making it a dedicated trail rig, single tri should do you well.
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline
post #7 of 10 Old 07-02-2013, 11:11 PM
BLACK04WJ
TNT customs made a double tri rear for WJ's a while ago. I saw one in person at GSW this year and it looked well built. I talked with the guy who had it and he said his jeep was the TNT test rig for the kit. He said they don't promote selling it, but if you called them they could probably sell it again.
06 LJ Rubi / 97 TJ / 04 WJ
Oct '12 GCOTM
http://www.jeepforum.com/forum/f22/unlimited-lj-2212193/
BLACK04WJ is offline
post #8 of 10 Old 07-02-2013, 11:55 PM Thread Starter
macbethpoe1
That's interesting, did you get a look at the mounting brackets by any chance?
post #9 of 10 Old 07-03-2013, 12:00 AM
BLACK04WJ
it looked a lot like the stock crossmember actually.
Oct '12 GCOTM
post #10 of 10 Old 07-03-2013, 12:39 AM Thread Starter
macbethpoe1
Hmm, interesting. Just been diving into the suspension sea lately, reading all I can. I just had NO idea how in depth and complex these setups can be, and all the different variables (roll axis/center, COG, anti squat, pinion/caster angles), and how the simplest little changes can change everything. But after seeing DJdillon's picture, and getting the general consensus from The Suspension Thread, it seems like the biggest thing to worry about is, where and how this stuff will actually fit lol.
