#31 | |
True. I agree with you, I don't think the red/black would look too hot.
It makes me glad that my ZJ is black, so there wouldn't be a contrast if I ever chose to go that route.
#32 |
I don't really notice a major difference. They aren't that stiff, they def broke in since I first installed them. They ride pretty well. I've never gotten body wobble, or death wobble which those def helped play a part in i'm sure.
1997 Grand Cherokee Orvis: V8 5.2L, stock. (Sold) 1998 Cherokee Sport: 4.0L I6, Stock. (Sold) 1990 Cherokee: 4.0L I6, 4.5" Lift, 33" BFG's. (Sold) 1997 Grand Cherokee Limited: V8 5.2L, 2" BB, 31" Dick Cepeks. (Sold) 1999 Grand Cherokee Laredo: Build Thread; V8 4.7L, Stock. (Sold) 1996 Grand Cherokee Laredo: Build Thread; V8 5.2L ,3.5" lift, 32" Tires |
#33 |
Got a little work done this weekend but also had a setback. First the work....When I bought this thing the guy told me he got his lawn tractor stuck and used the ZJ to pull it out. In true genious form he had hooked it to the rear bumper and completely ripped the thing off. He said "it just never fit right after that". So I had enough of the floppy rear bumper and took it off for further instpection. Turns out not only did he rip the plastic bumper off he ripped the actual metal bumper clean off it's mounts. So on the right side it tore the bolt through the mount. And on the left it tore the bolt through the bumper. He had welded a peice of 2" banding material to the unibody to get it to sit straight and it was only bolted in using 2 bolts. So I used a BFH and beat it back mostly into position and welded in some patches so I could bolt it back up using the factory mounts. Sorry for the cell pics, I forgot the regular camera at home (I usually work on stuff at my parents since I don't have a garage at my house). While I had it off I also shot it with some Krylon Fusion. I live in a small town and anything besides a Lowes and Advance Auto are 30 mintues away so between the 2 I could only find gloss black. I'm not sure I'm digging it to be honest, it's just to glossy. Oh and the setback....my radiator puked enough fluid out to spray on my passenger side axle u-joints throwing coolant all over the passenger side under carriage and wheel. Its weird though because when I remove the cap the level is still at the top. I'm going to have to remove some stuff to get a good look at it but it might be time for a new radiator.
Passenger side bracket torn hole ![]() Drivers side bumper ripped off hole ![]() The fix, didn't take any pics after I welded it ![]() The bumper getting shot with the Fusion ![]() The finished product ![]() ![]()
Nationalmssociety.org Current = 1996 XJ, 2.5, 2-Door, 5-Speed, 4.88's, SYE, 3.5" Mix-N-Match OME + RE, Black 15" KMC XD122's, 31" BFG AT's, RE QD's My current XJ build thread My old ZJ build thread Previous builds 99-XJ, 98-XJ, 89-XJ, 05-TJ, 95-ZJ, 79-J10 FOR SALE: RE 4.5" AAL for XJ, Reese Hitch for XJ, PM me for details on either |
#34 |
Nice work! The ZJ is looking really good. I would paint the front bumper and rockers to match the rear bumper.
#35 |
Thanks. It's on this weeks to do list, honeslty though I think the rockers are comming off. Sliders will be making their way on there before to much longer and I think they will look better with that last little bit of cladding gone.
#36 |
Sounds good to me.
#37 |
Looks like you have been very busy with the fixes and mods.
#38 |
It's my wallet that's been getting the real workout. I know it's nothing compared to what some guys spend but I'm only a couple hundred shy of spending as much in upgrades and repairs as I spent in the original purchase price.
And I'm nowhere near done, it's going under the knife this week for manifold install, rear main seal fix, talishaft seal fix and a radiator leak diagnostic. Sometime very very soon it's going to have to have an exhaust system, it has issues from the header to the tailpipe. Also need a new battery, mid winter will need new tires then early spring I'll have to get the A/C fixed. All part of owning a Jeep.![]()
#39 | |
n i must say...it's another mooneyjohn...
#40 |
Don't worry it's on the to do list. I just didn't have time to get to it Saturday and was busy Sunday. And I'm not offended I actually was going to do the same IRO setup as you and Mooney but I didn't like the idea of 3.55's and 32's so I'll stick with my BB for a year or so until I swap axles and regear.
#41 |
mooney has 3.55's im pretty sure. unless he got the towing package for an I6?
we have 2 diff motors and if he didn't get the towing package, I'm running 3.73's n he has 3.55's
#42 |
IIRC he swapped in a D44a and a D30 with 3.73 from a 5.2 ZJ
#43 |
I ran 31's on my old 2-door with 3.07's and hated it. When I took it to Colorado at the altitudes I was 2nd gear getting to the top of some of those mountains, on the interstate. I was carrying 700 or 800lbs of gear but.....I swore to myself right then I would never go to big tires without gearing. I ran 32's on my TJ with 3.73's and it was decent. I'm not knocking anyone at all for doing it, I'd probably do it if I didn't tow. But the 2,500lb boat I tow in the summer, on top of the fact that I live in the mountains and the large tires I want just aren't worth me killing my tranny and patience. I'll do that same swap D30/D44a sometime in the future.
#44 | |
Nighthawk
Correct.
Built Not Bought #037 Project Blue Moon Build Thread > > > http://www.jeepforum.com/forum/f197/moonyjohns-project-blue-moon-2000-wj-1009379/ 1996 ZJ 4.0 - [SOLD] 2000 WJ 4.7 - 5.5" Front IRO LA, 2" Front spacers, Bilstein 5125 12" travel, JKS BPE's, 35/12.5 Goodyear MT/R Kevlar, 15x8 3.75" MD 72 Series, SOLID D30 cover, BTF D44a cover, Cobra CB, 4' Firestik, Alpine iDA-X305, Alpine SWE-1243 Sub, Homemade sliders, Laredo Style Headlights, 20% window tint, D-ring shackle, Custom front bumper, Procomp 9" Lights, Gas tank lift, XRC-8 Winch w/ Synthetic, K&N FIPK Intake Kit, Magnaflow High-Flow Cat, FM50 series, Amsoil 6x9 Filter, LED tailights, Alpine Door Speakers & Tweeters, Custom Rear Swing Out Bumper w/ Spare |
#45 |
That's definately the route I'll eventually go. What did the 2 used axles cost you?
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
