Dodge 242 D (HD) & 231 D (HD) transfer case options. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Dodge 242 D (HD) & 231 D (HD) transfer case options.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineORS Recovery RopeSynthetic Winch Rope from ORS
Unread 02-22-2014, 09:42 PM   #1
gcjeeping
gcjeeping's Avatar
Thought I'd start a thread about what I have found out about the 98-04 Dodge Durango/Dakota 242 D (HD) & 231 D (HD) Transfer Case to keep info in one place.
Thought it might be helpful for those trying to find a 242 HD since the Jeep 242 HD is scarce and the Dodge ones are more common and usually cheaper.
231 D is in second post.
I have included some pics too.
First it looks exactly like a Jeep 242 HD (V8).
Has aluminum tail cone, 32 spline rear output shaft, electrical connector on top and shift lever on side.
The only thing I couldn't find while looking at the JY was the input shaft length and chain size.
But while I was at a pic m pull in Oregon I found one pulled and it had a short input shaft like a Jeep 242 LD (I6).
Also found specs on the Dodge 242 D (HD).
This is a New Transfer Case Chain for a Dodge Np 242/244
Fits 1998-2004 Durango's with Full Time NP242 or NP244 Transfer Case
HV072
OE Supplier Borg Warner/Morse
1.25" wide 98 pitches 49 Links
The Jeep 242 HD (V8) specs..
EVO 242 4.7 (00-03) pn 05003453AA
Type: NP 242, 244
Number of links: 49
Width: 1-1/4"
Dodge 242 D pics.
__________________________________________________ _________
-GCJEEPING's build/mod thread-IT'S A GREEN THING...
gcjeeping is offline   Reply With Quote Quick reply to this message
Unread 02-22-2014, 09:44 PM   #2
gcjeeping
gcjeeping's Avatar
From another thread I started.
Originally Posted by MurdaJs View Post
I have a 231D HD out of a 97 dakota 5.2 5 speed. Input shaft is 23 spline .840", output is 32 spline internal slip, from my research ot should also have a 1.25" chain.
Unread 02-26-2014, 03:27 PM   #3
NOVAXJ
So theoretically a 242D from a dodge should fit into a WJ with a v8, correct? Because if so, the dodge 242s are everywhere at my picknpull, and they are usually dirt cheap since theres so many. The wj 242hd, not so much.
NOVAXJ is offline   Reply With Quote Quick reply to this message
Unread 02-26-2014, 03:36 PM   #4
gcjeeping
gcjeeping's Avatar
Originally Posted by NOVAXJ View Post
So theoretically a 242D from a dodge should fit into a WJ with a v8, correct? Because if so, the dodge 242s are everywhere at my picknpull, and they are usually dirt cheap since there is so many. The wj 242hd, not so much.
Yes I believe so. You would have to swap the input shaft though since the WJ 242HD V8 uses a longer one than the 242D (HD) V8. Also you still need the rear drive shaft and would have to check the length.
A benefit is all the 242D's I have seen have the U joint yoke on the front TC output. This could also let you upgrade the front drive shaft too if the length is right.
If you do this let us know so others can try it or not too.
Unread 02-26-2014, 03:40 PM   #5
NOVAXJ
Yeah I want to give it a shot, Ill try and go sometime in the next two weeks during my spring break when I have some time and see if I can pick up the dodge tcase. Whats involved with the 231 swap?
Unread 02-26-2014, 04:08 PM   #6
gcjeeping
gcjeeping's Avatar
Same thing (swap input shaft) except rear drive shaft spline should be the same as the one you got now and not the 32 spline like the HD's.
Unread 02-26-2014, 06:56 PM   #7
NOVAXJ
Doesn't the 247 with a v8 have the 32 spline as well? Or am I wrong
edit: Nevermind, I read that wrong. I see what you are saying.
