dnuccio's build thread-1995 ZJ Limited - Page 8 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > dnuccio's build thread-1995 ZJ Limited
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 05-12-2013, 04:05 PM   #106
moparlover1992
Originally Posted by dnuccio View Post
thanks!
my dad had his paint guy at work do the hood. he did the hood, the rear louvers (they were faded) and he did the rear bumper cover all for a hundred bucks
I think I may do the black stripe on my cladding red and the rest black. That would go with the red pinstripe too. And give it a wanna be trailhawk look lol. That's a wicked good deal you got
95 zj 5.2 np242 3.5'' IRO lift, IRO adjustable arms, KOR front trackbar, steering stabilizer and box brace, IRO rear adjustable trackbar, bilsteins, Hughes plenum plate, flow master 40, 31x10.5s on 15'' dc-2 rims
Mopar or no car!
moparlover1992 is offline   Reply With Quote Quick reply to this message
Unread 05-14-2013, 12:09 AM   #107
dnuccio
Found some weird wear on the front right today. outside edge was worn down, but it cant be underinflation because the inside edge is perfect. think it was from the tire rubbing the inner fender before it cut the piece out. rotated the tire to the back so we'll see if it happens to the originally rear tire tire, and if it does, ill investigate it further.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline   Reply With Quote Quick reply to this message
Unread 05-29-2013, 10:23 PM   #108
dnuccio
been a while since i updated the thread, not much has happened though.
RIP ratmonkey, the ZJ encyclopedia. my condolences to his family.
R.I.P. Ratmonkey
Unread 05-29-2013, 11:46 PM   #109
KyleSekora
How's the wear going?
______ooooo
/__l_l_,\____\,___
l_---l_l__l---[ ]llllll[ ]
_.(o)_)__(o)_)---)_)
KyleSekora is offline   Reply With Quote Quick reply to this message
Unread 05-30-2013, 12:24 AM   #110
dnuccio
havent noticed anything out of the ordinary yet. its weird. none of the other tires have even a small sign of starting to wear the way that one did. im thinking it was from rubbing the inner fender. i have since cut out the piece that the tire was contacting
R.I.P. Ratmonkey
Unread 06-15-2013, 05:12 PM   #111
dnuccio
did a little more work on the jeep today.
was at the junkyard yesterday and found a couple spring clips for my tow hooks. 50 cents a pop! little rusty, but nothing a wire wheel couldnt fix. for those of you that dont know, they keep the strap from falling off the hook.
also found out why my aux lights werent working. the ground wire to the relay somehow broke. added a new one and they work now.
R.I.P. Ratmonkey
Unread 06-17-2013, 01:13 PM   #112
dnuccio
think the tire wear might be a bad shock. gonna pull the shock later and check it out.
R.I.P. Ratmonkey
Unread 06-29-2013, 12:53 PM   #113
dnuccio
shock seemed ok. it does need shocks though, im still on stock length ones.
i recently trash picked a piece of an old pool fence, because it had alot of good 3/4" square tube. I was going to use it on the go kart im putting together, but now I kind of want a roof rack again. what do you guys think? badass go kart, or badass roof rack?
R.I.P. Ratmonkey
Unread 06-29-2013, 02:36 PM   #114
GCjunkie93
Definitely a badass go kart.
1993 ZJ 5.2 V8-Some Stuff/Beater
1984 CJ7 258/Auto/Dana 300/Daily Driver
GCjunkie93 is offline   Reply With Quote Quick reply to this message
Unread 06-29-2013, 03:28 PM   #115
dnuccio
just talked to a buddy of mine, he just got a new rv gate because his friend backed their boat into the old gate (first time backing up a trailer), so he is gonna give me the old gate. ill be able to do both
go kart is kind of shelved right now anyway, i need to get a trans pan for the jeep, and get my u joint driveshaft put in. still need to swap the yoke (which ill probably have a shop do anyway, i dont want to screw it up)
R.I.P. Ratmonkey
Unread 06-29-2013, 08:04 PM   #116
dnuccio
roof rack build
started building the new rack.
heres some of the drawings i made
bottom part of the frame done
top part done
hopefully ill be able to get that piece of fence from my buddy on monday (hes on vacation this weekend). after i get that, this should be build pretty quick. then ill just have to go to walmart and get some flat black krylon. same paint i used on my wheels, i like it because it dries really really fast (fast enough that when i painted my wheels, i could paint one wheel, paint another one, and go back to the first one for a second coat. just like that, no delay) and it covers really well.
R.I.P. Ratmonkey
Unread 06-29-2013, 08:07 PM   #117
dnuccio
and yeah i know that im my first drawing, 6.5" x8 doesnt equal 53", the cross bars will be slightly more spaced out than 6.5", somewhere around 6.6" is about right. obviously it wont be perfect, since im just kind of eyeballing it.
R.I.P. Ratmonkey
Unread 06-29-2013, 10:06 PM   #118
dnuccio
welded in some of the cross bars. ran out of metal, so the rest will be done when i get some more.
always be very aware of your surroundings when welding
R.I.P. Ratmonkey
Unread 07-02-2013, 05:34 PM   #119
dnuccio
rack is done, just needs paint now. will post pictures in a bit.
R.I.P. Ratmonkey
Unread 07-03-2013, 09:17 PM   #120
dnuccio
pics as promised
shovel mount:
not mounted yet, just posing for the picture
R.I.P. Ratmonkey
