Diesel grand Cherokee - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Diesel grand Cherokee
RCV Axles at CCORPoison spyder items @ oconee off road 706 534 9955Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 07-23-2014, 12:56 PM   #1
yellowjeep222
Am looking at the 2014 GC Diesel. Can I get some feedback from anyone whose has had one for a while? What has been your experience? How is the power? How does it tow small trailers? Gas mileage? Any problems?
yellowjeep222 is offline   Reply With Quote
Unread 07-25-2014, 12:02 PM   #2
MartyA
2012 WK
Check out the WK2 forum instead of the general forum. There's lots of posts that directly answer your questions.
MartyA is offline   Reply With Quote
Unread 07-26-2014, 12:39 PM   #3
dunno513
how does it tow small trailers?
question is how does it tow small houses
towing a 3.5k boat
1996 v6 2wd - struggled with just about anything, stuck at launch many times.
2002 4.7 4wd - fine on the flats, hills had it running 4k just to keep speed
2012 5.7 4wd - only knew it was back there while accelerating.
2014 3.0l 4wd - if I didn't have the econ gauge I wouldn't know it was there.
summary.. I need a new boat...
dunno513 is offline   Reply With Quote
Unread 07-29-2014, 03:24 PM   #4
kg6mov
Hears the voices
kg6mov's Avatar
32mpg on cross country trips. 600 miles on a tank with axles for my trail pig in the back. Turbo lag is a bit annoying, doesn't jump off the line like the V8's, doesn't get 13mpg and spit out parts either.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 31's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, New engine and trans, no front driveshaft, but it's pretty
"Whats wrong with a PT Cruiser?"
"Coulda had a V8!"
96 build thread
Niner build thread
kg6mov is offline   Reply With Quote
