Diagnostic plug location? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Diagnostic plug location?
New Hours at RUFFSTUFF!Enjoy 5% off in April 2000-2006 Jeep Wrangler Ignition CoiEnjoy 5% off in April 1997-2006 Jeep Wrangler Door Weather
Unread 07-06-2010, 03:12 PM   #1
elwood10
Hello! I have a 93 Grand Cherokee 4X4 with the straight 6, can anyone tell me where the plug is located? I'm tired of counting flashes, & would like to use my scan tool. Thanks!
elwood10 is offline   Reply With Quote Quick reply to this message
Unread 07-06-2010, 04:03 PM   #2
xJoshxx
2012 WK
did you by a ODB2 Scan tool? or a OBD1?
Interested in Amsoil? Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2
2012 WK2 SRT8
xJoshxx is offline   Reply With Quote Quick reply to this message
Unread 07-06-2010, 05:56 PM   #3
elwood10
I have a OTC Nemisys, which is OBD 1 and 2. And the Chrysler OBD 1 cable, so if I can find thr plug, it should work fine.
Unread 07-06-2010, 05:59 PM   #4
Erbo1Kanerbo
mine is on the drivers side around where the hood release thing is
ZJ Build thread:
[URL="http://www.jeepforum.com/forum/f197/my-slow-zj-build-1024680/"]http://www.jeepforum.com/forum/f197/my-slow-zj-build-1024680/[/URL]
ZJ's: If you dont know what it is you cant afford it.
Erbo1Kanerbo is offline   Reply With Quote Quick reply to this message
Unread 07-06-2010, 06:34 PM   #5
soul_Less
1994 ZJ
96 and later have that OBDII port
93-95 still had OBDI and dont have a port beside the hood release.
to the OP, I think theres a plug in the engine bay somewhere..
soul_Less is offline   Reply With Quote Quick reply to this message
Unread 07-06-2010, 07:30 PM   #6
elwood10
That's where I first looked, but couldn't find anything near the left or right fenders.
Unread 07-06-2010, 07:44 PM   #7
ratmonkey
R.I.P.
ratmonkey's Avatar
it should be tucked up next to the ecm.
ratmonkey is offline   Reply With Quote Quick reply to this message
Unread 07-06-2010, 07:47 PM   #8
soul_Less
1994 ZJ
Is this it??
Unread 07-06-2010, 07:57 PM   #9
xJoshxx
2012 WK
there she blows.
2011 WK2 ORA2
2012 WK2 SRT8
Unread 07-06-2010, 09:21 PM   #10
elwood10
Hey! Thanks for all the inputs! The picture was the clincher! Pictures are a mechanics best friend. This forum is awesome! I use a Ford forum once & awhile for my other vehicles, & it's pretty useless. I usually end-up answering my own questions there.
Unread 07-06-2010, 09:31 PM   #11
soul_Less
1994 ZJ
Yea, pictures are always very helpful. And it saves from writing 1000 words each pic.
Unread 07-07-2010, 07:21 AM   #12
comptiger5000
Elwood - FYI, a 93 grand cherokee is a ZJ, not an XJ.
comptiger5000 is offline   Reply With Quote Quick reply to this message
Unread 07-07-2010, 12:09 PM   #13
elwood10
Thanks, I wasn't sure, I'll change that in my profile. You'd think after owning & doing a lot of work on both my Cherokee & Grand Cherokee, I'd know that, but I was never asked at the parts store, nor did I ever give it any thought.
Unread 03-25-2015, 09:17 PM   #14
angelwood10
1994 Jeep Cherokee SE
I have a 94 jeep SE. Had some engine work done and transmission replaced. Picked up my jeep today and when I turned on my headlights the radio immediately shut off but then cut right back on. Jeep ran just fine for about 5 miles. When I then stopped for gas. Turned off ignition, put gas in jeep and then proceeded to crank truck. Nothing happen. all lights and buzzers came on but it was like battery was dead. Someone then came over and gave me a jump. Jeep started with no problems. When I arrived home I turned off ignition then tried to restart truck, once again, nothing happen. As I was tinkering with it, I figured out when I hit the brakes, it made the inside light flicker. If I was to move the entire battery back and forth (with key switched on) all lights and dashboard lit up like all power was restored. But only for a split second. What could be wrong? I am thinking a wire is grounding out somewhere. But I have litterally traced each wire only to find the connector "85572" is NOT plugged into anything. Should this connector be left free or should it be plugged into something? I am completely baffled and starting to get discouraged. PLEASE HELP... Thank you in advance for any suggestions
angelwood10 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 04:50 PM   #15
vlackattack
In the future, start your own thread rather than commenting on a 5 year old thread not related to your problem. It sounds like you have a problem with one of the grounds somewhere, try checking all of them and make sure they're clean. There's probably threads on here covering where all the grounds are. Not sure about the connector thing.
vlackattack is offline   Reply With Quote Quick reply to this message
