derekmac's WJ build - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > derekmac's WJ build
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 08-08-2014, 03:00 PM   #1
derekmac
derekmac's WJ build
**Most of this is copied from a build thread that I have going on another site.**
Well I figured what the hell, might as well have a build thread for my WJ. Now this won't be an ordinary build thread, oh no. It's going to be the slowest and most boring one in history!!
I haven't done all that much to it yet, but I did install a 2" budget boost, bigger than stock tires and trimmed the front bumper.
Here it is, not too long after we got it. It was all shiny, no scratches, dents or rust.
One of the first things I did was to Plasti-Dip the emblems as they looked pretty bad.
I also Plasti-Dipped the fuel door, and since I had it, put a Monster sticker on it.
The next thing I did was get tires for it. For some reason, the almost bald all seasons on it didn't fare too well in the mud.
Looked a little more like a Jeep should.
After that, I also Plasti-Dipped the rims as I'm not really a fan of chrome.
And I also installed my 2" lift.
I also thought I should install a CB, and my parents happened to have an old (verrrrrry old) one that they gave me.
I got tired of the tires rubbing on the front bumper, so I gave it a trim.
That's about two years worth of work. Like I said, a sloooow build.
32" MTs | Custom Sliders
4" RC | Viair OBA
http://goo.gl/wWBlre
derekmac is offline   Reply With Quote Quick reply to this message
Unread 08-08-2014, 03:05 PM   #2
derekmac
I bought it off of eBay. The place has amazing feedback and they've sold almost 3000 of these lights. It was also much cheaper than anything I could find local. I'm interested to see how well it works.
http://www.ebay.ca/itm/24INCH-120W-L...item4d14754d84
No pics of the install as it was starting to get dark when I started to do it. I'm really happy with how bright it is! It doesn't have crazy throw, but does a great job lighting up in front of you.
It was really hard trying to take half decent pics with a phone, the difference is quite a bit more than what the pics show.
Here's just low beams.
Low and light bar.
Just high beams.
High and light bar.
I mounted it back a bit so I wouldn't get any glare on the windshield, or hood.
Only a tiny bit of light lands on the hood, and I can't see it sitting in the Jeep.
Here's how it looks mounted, now that I had a chance to clean up the wiring some.
4" RC | Viair OBA
Unread 08-08-2014, 03:07 PM   #3
derekmac
I used Plasti-dip on the front grill, and used wing-walk paint on the bumpers, and plastic on the doors.
Also took off my mangled steering damper.
4" RC | Viair OBA
Unread 08-08-2014, 03:12 PM   #4
derekmac
I cut the wheel wells to eventually allow for bigger tires. Here's a pile of dirt that came out of the drivers side plastic rocker cover. No wonders it's rusted!
Here it is with the lines drawn on.
The relief cuts made.
And basically done. I need to fix the rust on the fender, and trim the plastic liner.
Here's the front finished.
The back before cutting.
After cutting.
These show how much was trimmed.
It's not perfect, but it's good enough for me. The next thing will be to have the rockers cut out, and new metal welded in.
4" RC | Viair OBA
Unread 08-08-2014, 03:15 PM   #5
derekmac
The Jeep was in the Garagemahal to get the rusted out rockers cut out, and new sliders welded in. Also had the ball joints replaces on it. Here are some pics that he took, and I'll add some more when I get it back tomorrow.
4" RC | Viair OBA
Unread 08-08-2014, 08:31 PM   #6
derekmac
Here are some of the finished pics he took.
4" RC | Viair OBA
Unread 08-09-2014, 04:05 PM   #7
derekmac
Picked the Jeep up from the Garagemahal today. What a difference!! The sliders turned out even better than expected. Scott did a fantastic job.
Here are some pics of the finished product, before and after paint.
4" RC | Viair OBA
Unread 08-18-2014, 06:41 AM   #8
2000wj6v40
Thanks fore the pic's...
I have a 2000 WJ that looks like yours... Same colors as 1st picture (silver/ light gray vinyl)
Question... I noticed the color change on the vinyl skirting and bumpers..... Did U Plasti-dip them ??? If not, what did you use to make them darker
and even out the color... Cause I can't get an even color coat on mine and yours look pretty damn good to me.
Cat5
2000wj6v40 is offline   Reply With Quote Quick reply to this message
Unread 08-18-2014, 08:08 AM   #9
Jeep32
Ive never seen a WJ rust like that! On the drivers side, the fender and quarter are crazy! Other then that looks like a fun rig man!
"so i did a full tune up soup to nutts."
4.7 213k+
Jeep32 is offline   Reply With Quote Quick reply to this message
Unread 08-19-2014, 12:09 PM   #10
derekmac
Cat5
No, I didn't use Plasti-dip on them. In the first post, where they get darker, I had used Krylon bumper paint in the closest color I could find to the original. The stuff was really easy to spray on, and it went on nice and even. It also holds up really well to abuse. Just make sure the plastic is really clean, and give it a scuff with a red scotch bright pad.
In the winter, we get a ton of salt on the roads. I blame that, and the plastic rocker covers for the rocker rust. I had probably two pounds of dirt caked between the plastic and the metal. On the fender and quarter, the fender liners held a lot of dirt also, and I didn't realize that until the rust started to show through.
Even though it's not really built up, it is a fun rig. When I get a 4" lift, it'll be even better, or at least I hope it will be!!
4" RC | Viair OBA
Unread 08-19-2014, 03:18 PM   #11
derekmac
The latest thing I've done is to start a GoFundMe thing. I figured what the hell, why not try it.
Lift kit for Jeep
4" RC | Viair OBA
Unread 08-19-2014, 04:44 PM   #12
2000wj6v40
Thanks
Unread 09-03-2014, 12:36 PM   #13
derekmac
Well I'm thinking about buying a Viair OBA setup. I'm looking at this one here: VIAIR 150 PSI High-Flow Air Source Kit. Anyone have any opinions on this? I'm only going to be using it for airing up tires.
4" RC | Viair OBA
Unread 09-05-2014, 08:32 PM   #14
derekmac
Well I ordered the Viair kit. I'm going to be running 1 gauge wire from the battery (yes, it'll be fused at the battery) to the back and into a fused distribution block. From there I'll be running 8 gauge wire to a relay, and from the relay to the pump. I know that the 1 gauge wire is way overkill, but I want to be ready incase I get a power inverter, or install a sub and amp.
4" RC | Viair OBA
Unread 09-12-2014, 07:27 PM   #15
4x4Jeep
i started off slow too, past year or so started getting serious with the mods...due to more income. nice build and good luck with that fund, i see you had a few donors..
Build - http://www.jeepforum.com/forum/f197/4x4jeeps-build-thread-1341031 - SOLD
4x4Jeep is offline   Reply With Quote Quick reply to this message
