Dash board lights flash during cold weather - JeepForum.com
post #1 of 2 Old 09-10-2013, 01:53 PM Thread Starter
Jeep-Creep
Why, only during the colder months, does my speedo gauge/panel, my radio station display panel, and my two small AC button lights all flash on and off together? This only happens during the cold fall/winter months. Never during the summer months and has happen like clock work for the past three winters. I checked the fuses and all seem good. Any suggestions on what else to check?
Jeep-Creep is offline
post #2 of 2 Old 09-10-2013, 06:26 PM
JeepNicholson
Is this when your headlights are on?
If so, it kinda sounds like your headlight/dimmer switch needs resoldered. I'd guess that cold weather causes the cracked solder to shrink slightly which breaks the connection.
Edit-
Or maybe not, since your other thread says your cel is acting strange.
You should combine these into one single thread, they could be caused by the same thing.
JeepNicholson is offline
