Daily Driver 5.9 build thread - bumpers, tube rockers, etc.. - Page 4 - JeepForum.com
 5Likes
post #46 of 375 Old 01-22-2012, 01:28 PM Thread Starter
Timo_90xj
Timo_90xj's Avatar
Seems like my build thread was moved to general discussion.. I guess it's where it should've been from the beginning.
Originally Posted by PolkaPower View Post
Or just carry your spare
Do you listen to any of that Black Metal like Sentenced or Purtenance?
Yeap, I do.. mostly good 'ol rock 'n roll, and all sorts of metal from "mainstream" to really weird stuff - and occasionally some classical music too Why? ..btw., it's not me on the highlift lever, although my beard isn't much shorter than that
Back to business, I wonder what's this gonna be:
Not finished yet, but should give you an idea. I need to notch & reinforce the center for tranny bushing clearance. Holes are already drilled on the underside for countersunk 10mm class 12.9 hex bolts. I got tired of ripping the standard bolt heads when sliding over rocks.
I'll add some sort of protection for the TC and tranny oil pan (probably 1.5" OD DOM hoops skinned with 1/4" plate). Need to figure out a smart and easy way to add supports on the uniframe rails for them - with the four stock 10mm class 10.9 bolts the whole thing would rip right through the frame rails when the first rock hits the hoops..
***Under construction***
Timo_90xj is online now
post #47 of 375 Old 01-22-2012, 02:11 PM Thread Starter
Timo_90xj
Timo_90xj's Avatar
..few more pics from the wheeling trip on Sat..
That's the trail covered in snow
..first Jeep opening the path:
A little deep at times (33s on the TJ):
There's only one position on the skinny pedal in winter
post #48 of 375 Old 01-22-2012, 03:37 PM
Benja
omg, those pics are awesome, like your niner !
97' Grand Cherokee Limited V8 41K
STOCK
Benja is offline
post #49 of 375 Old 01-23-2012, 10:19 AM
sdmayhew
wheres the video from the contour camcorder on the hood?
looks like fun! Did a run in the Sierras and only had 6" of snow.
1993 ZJ Clayton long arms with Johnny joints, custom front axle W yota center, D44 chevy outers, fabtech dirtlogic 2.25, front bilsten rear shocks, tacoma rear axle, 4.88, arb rear, 5 speed, poly motor mount inserts, NP241OR 4-1 ,receiver front for xcr 8k winch
sdmayhew is offline
post #50 of 375 Old 01-23-2012, 10:30 AM
sabzz
GoPro? Videos would be nice!
1998 ZJ 4.0 work in progress/DD
'97 ZJ 4.0|3.5 RC|31" -SOLD
sabzz is offline
post #51 of 375 Old 01-23-2012, 11:11 AM Thread Starter
Timo_90xj
Timo_90xj's Avatar
Trying to gather a bit more material.. I've got a way too small memory card, and I never remember to buy a larger one I'm also still kinda learning for the best locations for the camera to actually record some good action. I sure will post a video once I get something done
One thing that is bugging me with the ContourHD is the sound quality - actually the lack of it. I never seem to get any of the engine noises recorded, it's mostly a slight hum on the backround even @ WOT...or maybe the 5.9 just isn't making enough noise?
post #52 of 375 Old 01-23-2012, 11:41 PM
PitchblakToxic7
Does it have a protective casing? I know with the GoPro it has a shatter proof clear case you can put on it that really cuts down on the sound quality. The trade off for better sound is obviously the chance of breaking your camera.
PitchblakToxic7 is offline
post #53 of 375 Old 01-24-2012, 12:26 AM Thread Starter
Timo_90xj
Timo_90xj's Avatar
I do have the shatter-proof watertight casing, but haven't used it yet. Contour seems to be pretty solidly built, and it's splash resistant without the casing. I have been thinking of opening the camera and adding a jack for a 3.5mm mini-plug to use an external mic. I'm pretty sure I saw some "how-to" threads on that somewhere in the mighty interweb..
post #54 of 375 Old 01-24-2012, 10:04 AM
squashman702
1994 ZJ
Snow wheeling looks like a lot of fun. Also, nice work on the crossmember. I assume you're planning on making the skids removeable so that you don't have to drop the crossmember every time you want to do a TC fluid change/remove a driveshaft/etc?
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #55 of 375 Old 01-24-2012, 11:43 AM Thread Starter
Timo_90xj
Timo_90xj's Avatar
Tubes are probably gonna be welded, but I add the skidplates so that I can unbolt them. ..or drill large enough holes. TC skid doesn't need to be that long anyway, only to reach the bottom back hump of it were the drain plug is. Gotta figure out what's the best way, not 100% decided on that yet
post #56 of 375 Old 01-24-2012, 09:29 PM
hotrodjeeper
Im in total drool mode for your fender and bumper work Wanna trade ZJ's?
BUILD THREAD BELOW http://www.jeepforum.com/forum/f197/why-did-you-get-niner-build-1200616/"]http://www.jeepforum.com/forum/f197/why-did-you-get-niner-build-1200616/
hotrodjeeper is offline
post #57 of 375 Old 01-24-2012, 09:37 PM
big_rudy101
New wallpaper.
That is awesome.
"Jeep is America's only real sports car" - Enzo Ferarri
big_rudy101 is offline
post #58 of 375 Old 01-25-2012, 03:35 AM Thread Starter
Timo_90xj
Timo_90xj's Avatar
Originally Posted by big_rudy101 View Post
New wallpaper.
That is awesome.
You can get it in bigger size from my friend's website who was out there doing the work.. I kindly ask you to give him some credit on his work which I think is amazing, and don't post the pictures around elsewhere on the web
Pekka Varis - Kulmakorpi Offroad Park
post #59 of 375 Old 01-25-2012, 09:50 AM
jeep0312
I used it as my background too.
I cant wait till I can make my ZJ look like yours.
-Travis-
2004 Chevy Malibu, red, 2.2 ecotec, shiny wheels, loud stereo
2000 Suzuki SV650N, V-twin, Yoshimura Exhaust, Custom Rashed Paint Job...
jeep0312 is offline
post #60 of 375 Old 01-25-2012, 01:29 PM Thread Starter
Timo_90xj
Timo_90xj's Avatar
Thanks for the compliments guys.. this is still a work in progress. ..and I really bought this to be my daily driver/ tow rig and keep it stock But it's been taking way too long to finish the XJ project so I've had to do some mods to make this a trail- worthy Jeep
Back to business, I did some more work on the tranny crossmember today. I'ts now almost finished as far as supporting the tranny goes. Still gotta figure out a good way to add the tranny/ TC skids to this.
It's a little boxy, but keep in mind the bottom of crossmember is about 1" higher than stock
This ended up looking a little crappy, but who cares - it goes UNDER the Jeep, and I'm not planning on flipping this
Made the passenger side end to have some sideways adjustability:
I don't think I will have problems with smashed bolt heads anymore
daily driver shocks JackStraw ZJ Grand Cherokee Forum 5 02-09-2009 09:57 PM
249=> 242 TC swap in a Daily Driver amonostereo ZJ Grand Cherokee Forum 7 11-10-2008 01:28 PM
Just picked up a newtome daily driver HTOR ZJ Grand Cherokee Forum 13 07-22-2008 05:25 AM
daily driver hitch jshaab2 WK Grand Cherokee & XK Commander Forum 11 01-15-2008 10:46 AM
Daily Driver Shocks apple ZJ Grand Cherokee Forum 21 08-05-2006 09:09 PM
