Daily Driver 5.9 build thread - bumpers, tube rockers, etc.. - Page 3 - JeepForum.com
 5Likes
post #31 of 375 Old 12-29-2011, 12:06 PM Thread Starter
Timo_90xj
Timo_90xj's Avatar
Well guys, you can officially call me crazy Polishing a turdy - or in this case the D44a - is one of those things one really shouldn't do
Anyways, pinion and carrier bearings are toast and pinion seal is leaking slightly on my D44a. So it's time for a re-build. Due to local laws I can't delete the ABS from my ZJ. Hence I can't swap in a Ford 8.8 - especially so 'cause they cost a lot here. So the easiest option is to upgrade the D44a.
I happened to come across a free D44a axle housing that had it's guts removed. Axle is dead-straight, bearings caps are there, and none of the bearings have spun inside the housing. So it's a good starting point.
Things I'm doing:
1. Fab a truss to reduce housing/ axle tube flex
2. Incorporate some kind of system to protect the underside of the aluminum housing. It gets rock rash pretty damn easily
3. Add an aftermarket diff. cover to reduce housing flex
4. Fab new UCA + panhard mounts, beef up/ modify the LCA + shock mounts
5. Install 4.56 gears; if I can find a cheap (free) open carrier I'll add a lunchbox locker. If not, I'll get the LSD rebuild kit.
After that, it should be strong enough to handle what I use it for. A lot of work? Maybe, but I don't care. At least I get some time spent in the garage instead of working outside on the rain building my house
I have a spare HP D30 in the garage, so I'll do something similar to it: fab a basic truss, add a heavy duty diff. cover, 4.56 gears + Eaton e- locker. I've also had WJ- knuckles and brake parts sitting in my garage for about two years, so they'll be swapped in as well.
***Under construction***
Timo_90xj is offline
post #32 of 375 Old 12-29-2011, 06:33 PM
MilanJeep
MilanJeep's Avatar
Damn! DDing a 5.9 with European gas prices...you must be rich lol
98 5.9 ZJ - 4.5" lift, 33x12.50 MT/R Kevlars
02 Z06 - Supercharged, E85, lots of rwhp, built and tuned by me
Milan
MilanJeep is offline
post #33 of 375 Old 12-30-2011, 01:54 AM Thread Starter
Timo_90xj
Timo_90xj's Avatar
Yeap.. at the moment it's around 7.50-7,70$/ gallon (1.50-1.55/ litre) ..and people wonder why I do some of my commuting by bus and metro
post #34 of 375 Old 12-30-2011, 06:12 AM
melk
I love the recessed winch and front skid.
Custom fab ftw!
melk is offline
post #35 of 375 Old 12-30-2011, 09:44 AM
jeep0312
Keeping an eye on the D44a build. I'm keeping mine and need to build it up.
-Travis-
2004 Chevy Malibu, red, 2.2 ecotec, shiny wheels, loud stereo
2000 Suzuki SV650N, V-twin, Yoshimura Exhaust, Custom Rashed Paint Job...
jeep0312 is offline
post #36 of 375 Old 12-30-2011, 06:17 PM
mtnmarc
Originally Posted by Timo_90xj View Post
i realllllllly like how much the winch doesnt stick out. i hope to be that close when i build my bumper.
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline
post #37 of 375 Old 12-30-2011, 07:14 PM
98zjkidd
Did u really cut up that niner grill??
98zjkidd is offline
post #38 of 375 Old 12-30-2011, 11:26 PM Thread Starter
Timo_90xj
Timo_90xj's Avatar
Well, how could I stick a standard grill in there, wouldn't look like a niner then
My reasoning was, since I recessed the winch so deep in there and did all the mods in the front I'm not needing the grill as it came from factory. Yeah, hurt a bit doing so, but I tried doing this so the niner looks as good as possible
post #39 of 375 Old 01-15-2012, 10:34 AM Thread Starter
Timo_90xj
Timo_90xj's Avatar
Rear truss starting to take shape..
post #40 of 375 Old 01-15-2012, 01:41 PM
nicklopic
...I love this zj
really interested in what you're doing with your D44a
98' ZJ 4.0
4.5" short arm, 33" Courser MXTs, custom stubby bumper, skids, someother stuff
nicklopic is offline
post #41 of 375 Old 01-16-2012, 10:49 PM
big_rudy101
That looks awesome man. Nice work! Superrrrr jealous!
"Jeep is America's only real sports car" - Enzo Ferarri
big_rudy101 is offline
post #42 of 375 Old 01-18-2012, 07:45 PM
Dyn0mitemat
Love the tube work.
Just an FYI but its fairly easy to get abs working with an 8.8 (mallcrawlin has a writeup), but if they're too hard to find there then thats cool. Nice to see someone give some love to the aluminum (is it alum-inum, or alu-minium? )
09 Rubi 2dr:MetalCloak2.5", 37"MTZ's/Slabs, EVO Stff, ORFab Cage, Chromo's, Driveshafts etc
Dyn0mitemat is offline
post #43 of 375 Old 01-22-2012, 01:33 AM Thread Starter
Timo_90xj
Timo_90xj's Avatar
We went snow wheeling yeasterday, it was a lot of fun. Then again, wheeling in winter makes things that little bit harder and way more different, and all sorts of things can happen on the slippery trails.
Whoops
Which results in this The damn 31" BFG AT (didn't have my own spare tire with me ) made things a lot more difficult, without a front locker I really wasn't moving anywhere after this. Difference in grip was huge between a 32" BFG MT and the AT..
It was left rear that punctured, but I had to swap the smaller AT to the front and my left front to rear, so when I got out of the trail I removed the front DS and drive back home in RWD.. In this case, I wish I had a 242 or 231.. This is the biggest downside of an AWD transfer case.
post #44 of 375 Old 01-22-2012, 10:42 AM
squazz
awesome skillz
squazz is offline
post #45 of 375 Old 01-22-2012, 11:32 AM
PolkaPower
Or just carry your spare
Do you listen to any of that Black Metal like Sentenced or Purtenance?
PolkaPower is online now
daily driver shocks JackStraw ZJ Grand Cherokee Forum 5 02-09-2009 09:57 PM
249=> 242 TC swap in a Daily Driver amonostereo ZJ Grand Cherokee Forum 7 11-10-2008 01:28 PM
Just picked up a newtome daily driver HTOR ZJ Grand Cherokee Forum 13 07-22-2008 05:25 AM
daily driver hitch jshaab2 WK Grand Cherokee & XK Commander Forum 11 01-15-2008 10:46 AM
Daily Driver Shocks apple ZJ Grand Cherokee Forum 21 08-05-2006 09:09 PM
