Daily Driver 5.9 build thread - bumpers, tube rockers, etc.. - Page 15 - JeepForum.com
 4Likes
post #211 of 374 Old 06-22-2013, 12:56 PM Thread Starter
Timo_90xj
Timo_90xj's Avatar
Thanks! And fear not, my ideas are free to be used. Preferrably with a little personal twist though IMO that's how we make things evolve on our hobby, look at other people's ideas and make something better out of it using our own
***Under construction***
Timo_90xj is offline
post #212 of 374 Old 07-27-2013, 08:14 AM Thread Starter
Timo_90xj
Timo_90xj's Avatar
I broke the HP D30 - again. That piece of crap just obviously isn't up to the task withe 5.9, 4.56s and 32s... Eaton e-locker took a dump, r&p is ruined, carrier bearing caps are gone, housing has deep gouges, pass. side bearing cap mounting bolt hole threads are damaged and the end is crushed.
The cromo- shafts I installed past winter are ok, but the long side shaft is severly stuck inside the case, I need to cut the case into pieces so I can use a bottle jack to press out the shaft. Housing is ruined anyways, so I don't really give a crap of causing more damage to it. Time to build a HP D44/ D30 hybrid. Can't install a non- abs D44 or a wide track axle like a JK D44 to my Jeep due to local laws.
I'll post some pics of the carnage later..
post #213 of 374 Old 07-27-2013, 10:51 AM Thread Starter
Timo_90xj
Timo_90xj's Avatar
Typical D30 gear deflection right there?
..suprise, ended up in a tooth fairy paying a visit:
I'd say that ring gear doesn't look right, does it?
This was right about the exact moment when the front said boom. I really don't get it - on 4lo, front locker engaged, not jumping, engine turning @1500rpm. What the hell, a full case locker broke right there!?
post #214 of 374 Old 07-27-2013, 01:03 PM
CRJEeP_wj
That sucks. I'm kinda shocked there was so much damage. What's the plan for the front now? A cut to fit 44 with abs?
02 grand cherokee, hp60 14b, 42s. Stazwork, triangulated 4-link, rear leafs, homemade bumpers and sliders. build thread
CRJEeP_wj is offline
post #215 of 374 Old 07-27-2013, 01:21 PM Thread Starter
Timo_90xj
Timo_90xj's Avatar
Yeap, most likely HPD44/ 30 hybrid. In other words, DIY TJ rubi front axle. It's gonna take some time though..
post #216 of 374 Old 09-08-2013, 04:42 PM
Geo-Nemesis
great build, even greater fab skills!
sorry to hear that your custom hp30 blew up!
'02 Black Overland H.O. V8
Geo-Nemesis is offline
post #217 of 374 Old 10-21-2013, 06:10 PM
chadcmb
LIKE^^ all of it.
98 ZJ, 231 3-4 inch lift 31/10.5/15 Hankook Dynapro MT w/Plastidip rims. V8 5.2L 208K+
Warn M8000
chadcmb is offline
post #218 of 374 Old 10-22-2013, 11:36 PM
Jeepforthewin
2010 JK Wrangler
Any Updates on the front end? Just read through the thread and I am amazed and all I can say is wow! Alot of time put into this project and from your plans it sounds like it will be unstoppable soon enough!
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #219 of 374 Old 10-23-2013, 12:40 AM Thread Starter
Timo_90xj
Timo_90xj's Avatar
Nothing done yeat, getting the parts first. It's not a quick build because of the current house- building project going on.. money is tight as you can guess
It will be a HP D44 with 3" x 3/8" wall tubes with a .250wall DIY truss (trying to save a couple of lbs of weight there with the thinner tubes), locked (eaton e- locker), gussed D30 inner Cs with the WJ knuckles & brakes/ OTK steering I've got on the turdy at the moment. I would've went with a Ford narrowed-to-stock-ZJ-width true HP D44 with rebuildable hubs, but the ABS system would be a pain to fit on those.. unfortunately it is needed here to keep my ZJ road- legal.
post #220 of 374 Old 10-23-2013, 01:26 AM
Jeepforthewin
2010 JK Wrangler
That is true haha and I Can't wait to see this!
post #221 of 374 Old 01-03-2014, 09:39 AM Thread Starter
Timo_90xj
Timo_90xj's Avatar
Still aquiring parts for the front axle, it's been a (very) slow progress..
In the meantime, I've installed a new VDO PM9069 e-fan motor after the original fan failed. Since it's been fairly cold here, I was able to drive to work and back without the e-fan functioning - only about a 10 mile drive with couple red lights and rest is 35-55mph flowing traffic. I had a slight issue with the power feed (supply connector to the e-fan circuit below the PDC had melted). Now it works perfect
My front hubs have steadily developed a grinding sound, eventually it was so bad I had to order new unit bearings. Gonna be installing them next week. If that wasn't enough, my starter motor failed I looked for a new one locally - a big no. Aftermarket new ones ranged between 199-289 (that's ~270-400$ ); I saw that Rockauto was offering OEM Mopar starter motors on a closeout for 49 + 51 for Fedex 2-day guarantee express shipping. I'm getting it on Tuesday
I had to see what had failed on the old starter motor, since the solenoid was good. Aftermath of using brake cleaner to clean up all the crap
..and the obvious reason for the non-working starter; it had been pretty weak for the past year, one of the brushes was totally seized. One of the rest of the three was too short to properly touch, and some of the internal wiring below the brushes were VERY badly corroded.
post #222 of 374 Old 01-06-2014, 11:23 PM
MurdaJs
Why is there barbed wire on your toilet? Lol
MurdaJs is offline
post #223 of 374 Old 01-07-2014, 12:25 AM Thread Starter
Timo_90xj
Timo_90xj's Avatar
Funny how everybody asks that.. it's all inside the transparent plastic lid. Me or the wife don't like sitting on barbed wire
post #224 of 374 Old 02-10-2014, 11:27 AM Thread Starter
Timo_90xj
Timo_90xj's Avatar
Nothing big has been going on, I'm still gathering parts for the HP D44/ D30 hybrid. Actually, I'm pretty much at the starting point, trying to find suitably priced HP D44 center section out of a '78-'79 F250 on eBay from someone who is ready to ship it overseas. Not an easy task
In the meantime, I ordered a starter kit of Delphi Weatherpack connectors with the crimping tools. 75$ + overseas shipping, ended up costing me about 100$ + 24% VAT (= ~100 i my currency). I'm pretty happy, those connectors are OEM quality and there are a lot of them.
I also pulled out my stock rear springs and the 1.75" BB blocks, and replaced with (used) stock ZJ I6 front coils. With the fairly heavy hitch and gas tank skid, I got about 2.5" of lift from the used coils. Pretty happy, now the rear sits at the same height as front with 1.75" BB blocks and modified axle coil buckets (they give me about .75" of lift).
post #225 of 374 Old 02-10-2014, 04:22 PM
kg6mov
Hears the voices
kg6mov's Avatar
How do those coils ride?
kg6mov is online now
daily driver shocks JackStraw ZJ Grand Cherokee Forum 5 02-09-2009 09:57 PM
249=> 242 TC swap in a Daily Driver amonostereo ZJ Grand Cherokee Forum 7 11-10-2008 01:28 PM
Just picked up a newtome daily driver HTOR ZJ Grand Cherokee Forum 13 07-22-2008 05:25 AM
daily driver hitch jshaab2 WK Grand Cherokee & XK Commander Forum 11 01-15-2008 10:46 AM
Daily Driver Shocks apple ZJ Grand Cherokee Forum 21 08-05-2006 09:09 PM
