Daily Driver 5.9 build thread - bumpers, tube rockers, etc.. - Page 14 - JeepForum.com
 4Likes
post #196 of 372 Old 03-27-2013, 03:25 PM Thread Starter
Timo_90xj
Timo_90xj's Avatar
Got my steering box rebuild going on again, now that I finally received the seal & bearing kit. A bunch of stuff to figure out where they go..:
..This is how the box came out (you can't see the hydro assist ports, but they're there):
..and this how things looked after two minutes when I started filling the power steering pump and bleeding the system
It wasn't too hard to find from where the PS fluid poured out; sector shaft seals had been pushed out for some reason - but I don't understand why. All the seals where there, in right order and right way round, both washers where there, snap ring was installed and I also double-checked the sector shaft endplay.. weird.
***Under construction***
Timo_90xj is offline
post #197 of 372 Old 03-28-2013, 10:18 AM
bananaslug
no one wants to do that once let alone twice!
still daily driving the ZJ?
bananaslug is offline
post #198 of 372 Old 03-28-2013, 10:44 AM Thread Starter
Timo_90xj
Timo_90xj's Avatar
Yeap, still daily driving - although I've lately been going to work a bit more using metro and bus... 1.65-1.75/ liter (~8$ a gallon) gas prices are a bit on the high side to daily drive a vehicle that only gets ~13-15mpg during winter
Snap ring had failed, but I don't really know the primary reason for this happening. I double checked what I had done, and everything was exactly the way they're supposed to be. Second try now, if it blows up again then I really don't know what the heck is going on..
post #199 of 372 Old 03-28-2013, 12:18 PM Thread Starter
Timo_90xj
Timo_90xj's Avatar
2nd try with the box and now everything held together, at least all the way from garage to my home (~10 miles). This was a MAJOR improvement in steering power, and also all loose feeling is now gone. I don't know where the old box had lost it's power since I'm running the exact same pump and & pulley with this one.. With the XJ pitman arm the steering angles are now spot-on, and draglink isn't hitting the tierod no more.
I do have to adjust the steering "tightness" a little, at the moment it's one finger steering with close to no feel at all.. Good thing cops didn't see me driving home, they probably would've thought I'm wasted
Apart from that, this was a big improvement over the old worn steering box.
post #200 of 372 Old 03-29-2013, 03:55 PM Thread Starter
Timo_90xj
Timo_90xj's Avatar
Well, steering box worked at least for now
post #201 of 372 Old 03-29-2013, 05:24 PM
Dyn0mitemat
Originally Posted by Dyn0mitemat View Post
Box looks good, I had mine out over the past summer to replace the seal right above where the pitman arm mounts, and decided to drill/tap for hydro then, not too difficult.
I do have a tad bit of play in it though, I wouldn't mind picking a junkyard box up and rebuilding it. I remember when I looked to do my last one there wasn't much out there for rebuild kits, or guides/layouts for rebuilding the box. If you found any of that online and sure many others along with myself would appreciate where you found it
Looks a bit too nice for a steering box, not that thats a bad thing though haha
Any chance you have any info on rebuilding that box? Where'd you get the rebuild kit, and you any links on a how-to on rebuilding it? Thanks
09 Rubi 2dr:MetalCloak2.5", 37"MTZ's/Slabs, EVO Stff, ORFab Cage, Chromo's, Driveshafts etc
Dyn0mitemat is offline
post #202 of 372 Old 03-30-2013, 12:30 AM Thread Starter
Timo_90xj
Timo_90xj's Avatar
I believe I got the seal & bearing kit from Rockauto (Gates version), it was a friend of mine who actually ordered the kit though. I've got to check the number on the box though, since the pic on Rockauto for the Gates kit only shows it has seals but no bearings, and the one I got had new bearings as well.
Used these as a guide for the rebuild:
* http://www.jeepforum.com/forum/f13/h...-gear-1287129/
* http://www.fourwheeler.com/techartic...d/viewall.html
...and this for drilling & tapping the hydro assist ports:
* http://www.pirate4x4.com/forum/gener...ic-thread.html
post #203 of 372 Old 03-30-2013, 03:08 PM Thread Starter
Timo_90xj
Timo_90xj's Avatar
My Easter Jeep Safari was like this In other words, with the 4- days off from work I've got some good time to work on the TC issues I have. I'm mating the 242 from my '90 XJ to the 249 from my ZJ.
249 has been making a grinding noise for quite some time now, I've been suspecting bearing failure. I changed the TC fluid about 4k miles ago, now that I drained it it was fairly red, but all metal-flaky. Weird thing is I didn't find anything obviously wrong with the 249 when I dismantled it. Chain was a bit stretched and "wiggly", but it hadn't made contact with the case and all the bearings etc. seemed to be fine.
I will use these from the 249:
* Front case half with the stationary planetary gear
* Input shaft + plantery gears for the 4wd
* Electronic speed sensor
* Mode switch
* Random other parts that are in better shape than with the 242
From the 242:
* Rear case half + tailhousing + main shaft
* Planetary gears for the 4 full time
* Chain sprockets; I'll be buying a new chain.
I will buy new input and output bearings; all other bearings were in very good condition so I'm not gonna start replacing them now.
My idea was to use the wider 1.25" chain & sprockets from the 249 to replace the narrower (7/8" or 1" whatever the chain is) ones on the 242. Problem is - even though the splines match on the main shafts - the wider sprocket cannot be used on the 242 because the lockring groove is covered by the thicker sprocket. Shame, since the wider chain would've been a lot more sturdy compared to the narrow chain on the 242.
249 unbolted from the ZJ:
242 (it's got a hack 'n tap SYE) with the 249 behind:
242 with the case split open, and some of the internal parts:
..this shows how big a difference there is between the sprockets on the 249 vs. 242:
post #204 of 372 Old 04-10-2013, 11:36 AM Thread Starter
Timo_90xj
Timo_90xj's Avatar
I needed to adjust the front & rear bands on the tranny, my 1-2 shifts have lately been really slippy. I also need to replace the tranny speed sensor and governor pressure solenoid (I will replace all the solenoids actually), but that's a different story.
I don't have the 5/16" square head socket that is needed for the adjustment, nor could I find it anywhere in here. So I had to do some DIY fabbing to get the tool required
I used a 1/2" -> 3/8" adapter and a 7mm open- end wrench that I enlarged and "squared" the bottom edges to 5/16" (7.5mm). I then welded the wrench to the adapter, then cut off the handle, and rewelded part of it to make my DIY socket a box- end 5/16". I now have a tool that fits to the front band adjuster without the special tool normally needed for the job
I had the transfer case halves glass bead blasted (only cost me a dime really, 30 which is under 40$). I must say they came out really good, I know have a perfectly clean and rough enough surface for a primer to grip even on aluminum.
..primer applied, tomorrow I'll paint the first coat of silver aluminum- look paint on it, second coat on Friday. Should end up looking nice and stay cleaner a bit longer than unfinishied aluminum I should get the drive chain from Rockauto on Friday afternoon (FedEx again provided me with a really fast international shipping, three days ), so I should be able to assemble the case during weekend to test how it works.
I noticed Tom Wood's is coming out with a true 242 HD 32-spline rear output SYE within two months (or that's what they say ), I may be upgrading to that when it's available. I really don't trust the 27-spline hack 'n tap SYE with only about 1.5" of spline engagement on the rear output and a 1" wide chain. Too bad used 242 HDs cost a fortune over here, I would've loved to adapt a WJ 242HD onto the ZJ..
post #205 of 372 Old 04-12-2013, 02:02 PM Thread Starter
Timo_90xj
Timo_90xj's Avatar
Looks pretty good after two coats of Hammerite silver hammer effect paint. Maybe a bit too show- truck like? Oh well.. I'll let the TC dry overnight and I'll assemble it tomorrow. If all goes well, I will also install it tomorrow.
Bearings and front output seal look like crap becauseI hammered the old ones back in for the glass bead blasting to protect the machined bores.
I added a drain plug to the tranny oil pan, it sucks not having one in there. Almost managed to keep the pan from twisting out-of-shape when I welded the plug in there. It's only ~1/32" off so I'm sure it will not leak after the bolts are torqued to spec. I'm using reinforced rubber gasket which should help keep things clean.
I also pounded the pan back into shape with a piece of 4 x 4 lumber and a 15lbs hammer. I smashed the pan into a big tree trunk about 1 years ago, it made a nice 1/2" dent to it I rattle- canned it satin black so it looks like new again
post #206 of 372 Old 04-12-2013, 03:22 PM
bananaslug
Damn, that looks good when compared to the dirty one above.
From the pictures above, I cant tell if your undercarriage is coated in salt or its just the photo effect.
post #207 of 372 Old 04-13-2013, 12:42 AM Thread Starter
Timo_90xj
Timo_90xj's Avatar
It is mostly due to the effect of the HDR technique, but road salt is used quite extensively here so the vehicles are greyish-brownish all winter when it's even slightly wet. Good thing there is a good amount of rubbery undercoating on my Jeep, it won't get rusty that easily
post #208 of 372 Old 04-16-2013, 02:45 AM Thread Starter
Timo_90xj
Timo_90xj's Avatar
I continued with the TC rebuild on Saturday.. got it back together by ~9:30PM only to find out there was well over 1/2" of end-to-end play on the mainshaft. That of course is no good thing, modes won't work properly and the TC wouldn't really take that beating too long. Got tired of popping the case open again, so instead I popped a couple of beers and went home. I spent most of Sunday cutting aerated concrete blocks at our house construction site so I didn't really have time to work on the TC. Yeasterday I starting looking for the reason of the problem, I was suspecting a missing lockrink or snapring. Thank god it was exactly that, and it was the rearmost one that I forgot so it was only about a 30min. job getting the TC to function prorly - including scraping off the RTV and reapplying it
Next thing was shortening the rear output yoke, I'm switching to a fixed yoke with the slip joint in the rear DS. I drilled a 10mm hole through the endplate on the yoke, used a 10mm bolt & nut and secured it on my drill press so I could cut a straight line with the angle grinder. DIY lathe?
TC rebuilt & yoke installed; this package is roughly 5.5" shorter from TC mounting face to u-joint center compared to the 249 with the slip yoke in middle of the travel. Quite a big difference!
I'm still missing the yoke bolt, I accidentally used 9.5mm drillbit, and the 3/8" fine thread bolt won't fit through. Gotta enlarge the hole to 10mm.. ..and I know, my DIY output yoke is not exactly ideal since I need to press in the u-joint when under the vehicle and install the snaprings. It surely sucks, especially if I brake a joint or shaft when wheeling. The reason for temporary using this is I simply cannot find a 27-spline/ 1330- series fixed yoke with strap or u-bolt style mount anywhere. There are 26- and 32- spline versions, and there are 27-spline 1310- series fixed yokes. I do not want to run a 1310-1330 conversion joint on the rear DS, especially now that I've got RWD and all the torque goes to rear.
Spicer 2-2-949 is a suitable flange yoke that I could use with the existing rear output flange I have from the RE hack 'n tap kit. Spicer 2-2-949 is a 1330- series yoke flange and it has the smaller 4 x 3.5" BCD and all the other measuremnts match to the flange. The only problem is that it costs a whopping 80-90$ + international shipping + local import taxes + VAT = too expensive IMO. I make do with this until Tom Wood's comes out with the true 242HD SYE kit ina couple month that uses a 32-spline main shaft etc... it's gonna be fairly expensive though, so I don't know if it would be a better idea to try find a used WJ 242HD instead - it would at least have a 1.25" chain instead of the weaker 1" chain the XJ and ZJ 242s use.
post #209 of 372 Old 06-04-2013, 12:38 AM
kg6mov
Hears the voices
kg6mov's Avatar
Gotta watch this, amazing looking jeep.
kg6mov is offline
post #210 of 372 Old 06-22-2013, 11:11 AM
PitchblakToxic7
You're ZJ is one of the largest influences I have in working on mine, now that I have a second car and a welder, I hope to steal some of your ideas and see what I can make of mine.
Awesome rig.
PitchblakToxic7 is offline
daily driver shocks JackStraw ZJ Grand Cherokee Forum 5 02-09-2009 09:57 PM
249=> 242 TC swap in a Daily Driver amonostereo ZJ Grand Cherokee Forum 7 11-10-2008 01:28 PM
Just picked up a newtome daily driver HTOR ZJ Grand Cherokee Forum 13 07-22-2008 05:25 AM
daily driver hitch jshaab2 WK Grand Cherokee & XK Commander Forum 11 01-15-2008 10:46 AM
Daily Driver Shocks apple ZJ Grand Cherokee Forum 21 08-05-2006 09:09 PM
