As some may notice from my signature, I'm building an XJ that has Unimog 404 portal axles, 42" Pitbull Rockers, full cage, etc.. My ZJ is the tow rig and my daily driver so I don't want it to be overly built.
Being a Jeep guy, I can't resist taking my ZJ out on the easier trails sometimes. So it needs to be built so that it can take some rock rash without trashing the body panels. Finally had the time to start building it to better suit my needs for a "sunday wheeler".
I bought the ZJ last July, in absolutely mint condition. Zero rust, ~90k miles, all original. I couldn't keep it like that for too long, so I added 2" budget boost, longer shocks, some fender trimming and 32 x 11.50 BFG KM2s.
I drove it like that for the winter, and wheeled it occasionally..
..until spring came and I had time to start building it
First thing to do was to cut out the rockers and weld in box tube rockers. I had some minor rust on the inside of the rockers:
In contrary to my XJ, I used slightly thinner wall box - only time will tell how the hold up. I used 2" x 4" .188" wall box tube. Cut one in hald and welded it to the other two -> end result is 2" x 6" rockers:
..then started on the front bumper. It's a 100% weld-in, non-removable pile of tube and metal plate.
First extended and strengthened the front horn some (2" x 4" box steel, 3/16" wall):
..add a tube in between:
Then started on the new radiator support/ crossbar thingy:
..add some more tube..
..and it's done:
..well, it's not entirely done. I need to add a winchplate on top, and also something to protect the lower part of the A/C condenser and radiator. It's pretty easily damaged that way
..finally, the rear bumper. I wanted more room behind the rear wheels, and something stronger to hit when coming down from a high ledge or rock. So I started tearing in to the rear part of the ZJ..
..and out come the 4.5" cut-off wheel, some tube and the bender
Add some 1/4" plate:
..add some more 1/4" plate with relief cuts and bend it around the corner..:
..add a little paint and some other stuff and it starts looking like a bumper..:
This is where I'm at right now. I need to have the rear bumper ready by tomorrow night, gotta go wheeling on Sat. morning starting at 10AM
Rear ended up looking like this, I need to add another tube between the corners and some plating to tie it all in. Other than that, it's ready.
Held up to some beating on the trails pretty damn well, dropped the passenger side rear corner from about 2ft. straight into a rock - not a scratch. Had I had the stock exhaust and rear corners, I would've trashed at least the exhaust and the rear light, propablly something more than that as well
Stuffs 32s pretty nicely: :thumbsup:
Came out pretty well IMO.. I'm happy with the end result. I do need to add some skid plates on the belly, I put a big dent on the tranny oil pan. Whoopsie..
Tubing is mostly 1.75" OD .120" HREW, front cross-tubes are slightly bigger at ~1.9" OD (48mm, metric- standard tubing). Plating is between .120" -> .250" depending on the area. Rear corners are thickest, front tube fender panels are .120 :thumbsup:
As mentioned, I'm gonna add belly and gas tank skids. Probably will also weld tubes to the rockers the protect the doors a little more, and also for the ability to "swing around" rocks using the tubes.
I need to figure out a good way to mount my hitch - living in the EU, it has to be ECE/ e-code approved so I can't fab my own. On the other hand, I do have my old hitch which has the approval plate, I may just pop- rivet that plate to a DIY- hitch so it passes inspection and possible road-side checks by the local police
edit: Oh, the stock CAs will have to go. I haven't even been doing any serious wheeling with my ZJ, but both front lowers are bent, and one of the uppers is trashed as well. Looks like I'm starting to develop some DW issues too, which I think is the result from the bent CAs and over-flexed ball-joint end of the stock track bar. Need to address those issues as well. ..and I thought to keep this 100% stock when I bought it :rofl: :nuts:
Finally also added side tubes to protect the doors a little better. They stick out from the rockers about three inches, so I should be able to use them as a pivot point in rocks without damaging doors :thumbsup:
I would've loved to do boatsides, but as long as this is my DD this will have to do
Damn dude, you are on a roll! Those front fenders are exactly what I need to install for a little protection, plus to remain legal. All the tube work looks great. You sure are wheeling your DD pretty hard for not wanting to build it up haha.
Thanks :thumbsup: Yeap, the road legality issue was the reason for fabbing the front tube fenders - and of course protection when wheeling. Local laws here in Finland require the tire tread to be completely covered by fenders, sidewall may stick out.
I actually think the whole outer tubework came out pretty nice. I still need to finish both front and rear bumpers. Also, the more I look at the section at rear doors missing the tube, the more I think I gotta fill that gap with tube The problem is, if I do so I gotta hack rear doors and re-weld them :thumbdown:
I haven't been doing anything too serious with the ZJ and intend to keep the body in good shape, but the stock CAs clearly can't take any abuse :laugh: Bending the tranny oil pan was purely my mistake, I sorta forgot I was driving such a low vehicle when going over a rocky section on a trail :shhh:
The front tube fender sheetmetal is stitch-welded or full-welded to the front wheelwell (depending on the area) all the way, and the bottom part to the a- pillar just in front of hinges. There is also one 1.75" OD tube in the middle going from the tube to the wheelwell close to wear the coil tower is. Third tube support is right below headlights, going from the tube to the front unibody frame stiffeners. I think that should be sufficient, and it feels very solid. I've already hugged a few trees with the fronts and they didn't budge
Welder would be a nice birthday present :thumbsup: If talking about working on Jeeps, mig-welder and drill press have been the most important tools I've bought so far - along with the tube bender
I finally had time to finish my front bumper last week - it's pretty much done now, I only need to add the plate for a hawse- type fairlead. That same plate will be used for mounting my licence plate, for some reason cops don't like it my front plate is hidden behind the bumper
No need to mention I need a front locker The HP D30 I'm building for this will have one, also WJ knuckles & brakes, prob. OTK steering etc..
Bumper now looks like this:
..also had time to go test it and do some wheeling, friend came along to snap a few pictures.. He actually took well over 1200 pics in about 6 hours we were wheeling Enjoy!
nice looking rig man. love the bumpers and rails, i'd have to tie in the rear to the rails, that gap bugs me. Why couldnt you drop the tube a little to clear the doors?
And a set of tube/half doors would look sweet as well, if the EU regs would allow them.
I will fill the gaps on the rear extending all the way down to the rocker tubes :thumbsup: Just haven't gotten any spare time to do that yet, and I also ran out of tube. I didn't really want to drop the tubes any lower because I wanted as much room as possible to stuff the rear tires inside the wheel wells. On the other hand, that means I now have to cut little slices off the rear doors and re-weld them. This Jeep being my daily driver and the tow rig, it's kinda stupid :nuts: :rofl:
Tube/ half doors are legal here so no problem with that, but it's my DD so I don't wanna go that far with this build. I've got the XJ build going on which will be a full-on wheeling rig once finished :thumbsup:
Finished the front bumper; drilled/ cut a hole for the hawse, welded the plate in, bolted in the winch, fabbed new cables, wired the winch in/out switch to the cabin, and tested.
I had to fab the cables because my winch solenoid box took a dump - it decided to short- circuit, burning the winch motor, melting the cables and started a fire under the bonnet That was when the winch was mounted on my XJ though
I did not get another standard-style solenoid box, but replaced it with a Superwinch sealed "super-small" solenoid box. I used 35mm^2 ( ~2AWG cable in US- standards) cable for the electric connections, which should be thick enough. Longest cable is only ~5ft. long so I should see about 5% voltage drop under maximum strain. No big deal. I wired the switch to spooling winch in/out to the cab, it's easiest to use from there.
I'm pretty happy with the overhang (less than with stock bumper), winch does block the airflow to the radiator a little, but it's no problem here were I live. I also drilled a few more holes to the front skidplate to allow for more airflow to the radiator :thumbsup: But enough BS, here are a few crappy cell phone pics.. Gotta go test it tomorrow, it's been raining all week so I'm pretty sure there a lot of mud everywhere
I really like how you cut the grill and recessed the winch back in farther, looks great! On a side note, you just helped me make up my mind on going to the euro front signals, looks 100x less "ricey" and way more classy! :thumbsup:
Snapped the shaft in a pretty easy spot, a small rock step where I had to bump both front and rear tires up at the same time with some momentum. *CRUNCH* :laugh: Did a 45 minute replace job at a friends garage, he happend to have a spare CV- shaft. Time to get alloy u-joint shafts.
I always cringe when I see people tearing into a Niner, but your tube fenders look great!
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
