Custom LED license plate lights? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Custom LED license plate lights?
ZONE 4.25" combo lift for TJ available at Rockridge4wROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail ANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete
Unread 05-09-2010, 05:17 AM   #1
HondaPeople
Both of my license plate lights have burned out. I took the lens off and noticed the burned out bulbs were melted into the bulb socket. So... has anyone clipped the wires and added an LED light in place of the stock light? Just curious. Since I was pulled over because an officer could not see my license plate, it's something I am going to do very soon. Thanks!
2011 Dodge RAM 1500-HEMI, 2001 WJ Laredo-V8
2008 Honda Recon ES 4x4, 2006 Honda Lawn Mower, 2001 Honda VFR800
HondaPeople is offline   Reply With Quote Quick reply to this message
Unread 05-09-2010, 10:49 AM   #2
00JGC00
Yep! Same thing happened to me. You don't need to clip the wires though. What I did was found another JF member who was parting out a WJ and he sent me the whole wiring harness that just plugs in. I ordered some of these (below) and then tried them on my existing partially melted sockets and they still worked so I have a spare license plate socket harness now. I love the LEDs because they don't get hot enough to hurt anything.
Look on eBay for white LED 194 bulbs and there are a ton of different styles. I tried a few of the really cheap ones and these put out the best/most light. There are brighter better ones, but for the money I say these are the winners.
I see you're from Utah. What part?
"The" Matt | '00 Limited WJ | "The White Wolf" aka "Willow" aka "Cool Whip" aka "Sweet 'N Low" aka "AKA"
Utah JeepCrew #39 | Club Matt #1
December '11 GCOTM | Build: http://www.jeepforum.com/forum/f197/life-times-979511/
00JGC00 is offline   Reply With Quote Quick reply to this message
Unread 05-09-2010, 11:29 AM   #3
RedRock527
superbrightleds.com has a lot of LEDs to choose from also. I ordered some Blue wedge base 194's for my license plate lights just the other day. They should be here Monday or Tuesday.
I believe superbrightleds also sells the actual sockets too.
Super Bright LEDs - LED Accessories & Motion Sensor Lights
RedRock527 is offline   Reply With Quote Quick reply to this message
Unread 05-09-2010, 07:48 PM   #4
HondaPeople
Thank you all for your information! I appreciate it!
Unread 01-23-2013, 08:26 PM   #5
WJunkie
LEDs
Do the LEDs you linked on Amazon plug straight into the standard housing or is a new socket needed?
WJunkie is offline   Reply With Quote Quick reply to this message
