Construction of my ZJ and greetings from faraway Russia - Page 9 - JeepForum.com
post #121 of 153 Old 10-04-2013, 10:04 AM
970001zj
Originally Posted by madelk_RUS View Post
Installed windshield
i need to do this sometime , was it very difficult ?
came the cooling fan
this is the next step i took after i installed the electric fan i think you should try it
the electric fan and durango air hat work very well together and make a noticeable difference in power
970001zj is offline
post #122 of 153 Old 10-11-2013, 02:19 AM Thread Starter
madelk_RUS
what's the advantage of the top Durango, compared with the original top?
madelk_RUS is offline
post #123 of 153 Old 10-11-2013, 04:40 AM
970001zj
a lot of air flow
970001zj is offline
post #124 of 153 Old 10-15-2013, 12:31 AM Thread Starter
madelk_RUS
a lot of air flow
Thank you! but here in Durango prakticheki not drive around the city))
You can Popras part number?
yesterday reinforced front side members and wheel mounting machine.
post #125 of 153 Old 10-18-2013, 12:26 AM Thread Starter
madelk_RUS
post #126 of 153 Old 10-25-2013, 12:10 AM Thread Starter
madelk_RUS
held all the brake lines, removed the ABS unit and installed raspredilitel braking forces from the Cherokee
made Panhard rod mount amplifier
manufactured to insert the temperature sensor (to turn the fan)
scalded cover bridge
post #127 of 153 Old 10-28-2013, 01:07 AM Thread Starter
madelk_RUS
set the oil temperature sensor in the automatic transmission
and made the drain bolt out of the bath
post #128 of 153 Old 11-29-2013, 01:39 AM Thread Starter
madelk_RUS
bought suspension travel stops
purchased and installed tow loops from Hammer
produced a large area under the battery
fabricated hatch to replace the fuel pump
post #129 of 153 Old 12-01-2013, 01:53 AM Thread Starter
madelk_RUS
did handbrake
collected Front Axle
established hubs (milli marker)
installed fog lights
otgruntovali otkrasili and front bumper (just to avoid rusting )
Install the front bumper
completed the pad under the battery
changed the terminals on the accompaniment and crimp the wire again ( pics so far)
filled new antifreeze
tubes changed Transmission
Rubicon stickers pasted ) )
gathered front panel cabin and found one chair ( to be able to move )
made on the bumper bracket for rooms
poured oil in the front axle and installed KRYZHKOV Difa (more precisely in the reverse order )))
collected before the frontal panel and installed wipers leashes
Well, put the wipers
first full test was successful ) )
left to put stabilizer
without it, the car is very rolls cornering
post #130 of 153 Old 12-02-2013, 02:24 AM Thread Starter
madelk_RUS
post #131 of 153 Old 12-08-2013, 11:55 AM
RedZJ
looking good! Really liking the bumper..
RedZJ is offline
post #132 of 153 Old 12-22-2013, 11:16 PM Thread Starter
madelk_RUS
painted all the levers and drive
post #133 of 153 Old 12-30-2013, 04:32 AM Thread Starter
madelk_RUS
post #134 of 153 Old 02-10-2014, 10:40 PM Thread Starter
madelk_RUS
lost oil pressure! ((
Disassembly showed that weight oil bath in the sediment.
All washed with kerosene, including oil pump
Renew pressure on standards
post #135 of 153 Old 02-10-2014, 10:48 PM Thread Starter
madelk_RUS
raised rear spring seats (after assembly it turned out that the rear part of the car below the front )
closed steel sheet inner cavity of the wheel arch
