Construction of my ZJ and greetings from faraway Russia - Page 4 - JeepForum.com
post #46 of 153 Old 02-26-2011, 04:46 AM Thread Starter
madelk_RUS
News from the garage
bought two fans with shroud
bought a new water pump, crankshaft seal, oil pump and all gaskets
area under the winch is ready
madelk_RUS is offline
post #47 of 153 Old 02-27-2011, 06:27 AM Thread Starter
madelk_RUS
post #48 of 153 Old 03-02-2011, 12:27 AM Thread Starter
madelk_RUS
disassembly of the front of the engine revealed that a chain with gears on the replacement starter for the replacement and restoration can not be, a generator needs to be replaced bearings and graphite elements
bought a new starter
'll take the weekend to repair the generator
post #49 of 153 Old 03-09-2011, 12:37 PM Thread Starter
madelk_RUS
oil pump
[/quote]
post #50 of 153 Old 04-21-2011, 05:48 AM Thread Starter
madelk_RUS
At this stage, supply a wide range in the transfer case from the Chevy Blazer and put konvershen kit for the transfer case.
Bushwacker has tried (for the upset that they did not cut the wheel arches) can fit them in aomoschi hot dryer.
almost ready front bumper
on the motor are all made to the end (but still works)
I also bought a rear axle from Sang-Yong Musso, but with the disc brake, locking differential and 4.56 gears
all of 2009, Dana 44
post #51 of 153 Old 10-21-2011, 05:50 AM Thread Starter
madelk_RUS
Hello! We already autumn and temperatora 0 Celsius
have not written as Work a little bit stopped
So during this time made ​​all the body work and remove all the rust (replacing the rear floor)
set to the rear axle is given 44 / 4.56 with no forced lock rear multi-link suspension is made and set the wheels 35 inches (Cooper STT)
Motor collected but not yet wound up (not connected radiator)
on the channel, do not look! it is fitting for a rear winch and mount the rear wheel
rear beam installed
post #52 of 153 Old 10-21-2011, 05:52 AM Thread Starter
madelk_RUS
answer my question plese)
Shock bilshtayn 5100 should stand down or rod up?
where you can see examples made ​​by the bumper with a winch and spare wheel holder?
post #53 of 153 Old 10-21-2011, 08:27 AM
WJChris
WJChris's Avatar
Похоже, что какой-либо стороной вниз, как правильно смонтировать их!
http://www.jeepforum.com/forum/f13/m...rectly-618656/
У меня есть бампер (Protofab), который имеет колеса перевозчика, но не лебедки.
Поиск здесь для получения полезной информации:
http://www.jeepforum.com/forum/f310/...mpers-1232335/
WJChris is offline
post #54 of 153 Old 10-22-2011, 02:12 PM Thread Starter
madelk_RUS
thank you
I realized there was no difference as to install a shock absorber.
post #55 of 153 Old 10-26-2011, 05:50 AM Thread Starter
madelk_RUS
Hello
still have a question!
to install the bumper with a holder to gauge amplifier amplify the body that holds the bumper?
I think that open-wheel holder will be a big load
Here are doing bumper!
I also bought a block of ARB in the front axle
post #56 of 153 Old 10-26-2011, 08:04 AM
1stblack97ZJ
looks very good!!
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #57 of 153 Old 10-26-2011, 09:57 AM
roughknight69
roughknight69 is offline
post #58 of 153 Old 10-26-2011, 10:30 AM
RedlegWJ
On my steel bumper, I welded a piece of plate to the face of the body rail under the old bumper and drilled for a couple of 1/2" grade 8 bolts. You can also weld a bracket to your reciever and bolt to that. One more spot I need to do yet, is make a bracket near the gas fill hose from the unirail to the forward end of the bumper and same on the other side. I already welded a thin plate to the unirail and trimmed the body out of the way behind the mudflap area.
Gray 99 Laredo with '04 driveline wap. Tons of fun coming soon. Steel bumpers. 5 1/2" IRO coils, IRO adj. track bar. Rancho RS9000 Addco rear sway. 2"x.250" DOM long arms with johny joints. Custom A-arm with ball joint delete (J-joint). JK Moab wheels/ 33x 12.5 x 17 Cooper SST. Bushwacker Flares.
RedlegWJ is offline
post #59 of 153 Old 10-26-2011, 01:24 PM Thread Starter
madelk_RUS
thank you
I will think a lot
post #60 of 153 Old 10-26-2011, 09:50 PM
Foundrydude
Well built truck, very well planned, very deep modifications. Excellent. Thank you for showing these pictures.
Foundrydude is offline
