Construction of my ZJ and greetings from faraway Russia - Page 10 - JeepForum.com
post #136 of 153 Old 02-10-2014, 10:50 PM Thread Starter
madelk_RUS
replaced all the rollers and belt
Replace the gasket valve covers
madelk_RUS is offline
post #137 of 153 Old 02-25-2014, 03:13 AM Thread Starter
madelk_RUS
How to get rid of the problems with the automatic gearbox?
Third gear is turned on for 2-3 seconds and then switches to the fourth gear!
If you turn on overdrive that third gear is working properly.
I understand this is due to replacement of the steam in the bridges.
post #138 of 153 Old 03-05-2014, 02:16 AM Thread Starter
madelk_RUS
up
post #139 of 153 Old 03-12-2014, 09:54 AM
970001zj
change the transmission fluid with the filter then adjust the transmission bands and tune the throttle cable
97 zj orvis/04 wj ltd/02 lancer oz rally/85 rx7 gs
970001zj is offline
post #140 of 153 Old 03-24-2014, 11:59 PM Thread Starter
madelk_RUS
thank you
post #141 of 153 Old 03-25-2014, 12:05 AM Thread Starter
madelk_RUS
Install the compressor with receiver
ARB hooked lock with pressure regulator, manometer, rubber switch
bought a second battery optima
install it in the trunk (behind the chair) bought a relay for charging two batteries
* adjustable battery energized two winches, inverter (two Kilowatt), compressor and light on the roof
post #142 of 153 Old 04-23-2014, 01:21 AM Thread Starter
madelk_RUS
car interior insulation
post #143 of 153 Old 04-23-2014, 01:49 AM Thread Starter
madelk_RUS
installed a second battery
and hooked to it both winches, Compressor
installed automatic slack distribution Alternator Charge
and established salenoidy power interruption in case of breakage (on the dashboard appeared emergency button (disable all)
post #144 of 153 Old 04-23-2014, 02:08 AM Thread Starter
madelk_RUS
First test
plied synthetic rope 9 mm. two winches
* went into the woods to test new compiled vehicle)
car rides through the mud excellent
all locks are working properly
on the way back home I broke down control rod wheels
battered and bent swivel
as experience has shown it is not strong
necessary to alter (
post #145 of 153 Old 04-23-2014, 03:04 AM
SnowLeopard
How did you not get in an accident when that thing broke? It seems like you came out lucky.
SnowLeopard is offline
post #146 of 153 Old 04-23-2014, 03:38 AM Thread Starter
madelk_RUS
Yes! I was very lucky because it happened at a speed of 30 miles per hour on the road to town! I was lucky because was eleven o'clock in the evening and in the oncoming lane there were no cars
I stopped at a roadside counter
I rode home on the evacuator
post #147 of 153 Old 04-23-2014, 06:28 AM
marcall
looks good, I like your build!
marcall is offline
post #148 of 153 Old 04-25-2014, 07:30 AM Thread Starter
madelk_RUS
post #149 of 153 Old 04-25-2014, 03:11 PM
Spike300
DO you have more pics of your integrated roll cage? I wanna do one like yours. And can you explain more about your insulation? Please and thank you
5.2-242 tcase-44a-30x9.50x15 MT/R-American Racing Burst Rims -Optima -E3 plugs-Custom Paint-Amsoil-Addco Front and Rear-polyurethane bushings
To be installed: RE gen2 discos, military battery terminals
To be rebuilt: HP30
To be received:
To be paid for:
Next on the list: complete redo of brakes and
lines
Needed: fittings, coil of brake tubing, Russel speed bleeders
Zombie Outbreak Response Unit #75
Spike300 is offline
post #150 of 153 Old 04-28-2014, 12:41 AM Thread Starter
madelk_RUS
I bought a tube thickness of 3 millimeters! pipe without a seam! tube inserted into the rack between the doors.
Pipes of factories from the roof to the thresholds
should carefully welded pipe rack as can spoil the geometry of the body from welding.
