CompCrasher's 01 WJ Ltd - Page 51 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > CompCrasher's 01 WJ Ltd
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 12-23-2011, 10:10 PM   #751
comptiger5000
The 4.0 isn't that picky about oil. What grade of M1 have you been using? The 0W-40, or 5W-40 TDT would work fine in the 4.0, as would the Rotella 5W-40 and a few others.
comptiger5000 is offline   Reply With Quote Quick reply to this message
Unread 12-23-2011, 10:16 PM   #752
compcrasher86
I've been using 10w-30 and if the change happens to fall on a winter date I'll do 5w-30, which is what I just picked up today. I've been using the high mileage cus I hear it's got extra zinc
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 12-23-2011, 10:21 PM   #753
snobrdrkid07
snobrdrkid07's Avatar
I've basically run Mobile 1 Full Synthetic 10w-30 High Mileage since I can remember!
Edit: Nice video there, looks like fun, and you soaked that other car!
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 12-23-2011, 10:29 PM   #754
compcrasher86
iPhone double post
Matt
Unread 12-23-2011, 10:31 PM   #755
mrJ
2002 KJ Liberty
Lookin good mang
Build In Progress...[url]http://www.jeepforum.com/forum/f22/03-wj-limited-build-she-needs-name-1113549/[/url]
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline   Reply With Quote Quick reply to this message
Unread 12-24-2011, 11:10 AM   #756
comptiger5000
If it's not much more, I'd step up to the 0W-40 (M1 0W-40 is considered one of their best). It's on the thinner end of the 40 range (not that the 4.0 minds a 40 at all). But, being a 40, the limits on zinc and such are higher, as it's not a resource conserving oil.
Unread 12-24-2011, 11:50 AM   #757
compcrasher86
That's what my dad runs in the Mercedes, you sure mine would be fine with a 0w?
Matt
Unread 12-24-2011, 08:22 PM   #758
snobrdrkid07
I'd be hesitant until I hear about that people with the 4.0 say who have actually ran it... I do not like being the person to "try it out" sometimes!
-Michael-
Unread 12-24-2011, 09:38 PM   #759
comptiger5000
0W just means it's thinner when cold than a 10W-40 (better for cold winters). A 0W-40, 5W-40 and 10W-40 are all pretty close to the same thickness when hot. In other words, it's fine. I've thought about it for the 5.9, but the Rotella 5W-40 seems to be doing well, and is easier to find around here.
Unread 12-25-2011, 06:51 AM   #760
compcrasher86
I'll do the rotella I think, cus you've been running it in your moms i6 for a while without issue and it sounds healthy. Which rotella do I get? t_ (insert number here)
Matt
Unread 12-25-2011, 08:12 AM   #761
snobrdrkid07
10w-30 Rotella T
-Michael-
Unread 12-25-2011, 08:32 AM   #762
compcrasher86
Im looking at the 5-40 cus it'll be happier in the winter, also I wanna keep synthetic versus the weird blend stuff. I hear the rotella has Higher detergent levels, is this gunna eat away at old gunk and sludge and cause any problems? I'd like to not have to deal with a 500mi oil change till summer.
Matt
Unread 12-25-2011, 09:48 AM   #763
comptiger5000
I've been using the T6 5W-40. Assuming your engine isn't totally gross inside (probably not, 4.0s aren't hard on oil), then it shouldn't loosen up much gunk. Plus, while the detergent levels are higher, they're not dramatically higher.
Unread 12-25-2011, 10:31 AM   #764
compcrasher86
Okay yeah I figured t6 is where it's at, that should be the blue bottle, wish they sold it by the quart tho now I have to buy 2gal
Matt
Unread 12-25-2011, 10:35 AM   #765
comptiger5000
They do sell by the quart in some places, but it's harder to find and more expensive overall. For me, the gallons work perfectly. 3 gallons changes my ZJ and mom's WJ with about a quart left over. Using the small filter on the 4.0, you should be able to do 2 changes on 3 gallons.
IOW, you've gotta buy 2 gallons the first time, but probably only need 1 the next time.
