CompCrasher's 01 WJ Ltd - Page 170 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > CompCrasher's 01 WJ Ltd
*STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light BaRuffstuff 10 year saleRegear now with Gear Packages from JeepHut.com
Unread 05-21-2013, 07:26 PM   #2536
compcrasher86
On a more positive note I've pulled 506miles out of my last tank of gas and I'd say that is most definitely some kind of a record
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 05-21-2013, 08:02 PM   #2537
zephyr80
How was that possible? im lucky if i get 350 driving down hill the whole time
Sent from your back seat!!!
zephyr80 is offline   Reply With Quote Quick reply to this message
Unread 05-21-2013, 08:12 PM   #2538
compcrasher86
55mph for 90% of that driving, cruise control, tailwind, it was a good day for the mileage gods lol. Oh and stock street tires.
Edit: oh and a recent development, my tires may be to blame for my highway issues, the sidewalls "may" be compromised from what I'm reading. I am going to throw the 32s on tomorrow (yay real lifted Jeep) and see how if it makes a difference.
Matt
Unread 05-25-2013, 07:22 PM   #2539
compcrasher86
I noticed the moog SS skipped a bit when I actuated it by hand (huh?) but couldn't replicate it another time. Also noticed, the rubber bushings are SHOT, I was able to get a good bit of play between the rubber and the SS. Time for a new SS!
Matt
Unread 05-26-2013, 12:35 AM   #2540
comptiger5000
Sounds like the SS was questionable. CA bushings might need some love, but if they're not blatantly bad, they shouldn't be enough to cause DW.
comptiger5000 is online now   Reply With Quote Quick reply to this message
Unread 05-31-2013, 07:22 AM   #2541
compcrasher86
Did a good bit of towing with my Jeep yesterday. All was well and then this morning I started it up and got horrendous noises. Who wants to play the guess this fluid game?!
Matt
Unread 05-31-2013, 07:28 AM   #2542
dillonjm
Power steering judging by the location.
[B]03 Rubicon[/B] (Weekend Toy) [URL="http://www.jeepforum.com/forum/f176/marshals-03-rubi-2822258/"]Build thread[/URL]
[B]11 Ram 2500 [/B] - H&S tuned 6.7 Cummins (DD/Tow Rig)
[B]05 Liberty Limited[/B] (Wife's): Minor mods, OME/JBA Suspension, 245 70/17 Duratracs
dillonjm is offline   Reply With Quote Quick reply to this message
Unread 05-31-2013, 07:34 AM   #2543
compcrasher86
Most definitely. Looks to me like a blown up hose or its coming from the rack itself but the pump is shot too, needs full overhaul. Bad timing too. Didn't have time to look it over had to bike to work in the time it would take me to drive. Not fun.
Matt
Unread 06-01-2013, 06:19 AM   #2544
comptiger5000
At least you work close to home!
Unread 06-01-2013, 05:10 PM   #2545
compcrasher86
Had some more time to look into my PS problems. Pump is weeping around joint to expansion tank and making horrible noises so new pump is in order anyways. Lower hard->soft joint on PS high pressure hose is wet and looks gross, i think thats where the failure has occurred. Pitman arm area of steering box and adjoining area is covered in PS fluid, box itself is dripping. What I'm hoping is that its the high pressure line was spraying the box. Once I get a second hand ill hop under and watch as the wheel is turned. It does not leak at idle.
Luckily that is a cheap and not too difficult fix if its just the pump and line
Edit: I also found this online today, it is a TSB for defective power steering line designs that cause "honking" noises. Mine has been doing that for about a year now and I thought that it was a steering collumn issue, explains why I was never able to find it. http://www.wjjeeps.com/tsb/tsb_wj_1900301a.pdf
Matt
Unread 06-04-2013, 08:27 PM   #2546
compcrasher86
Got my PS fixed today. Replaced pump, pressure line, and all 3 o-rings. Flushed and refilled with fresh fluid, steering is great now really smooth (was notchy before and assist occasionally cut out in reverse) and no noise. Very happy with the results.
I have a plethora of pictures but Jeepforum is broken and won't let me upload them. From my phone it complains about being larger than 540.6kb (I used to do this all the time and never had any issues) and from my PC the upload finishes and it complains about a security token being missing and the upload is cancelled. Not motivated enough to dig up my photobucket account.
Edit: Oh also, no more low speed honking noises with turns!!
Matt
Unread 06-05-2013, 07:59 PM   #2547
snobrdrkid07
snobrdrkid07's Avatar
Yay new power steering pump! I swear by the time you are done with this thing it'll be showroom new.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 06-06-2013, 11:23 AM   #2548
compcrasher86
Well Jeesh sometimes it feels like that. I do plan on selling my Jeep soon so the next owner won't have much to worry about with all of these new parts.
Matt
Unread 06-08-2013, 06:46 AM   #2549
compcrasher86
Well my RB1 decided to kick the bucket. I got a good 6 months of awesome reliable use out of it and now it has caught the dreaded blank screen disease. Mines intermittent. Nobody knows the "right" way to fix it so I might be tearing into it blind. I have my old 3-band head unit but you know this is just really disappointing.
Matt
Unread 06-08-2013, 09:19 AM   #2550
comptiger5000
Ugh, that blows! At least you're not the only one with weird failures. I've got a flaky headlight switch that needs fixing (auto doesn't always work right, dash light flicker a bit sometimes unless on min or max) and the dreaded "coolant sensor bad" on the VIC 70% of the time now (just a cracked solder joint).
