CompCrasher's 01 WJ Ltd - Page 168 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > CompCrasher's 01 WJ Ltd
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 04-02-2013, 12:15 PM   #2506
compcrasher86
Fun times, yesterday got out and realized my Jeep was dripping trans fluid ahh late to class will catch it later. Observed leaks and boy was there an ATF shower under there. Not sure which of these caused it but here are my suspects:
Leaking hard line from flexing too much (new radiator isn't prefectly lined up for the hoses), over tightened hose clamp on the soft-hard line conversion, or worn out constant tension clamp where soft meets hard line. So I chopped an inch off my hose to eliminate any doubt and the radiator trans cooler has been bypassed for the time being. I have it all running through the aux cooler which should suffice until summer time without towing anything. I just don't feel like pulling that radiator up and out a bit until the weather has improved drastically. Oh yeah and I did damage control with the dripping ATF all over the frame and the parking lot.
image-3536249688.jpg   image-1846152917.jpg   image-3826743742.jpg   image-229737618.jpg   image-1199936336.jpg
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 04-02-2013, 12:27 PM   #2507
billzcat1
Chicken in a Turkey Suit
2003 WJ
That's a lot. CT clamps are almost never the culprit. OEMs use them for a reason. Check the regular hose clamps, they probably cut through the hose. Either that or you bunged up the radiator install somewhere.
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 04-02-2013, 12:46 PM   #2508
comptiger5000
I've found the CT clamps are only good for a couple of uses before they don't hold tension well enough anymore. Trans cooler lines aren't under much pressure though, so that's probably not the issue.
comptiger5000 is offline   Reply With Quote Quick reply to this message
Unread 04-02-2013, 01:29 PM   #2509
compcrasher86
I've reused the CT clamps a couple times too many. One of the hoses I was able to spin with my fingers. Also, it looks like I did overtighten one of the screw clamps. I really can't tell about the radiator fittings but I think the upper still was leaking. To avoid further confict I've bypassed the radiator trans cooler and I'm running it off my external trans cooler. I've got about 900 miles worth of driving this weekend so I can't risk any more leaks. Need to add more grease to the a-arm before I head off
Matt
Unread 04-13-2013, 01:25 PM   #2510
compcrasher86
Went to rotate my tires today. I was getting a good bit of drag and scraping noises from the rear drivers side. So I tried adjusting the e-brake, nope. So I removed the e-brake, YUP :-D . But in all seriousness I don't need it for the time being and I think the springs are rusted out and stretched so they're not doing their job. Ill order some new hardware and shoes come summer time. Also have to look into replacing the rear calipers, they can't be bled for the time being (seized bleeders). That all can wait, as of now my ride got a whole lot quieter coasting.
Matt
Unread 04-13-2013, 06:27 PM   #2511
snobrdrkid07
snobrdrkid07's Avatar
Yeah I still wonder why mine locked up on me the other week. Maybe the springs were getting weak as you had mentioned or, the large amount of snow jammed up in there. So they were rubbing even with the cable completely slack? Is there any binding in the cable, between the sheathing and the actual metal cable?
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is online now   Reply With Quote Quick reply to this message
Unread 04-13-2013, 10:03 PM   #2512
compcrasher86
I hate drum brakes. My little brother's mustang just has a lever that pulls the caliper and uses the pads. The design is so simple nothing has ever went wrong. I've really got to pull the whole rear end apart and redo everything. When I was in there I hit the pads and slides up with brake parts lube and man have my rear brakes never been quieter. Happy.
And the noise reduction from pulling out the e-brake, amazing.
Matt
Unread 04-14-2013, 08:09 AM   #2513
comptiger5000
Personally, I think the drum thing is better for e-brakes, as it separates that crap from the rear calipers. I'd rather have a slightly more annoying e-brake setup than complicated brake calipers and more risk of the actual calipers ****ing up.
Unread 04-15-2013, 01:09 AM   #2514
85IrocZ-28
I like the double design, drum in a disc...However, I haven't ever driven a ZJ or WJ that had a really good parking brake.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY --- [URL=http://www.jeepforum.com/forum/f197/project-yeti-abominable-wj-1125665/]Project Yeti Build Thread[/URL]
85IrocZ-28 is offline   Reply With Quote Quick reply to this message
Unread 04-15-2013, 02:22 AM   #2515
compcrasher86
The one in my ZJ never worked right, and the one in my WJ has been nothing but trouble. When I first got it, it didn't hold in gear, then it started making clicking noises as I was driving, so I pulled everything apart and adjusted it. E-brake had good tension, but would give with about 1300rpm. In MA to pass inspection it's supposed to hold to 1500rpm, but my inspection guy doesn't check. I noticed lately my rear ends been noisy (scraping noises) so while rotating my tires I spun the rears and got that scraping noise. So my PITA e-brake is gutted until I can put fresh hardware and shoes in, things still a pain in the butt. And those springs are horrible to work with too.
Matt
Unread 04-15-2013, 08:37 AM   #2516
comptiger5000
The big issue is the hardware just wearing out over time, especially on e-brakes that don't get used often, so things get rusted in place and then broken free, etc.
Mine works, but it's a little screwed up. It works much better in reverse. In drive, it'll hold to about 1000 rpm. In reverse, it'll hold past 2000 no problem.
Unread 04-15-2013, 11:21 AM   #2517
85IrocZ-28
Originally Posted by compcrasher86 View Post
The one in my ZJ never worked right, and the one in my WJ has been nothing but trouble. When I first got it, it didn't hold in gear....
^X2 on everything you said...both my ZJ and WJ, always hated the poor holding ability of the e-brake.
Maybe I should at least replace the pads to see if that helps at all.
Unread 04-15-2013, 11:54 AM   #2518
billzcat1
2003 WJ
Add me to the club. Parking brake doesn't hold all that well. It's a Jeep thing. :-P
Unread 04-15-2013, 12:13 PM   #2519
compcrasher86
All right! I knew it wasn't just me. Yeah I doubt my grandma ever used that when she owned it. My rear brakes need an overhaul so ill do that on jack stands under shelter this summer when it's in the 70s and I have my workshop back again :P until then I'm really enjoying not having the noise from whatever was dragging slightly. And I thought my rear end was going out HAH it was just a silly e-brake.
(knocking on wood)
Matt
Unread 04-15-2013, 12:14 PM   #2520
comptiger5000
Yeah, new shoes and hardware in there and it should work just fine again. And hey, you could do it now. It's 70* outside
