-   Grand Cherokee General Discussion (http://www.jeepforum.com/forum/f197/)
-   -   CompCrasher's 01 WJ Ltd (http://www.jeepforum.com/forum/f197/compcrashers-01-wj-ltd-1106034/)
compcrasher86 09-22-2010 07:01 PM
Hey guys, I neglected doing this on my XJ so I want to start an in-depth build thread on my 01 WJ Limited.
It has around 107k miles on it right now, its always been maintained well and was completely inspected before it was given to me. Mechanic who used to do all the maintenance told me its in great shape. I'll be doing all fluid changes and any maintenance from this point on :D
Here comes some stock info!
(All the stuff limiteds come with EXCEPT heated seats)
Stone White Exterior
Sandstone Leather Interior
4.0L i6
Quadratrac-2 (NP247)
Rear D35 Front D30 geared with 3.55's
235/65/17 Michelin AT's on Silverblades
Factory/dealer applied protective undercoating
Aftermarket Remote Starter
Stock pictures:
Front:
http://i45.photobucket.com/albums/f8...6/IMG_0875.jpg
Rear End:
http://i45.photobucket.com/albums/f8...6/IMG_0869.jpg
Interior:
http://i45.photobucket.com/albums/f8...6/IMG_0866.jpg
New Keys side by side with my XJ's :)
http://i45.photobucket.com/albums/f8...6/d42fa78d.jpg
It was just recently transferred into my name right after I left for college so I wont be able to touch it until november :rolleyes:
Mods I'm doing right away are as follows:
Got myself tow hooks from a junkyard up here, I'm happy to have recovery points now:
http://i45.photobucket.com/albums/f8...6/52849c61.jpg
Got a PIE aux in adaptor and then bought a dock connector --> 12v+RCA. I had to get one with a 5v transformer built in because I have an iphone and it only charges off of 5. This is a nice one plug solution and will charge and play iPods through the factory stereo. (Get to keep my steering wheel controls :highfive:)
http://i45.photobucket.com/albums/f8...6/IMG_1780.jpg
For audio I've resealed a set of WJ infinity tweeters because the ones in my WJ are blown.
Edit: See post below, new tweeters instead.
Heres the sub setup that I built in my XJ, I'm ditching the trunk box and putting the subs+amp in the WJ. Amp is going under the rear drivers side seat with a little crossmember hacking ;) They're not for showing off (even though they can) I was sure my Polk Amp I bought had remote level control because I'm an audiophile and I tune it on the go to sound the best. I love good quality sound.
http://i45.photobucket.com/albums/f8...6/IMG_0100.jpg
Repairs so far:
Side mirror autodim failed and leaked fluid between the panes, replaced that
Flasher module failed, pulled it apart and soldered the contacts again (works great)
Auto Climate Control blend doors fixed at dealer under extended warranty
Auto climate control knobs got stuck for whatever reason, pulled unit apart and cleaned a bunch of sticky iced tea out of it (not sure how it got there
Planned mods:
2" Rusty's BB
Bigger Tires
242 Swap
Westin Safari Light Bar (the low one because it mounts to the front skid holes not the tow hook holes) w/ 2x Hella 500ff's running 100w
HaViiK 09-22-2010 07:18 PM
Me and you are quite similiar! haha I lovee my music. But i tend to show off some. :)
compcrasher86 09-22-2010 07:39 PM
I only show off to the people in the car haha I tend to turn it down at redlights and such. When I'm on my own though I turn it down a significant bit
compcrasher86 09-23-2010 08:49 AM
Decided not to mess around with re-sealed tweeters. If they work fine I'm probably just going to give them away but I want to upgrade, re-sealing is a slight downgrade.
Bought a set of these:
http://i45.photobucket.com/albums/f8...ker_KS-350.jpg
Those are Kicker - 08KS350's. They seem to be perfectly matched power-wise to the infinity system and should fit with a little persuasion from my dremel :D
HaViiK 09-23-2010 10:48 PM
I did the exact same thing with Kicker 3.5". This is getting kinda weird.
compcrasher86 09-23-2010 11:11 PM
Yeah I just creeped your build thread a second ago and didn't see them on there so I definitely didn't get the idea to copy you haha. That is real weird, how did the install of them go, I know I might need to do some trimming but how much?
Also how are they holding up, I dont know if I should install a bassblocker on them or not...
platinum5.9 09-25-2010 11:22 AM
Where did you get the (PIE aux in adaptor and then bought a dock connector --> 12v+RCA) set up and how much?
compcrasher86 09-25-2010 11:24 AM
I found the PIE adaptor on ebay for $20. Nobody had bid on it and it had an hour left so I won it for minimum bid.
I found the Dock connector off of amazon for $20
compcrasher86 09-25-2010 12:39 PM
Hey, why not:
Off-Road Long-Range Truck Light System
hehe, I'm planning on getting a westin bar and plus these are on sale for $20... with my 20% coupon on top of that how could I ever pass that up
compcrasher86 09-25-2010 08:09 PM
Theres a 242 X-case for a '99 WJ with 85k miles on it for $100 on craigslists, right in town. I am so damm tempted but I can't store it in my dorm room and I dont have a job right now so its not smart to be doing big upgrades.
MoonyJohn 09-25-2010 08:20 PM
1 Attachment(s)
Buy it, and then store it in your jeep in the meantime.
compcrasher86 09-25-2010 08:26 PM
Both my two Jeeps are 400 miles away from me until november unfortunately :(
compcrasher86 09-25-2010 09:11 PM
I got the lights today:
http://i45.photobucket.com/albums/f8...6/4d4a9496.jpg
I couldnt pass them up they were $17. They win my seal of approval, these things are beefy! Probably as well constructed as a plastic light could be. Ridged and well protected. My friend comptiger5000 up here got a set for his ZJ and we hooked them up. Very impressive beam pattern and they fire FAR. Look forward to installing them on the WJ.
Light output:
http://i45.photobucket.com/albums/f8...6/2f301a0d.jpg
Bama_WJ 09-26-2010 12:46 AM
The school cares if you keep car parts in your dorm room? That's lame.
I've kept dirty axles and rock sliders in mine before. :laugh:
compcrasher86 09-26-2010 09:57 AM
The school, no. My roommate, yeahhh.
The time now is 11:23 PM.
