CompCrasher's 01 WJ Ltd - Page 56 - JeepForum.com
post #826 of 2661 Old 01-03-2012, 11:57 AM
joekid24
Can you show a picture of the new sway bar links installed?
joekid24 is offline
post #827 of 2661 Old 01-03-2012, 12:30 PM Thread Starter
compcrasher86
No problem, this is the best angle I can get of them without takin the tire off but the bar seems to be ~20 degrees above level with the ground. The second pic makes em look like they're crooked but they barely are, it's just the angle I was shooting from. Even if they were I'm not worried they are beefy and the bushings a very thick
Matt
compcrasher86 is offline
post #828 of 2661 Old 01-03-2012, 03:59 PM
joekid24
Looks like they would have put some angle on them like zone do.
joekid24 is offline
post #829 of 2661 Old 01-03-2012, 04:36 PM Thread Starter
compcrasher86
There's a little angle but I'm not worried about it whatsoever nothings binding and she rides great. I really love how well crafted and solid these IRO links feel, makes the stockers feel like pencils
Matt
post #830 of 2661 Old 01-03-2012, 05:31 PM
joekid24
Is your sway bar stock?
joekid24 is offline
post #831 of 2661 Old 01-03-2012, 06:13 PM
comptiger5000
Yeah, I'm pretty sure he's still running stock bars. And Matt, I think you could fit 33s under there with little trouble, considering you could stuff the 32s on 1.5" of lift with the BB. And I'll put 33s on the 5.9 the day gas drops under $1 a gallon and I have a second car for fun.
comptiger5000 is offline
post #832 of 2661 Old 01-03-2012, 07:31 PM
joekid24
The coils are OME HD right?
Kolak said I would get 21 front and 20 1/2 rear with OME HD.
joekid24 is offline
post #833 of 2661 Old 01-03-2012, 08:36 PM
alwaysHI
2003 WJ
FINALLY!!!! looks great mang!!
Bronson = 21 yrs. old
BUILT, NOT BOUGHT - WORKED HARD FOR, NOT KISSED MOMMY/DADDYS A** FOR!
Build Thread -
SOLD
alwaysHI is offline
post #834 of 2661 Old 01-03-2012, 08:38 PM Thread Starter
compcrasher86
Yupp they're OME HD. I was considering upgrading the rear to an addco but now it seems as though the body roll issue has been solved by the springs, I don't think I'll be purchasing one anymore. But otherwise they're all stock. I'm looking at the zone links for the front but I'd love a set of JKS discos.
Matt
post #835 of 2661 Old 01-04-2012, 12:39 AM Thread Starter
compcrasher86
Okay, so I'm now motivated to kill off the P0456, seeing as inspection is in a couple months and I'm leaving in less than a week. Originally I thought it was gas cap, so I replaced with one from AAP, new one wasnt 1/4 turn like the old one. Old Cap seemed perfectly fine to me but tossed it anyways. THEN I found what really was the problem I thought, a totally destroyed evap hose in the engine bay. Now reading the FSM it says if you have the 1/4 turn cap you need to replace it with the same style cap... which I threw out. Im hoping I just put on the wrong cap and thats the cause of the code. I'll go get a dealership 1/4 turn cap and cross my fingers that it'll go away I've checked every inch of the system and everything seems fine. Hoses might be a tad loose around the evap canister, might replace those too... this evap stuff sucks.
Matt
post #836 of 2661 Old 01-04-2012, 07:13 AM
comptiger5000
At least you only have ONE code, even if it's the most annoying type possible. I'm down to 2 now, and working on fixing both of those before I'm due for emissions at the end of the month, as any CEL is an automatic fail in CT.
post #837 of 2661 Old 01-04-2012, 08:00 AM
joekid24
What about the IRO front links?
I think the zone is only 9"
joekid24 is offline
post #838 of 2661 Old 01-04-2012, 01:53 PM Thread Starter
compcrasher86
I thought about the IRO front links but the main reason I got the rears was because I snagged a sweet deal on them. The Zones don't look so bad and for $40 I'd be willing to try em out. Looks much like the IRO but without powdercoat and red poly bushings. So far I like the handling feel so I might just wait it out and eventually get some of the JKS ones so I can adjust them and fine tune them.
I need to check to see if this code will fail me, I actually dont think it will, but I dont want to risk getting an R sticker if it will.
Matt
post #839 of 2661 Old 01-04-2012, 05:20 PM
joekid24
Thank's for all the help Matt.
joekid24 is offline
post #840 of 2661 Old 01-04-2012, 06:07 PM
JerzeyBoyWJ
2003 WJ
jezz the IRO links look like pure beef hahah...any difference in ride with them?
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline
