CompCrasher's 01 WJ Ltd - Page 4 - JeepForum.com
post #46 of 2661 Old 01-03-2011, 12:49 PM Thread Starter
compcrasher86
in my driveway packed with snow I can feel the rear wheel slip a tiny bit and then the 4wd pull, I know its there
Matt
compcrasher86 is offline
post #47 of 2661 Old 01-04-2011, 10:47 AM
gqmdl0617
Hey man, Im liking your WJ. Good luck with that inverter install. It should fit where mine did next to the shifter, jusding by the size of it.
Also, if u do get rid of the mud flaps. Give them to me! lol
gqmdl0617 is offline
post #48 of 2661 Old 01-04-2011, 01:34 PM Thread Starter
compcrasher86
Mud flaps are still on, I think I'm gunna leave them on till I know I need extra ground clearance but should be fine in snow and everything. They do a great job of keeping the crud off the fenders and through huge puddles water stays under the Jeep instead of spraying up everywhere
Matt
post #49 of 2661 Old 01-07-2011, 12:27 PM
comptiger5000
Good point. Looking at them in the parking lot earlier, your Jeep is a heck of a lot cleaner than mine! We're supposed to get some snow today through Sunday though, so I'm not sure when I'll get a chance to wash it. Maybe Sunday afternoon if things are clearing up. You should get yours washed too, as it's hard to tell just how salty it is, being white.
comptiger5000 is offline
post #50 of 2661 Old 01-07-2011, 12:31 PM Thread Starter
compcrasher86
I hate salt, luckily theres a heavy coat of wax as a buffer zone but just the thought of salt bothers me. We should go for a wash once all this snow is gone and melted...ish
So anyways, tested the range of my remote start. Although something isnt wired right with the ignition and it does some weird things the range is outstanding with a semi-new battery. I was able to have full control of my Jeep from this window across the hall from my room
And although I told myself I wouldnt because its the farthest parking spot away in the lot, I park next to comptiger because its way far away from the idiots who dont know how to park. A friend of mine got a dent and his mirror knocked off when he came out, I would not be able to handle that well.
Matt
post #51 of 2661 Old 01-07-2011, 12:36 PM
comptiger5000
I picked up some more WD-40 for mine today. It's well waxed also. The key isn't to keep the thing clean, but to get the salt off the undercarriage occasionally. Once I get mine washed, I'll spray the wheel wells and such with WD-40 again.
Oh, BTW, Harbor Freight didn't have the wide spray cans of WD-40, but they did have the 16oz ones without the straw, same price as the 12oz flippy straw ones too! ($7/can)
post #52 of 2661 Old 01-07-2011, 12:41 PM Thread Starter
compcrasher86
Wanna head over there with me? I'm going to pick some up to pre-treat the beginnings of pinch weld rust we found? That stuff is going to meet Mr. Dremel and Mr. rust reformer and Mr. Touchup paint eventually (probs when I go back in march)
Matt
post #53 of 2661 Old 01-07-2011, 12:42 PM
comptiger5000
Gimme 20 mins. I'm dubbing the new Santana album to tape. If you want to talk, walk down to my dorm room. BTW, this album wins. This is the 2nd time today I've played through it.
post #54 of 2661 Old 01-07-2011, 12:53 PM Thread Starter
compcrasher86
is all I can say. You're probably the only one in this building that would do that... no... wait... I bet you're the only one in this entire building with cassettes
Matt
post #55 of 2661 Old 01-09-2011, 03:14 PM Thread Starter
compcrasher86
got my Jeep washed today. I havent seen it REALLY clean for a while, it looks nice:
Oh and also I swapped all the speakers with Boston Acoustics from my friend's WK. I broke a couple clips because it was freezing cold but overall the sound difference is outstanding. The bass on the infinity's was deep and loud but the Boston acoustics are crisp and punch hard. I really like the improvement. No rattles from the doorpanels luckily. Also... look at the above picture, 5 brownie points to whoever can tell me whats missing from my Jeep (comptiger cant play because hes the one who first noticed) PS I took the subs out of my sig, they wont be going in the WJ ever since the Boston install. Probably going back in the XJ but until now they're just hanging out in my room at home
Matt
post #56 of 2661 Old 01-10-2011, 02:37 PM
squashman702
1994 ZJ
Debadged?
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #57 of 2661 Old 01-10-2011, 03:21 PM Thread Starter
compcrasher86
Debadged?
Win! Yeah before I got it my Jeep was side-swiped by an old lady in a caddy. Body shop forgot to put badging back on. Other side still has badging. The lack of symmetry is bothering me. I'm going to see if they still have the badging kicking around at the body shop where it was repaired or at least ask them to mail me a new set, I can put them on myself no problem
Matt
post #58 of 2661 Old 01-11-2011, 11:17 PM Thread Starter
compcrasher86
Rattling noise coming from the rear end when going over bumps, I am going to pick up a set of Moog K7410 bushing's tomorrow. 9/16" is what all of the parts sites have the WJ listed as so I'll assume thats correct. This will be my first wrenching on the WJ I do (minus the tow hooks). Funny actually the XJ needed front bushings when I got it so this is a familiar new Jeep owner process lol
I don't have to do anything special on the WJ I presume, just park on level ground, unbolt brackets and replace cruddy worn bushings. Grease at all?
Edit: Whoah it looks like the WJ rear suspension is WEIRD. I'm used to the bar being held to the frame with a bracket and bushing and links to the axles but if the FSM is correct.... the bar is bolted to the axle with links to the frame? Thats weird. I'm assuming Its probably the bushings between the bar and the axle then that are worn and not the brackets holding the links to the frame? On the upside looks like it will be a breeze to fix this, just gotta wait for the snow to subside
Matt
post #59 of 2661 Old 01-14-2011, 03:32 PM Thread Starter
compcrasher86
Bored so took a video of the remote start's range. I'm really amazed at how well this system works:
Matt
post #60 of 2661 Old 01-14-2011, 04:20 PM
SplitNail
Which remote start did you get I REALLY want one!
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
