A college student's cheap, daily driver build - Page 2 - JeepForum.com
post #16 of 161 Old 05-01-2012, 10:02 PM
ZJMTL
I like how you mounted those lights!
Thumbs up from another near broke college student
ZJMTL is offline
post #17 of 161 Old 05-01-2012, 10:34 PM
alphazulu29
How did you end up mounting the lights? Did you use the factory brackets the 93-95's came with? Or did you make your own?
alphazulu29 is offline
post #18 of 161 Old 05-02-2012, 05:49 AM
xbeakerx
How did you run your wiring for your roof mounted lights?
1998 ZJ Laredo(Gonzo) - Built Not Bought - 3.5" lift with IRO Long Arms, Cherry Bomb Exhaust, 31x10.50R15, CAI, Custom Front Recovery System & YJ Tube Bumper
1986 Toyota MR2 - Polyurethane Suspension Bushings,Suspension Techniques Lowering Springs,S/C Swap and more!
xbeakerx is offline
post #19 of 161 Old 05-02-2012, 09:27 PM Thread Starter
95_ZJ_Limited
I assume that you're asking about the front bumper. I removed the factory mounts and used the ones the new lights came with. I just drilled into the bumper cover.
1995 ZJ Limited. Lifted, AW4 & 4X4 swapped
Build Thread: Jeep Grand Hilton
Built Not Bought # 529
95_ZJ_Limited is offline
post #20 of 161 Old 05-02-2012, 09:33 PM Thread Starter
95_ZJ_Limited
I hate that I didn't take any pictures but here goes nothing. I grounded the lights themselves to other torx screw holes in the roof rack. I ran the rest of the wires through another torx screw hole (later filled with sealent to avoid leaking) in which it ended up below in the headliner. Then, if I'm not mistaken, I ran those to the switches on the overhead unit. I grounded the wires for the switches to pre drilled holes in the overhead unit and spliced the power wires with some fuses in the cabin fuse box.
post #21 of 161 Old 05-02-2012, 09:36 PM Thread Starter
95_ZJ_Limited
Here's a little wheelin pic. Nothing serious
And towing my buddys boat for a fishin day
post #22 of 161 Old 05-02-2012, 09:47 PM
nickpequignot
Like the build so far. I have 2 driving lights up front thinking about adding some fog lights as well.
nickpequignot is offline
post #23 of 161 Old 05-02-2012, 09:55 PM Thread Starter
95_ZJ_Limited
And then my mechanical problems hit . One of the serpentine pulleys decided to break (a major pain in the ***), and the steering box had gotten so loose, I had nearly 40-45 degrees of play at each end. Took it to a mechanic friend not wanting to risk screwing anything up
post #24 of 161 Old 05-02-2012, 10:02 PM Thread Starter
95_ZJ_Limited
After getting her back, I set out to replace the old and worn out headlights with new OEM parts as well as fab up a CB antenna mount out of on old bed wheel
Heres a pic that I found with everything lit up.
post #25 of 161 Old 05-02-2012, 10:40 PM
alphazulu29
Oh okay, I have a 96 and I'm trying to find a way to mount the lights. I wasn't sure if the bumper itself would be sturdy enough. Another option is to fab an L bracket and bolt that to the frame where the 93-95's had the option of the higher fog lights in the position you have now.
thanks!
1996 Red 4.0 ZJ
post #26 of 161 Old 05-02-2012, 10:42 PM
Ganjatrooper
1994 ZJ
damn bro i like the lights, nice little write up on how you did it but i vote you start all over on the install and this time take step by step pics! i love the switch placement looks clean bro! keep up the good work
Ganjatrooper is offline
post #27 of 161 Old 05-03-2012, 06:58 AM
xbeakerx
Originally Posted by ganjatrooper
damn bro i like the lights, nice little write up on how you did it but i vote you start all over on the install and this time take step by step pics! i love the switch placement looks clean bro! Keep up the good work
x2
xbeakerx is offline
post #28 of 161 Old 05-05-2012, 11:09 AM Thread Starter
95_ZJ_Limited
so right now i'm working on installing OEM towhooks that I bought from another user on JF. so far I have sanded and put on a coat of naval jelly and painted with krylon rust eliminator
post #29 of 161 Old 05-12-2012, 06:15 PM Thread Starter
95_ZJ_Limited
Finished the tow hooks, will get pictures up tomorrow hopefully. Also just ordered a set of 30/9.5/15 BFG Mud Terrains and black Cragar Soft 8's off discounttire and got an awesome price for the set. Hopefully they'll be here soon
post #30 of 161 Old 05-17-2012, 02:25 PM Thread Starter
95_ZJ_Limited
new bfg mud terrains and cragar soft 8's came in the mail today
Daily Driver with 8.8 KyBoy1991 ZJ Grand Cherokee Forum 48 01-16-2013 08:27 AM
daily driver shocks JackStraw ZJ Grand Cherokee Forum 5 02-09-2009 09:57 PM
249=> 242 TC swap in a Daily Driver amonostereo ZJ Grand Cherokee Forum 7 11-10-2008 01:28 PM
daily driver hitch jshaab2 WK Grand Cherokee & XK Commander Forum 11 01-15-2008 10:46 AM
A cheap a$$ college student need help to pass the smog test jasonliman ZJ Grand Cherokee Forum 13 10-14-2006 11:49 PM
