#661 | |
regarding the skid: you might run into some issues with bolts not fitting depending on which version of the cross member you have. might want to call up jason and see what he has to say about what version you have, didnt work on mine.
http://www.jeepforum.com/forum/f197/spife7980s-build-thread-868195/index4.html#post8590806 hope that was worded clearly enough.
-James Got to love an ORVIS guy... IRO 5.5", Front LA & Double Sheer TB, Rear Adjustable SA and TB, JKS Quick Discos, DT8Ks 265/75/16 Nitto Terra's, Cragar 16x& Soft 8s 4" bs JCR Stage 2 Sliders, IRO Trans Skid |
#662 |
ill have to ask them about that when i call them tomorrow
whats the difference between the 2 versions?
[color="#003300"]Matt[/COLOR] [color="white"][CENTER][size="1"] [url="http://www.jeepforum.com/forum/showthread.php?t=434081"][color="white"]Click Here For My Build Thread[/COLOR][/url] [/COLOR][/SIZE][B]**September 2009 Grand Cherokee Of The Month**[/B] [SIZE="2"][url="http://www.jeepforum.com/forum/forumdisplay.php?f=123"][color="white"]Colorado Jeep Club Member #88[/COLOR][/url][/SIZE][/CENTER] |
#663 | ||
If you have welded nuts, you can do two things. -What I did, was took two bolts and put them butt to butt, and welded them. This created a stud for the skid, and then I put nuts on those studs. -The other option is to support the subframe, take out the bolts going through, hold the skid in place and put slightly longer bolts through, making the skid end to end with the subframe.
-Pat I'm 19, and getting my hands cut while learning "Project Dirty Princess" 5.9 ZJ 7" IRO, 35s, 8.8, hp30, locked, blah blah "Project Grow A Set" Quote:
#664 |
i just looked and i do have the version with the welded nuts on the end pieces.
why cant it be put end to end with the subframe to begin with? why does it need the spacer in between also.. why cant the longer bolt be put in from the skid side? so it goes Bolt > Skid > Nut > X-Member > Nut
[color="#003300"]Matt[/COLOR] [color="white"][CENTER][size="1"] [url="http://www.jeepforum.com/forum/showthread.php?t=434081"][color="white"]Click Here For My Build Thread[/COLOR][/url] [/COLOR][/SIZE][B]**September 2009 Grand Cherokee Of The Month**[/B] [SIZE="2"][url="http://www.jeepforum.com/forum/forumdisplay.php?f=123"][color="white"]Colorado Jeep Club Member #88[/COLOR][/url][/SIZE][/CENTER] Last edited by CLNinja; 01-01-2010 at 01:38 PM.. |
#665 | |
Matt, it can be put end to end as far as I am concerned. Everytime I have installed one however i made studs for it.
And as far as putting a longer bolt in, thats what I would suggest for you if you do not want to build studs, you should be able to get the bolt in through the skid side, and thread into the welded nut. Give me a call if you have any questions, ya got my number.
#666 |
On my cross member on the transmission mount there is a piece that sticks out further than where the bolts are at so I'm assuming the nuts ate a spacer so that you don't have a gap that would result from flush mounting it or trying to torque the 2 together that i doubt would happen because you would have to bend one of the 2
#667 |
why not just put in a longer bolt from the skid side? use a spacer between the skid and the crossmember and the bolt threads into the welded on nut like normal
#668 |
what ever happened to those 1/2 doors lets see some pics
#669 |
half doors were put on the back burner since its winter and i cant use them anyways... there pretty much done..
im actually most likely going to sell them and just do tube doors
#670 |
new daily driver is being picked up tomorrow
so the jeep will not be my daily driver anymore... so ill have lots more time to toy with itthat means that over the summer its getting a hybrid roll cage ... so ill be able to go a little crazier with it when offroading oh yeah ... im getting a 1964 VW Bug Baja edition it will take a little work to get it in perfect condition but its a little project i love projectsheres a pic ![]()
#671 |
thats freaken BEE---UTTIIFUULLLLL..... i love bugs.. how much you pay for it?
#672 |
So is the bug the DD or you are getting something else?
#673 |
haha the bug is the DD
![]() i paid only $500
#674 |
Hopefully you are doing a motor swap. My dad had one when he was in college and he said his had no power and couldn't climb hills and that was in central California. They also get pushed around the road by wind and semis.
![]() But it looks sweet and should be fun. |
#675 |
it has the larger dual port engine so that wont be a problem. some tuning and it will be perfect
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
