clgielin's WJ build - Page 36 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > clgielin's WJ build
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 05-12-2013, 06:12 PM   #526
clgielin
2003 WJ
Originally Posted by PhantomWJ View Post
Did you remove the other upper mount? This cause the IRO only has one upper arm?
Exactly. I think it looks clean with the mount removed.
Chris
2003 WJ 4.7L
Build Thread Here: 2003 WJ
Michigan Tech Jeepers #4
Utah JeepCrew #16
clgielin is offline   Reply With Quote Quick reply to this message
Unread 05-12-2013, 06:15 PM   #527
clgielin
2003 WJ
Originally Posted by dillonjm View Post
Looking great. You putting in new bearings and seals too?
New seals for sure. I will probably reuse the carrier bearings, not sure on the pinion. They may be easier to just buy new.
Chris
2003 WJ 4.7L
Utah JeepCrew #16
Unread 05-12-2013, 06:44 PM   #528
dillonjm
I'm kind of a fan of going that route anyway.
You'll want a shim kit to set up the gears anyway, unless you already have some laying around, you might as well just get the whole overhaul kit with bearings, shims and seals at that point.
Just my unsolicited 2 cents.
[B]03 Rubicon[/B] (Weekend Toy) [URL="http://www.jeepforum.com/forum/f176/marshals-03-rubi-2822258/"]Build thread[/URL]
[B]11 Ram 2500 [/B] - H&S tuned 6.7 Cummins (DD/Tow Rig)
[B]05 Liberty Limited[/B] (Wife's): Minor mods, OME/JBA Suspension, 245 70/17 Duratracs
dillonjm is offline   Reply With Quote Quick reply to this message
Unread 05-12-2013, 07:12 PM   #529
clgielin
2003 WJ
I have plenty of spare parts laying around. The front bearings have really low miles, but the bearing on the gear side of the pinion is tough to get off without damaging the cage. I'll see how it looks when it comes apart.
Chris
2003 WJ 4.7L
Utah JeepCrew #16
Unread 05-13-2013, 09:52 AM   #530
85IrocZ-28
Yeah, every time I look under my jeep, I wonder why I still have the UCA on the axle
I really like that JJ, I am considering that as a future upgrade now that I see it in, it should be solid.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY --- [URL=http://www.jeepforum.com/forum/f197/project-yeti-abominable-wj-1125665/]Project Yeti Build Thread[/URL]
85IrocZ-28 is offline   Reply With Quote Quick reply to this message
Unread 05-19-2013, 04:14 PM   #531
clgielin
2003 WJ
The swap has started.
Chris
2003 WJ 4.7L
Utah JeepCrew #16
Unread 05-19-2013, 09:37 PM   #532
dillonjm
Nice! That looks kinda familiar.
Unread 05-19-2013, 09:39 PM   #533
clgielin
2003 WJ
Yeah, but I'm only putting a polished D30 back in
Maybe next time...
Chris
2003 WJ 4.7L
Utah JeepCrew #16
Unread 05-20-2013, 10:58 AM   #534
Geo-Nemesis
have you considered swapping an HP dana 30 ?
'02 Black Overland H.O. V8
Geo-Nemesis is offline   Reply With Quote Quick reply to this message
Unread 05-20-2013, 11:10 AM   #535
wj4play
Jk HP30's use the same knuckles/hubs/axle shafts as the jkd44 - but r&p is smaller.
Also in my research the Front will bolt up to the stock location with minor rework of the trackbar
Sent from iPhone
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline   Reply With Quote Quick reply to this message
Unread 05-20-2013, 08:31 PM   #536
clgielin
2003 WJ
I am 'bolting in' this hydra-lok to save a few axle shafts. My next axle build will be something a little stronger. Let me wear these 35's out first...
Chris
2003 WJ 4.7L
Utah JeepCrew #16
Unread 05-20-2013, 08:34 PM   #537
clgielin
2003 WJ
Swapped the 4.56 ring on the hydra-lok carrier tonight. One step closer to being back on the road!
Chris
2003 WJ 4.7L
Utah JeepCrew #16
Unread 05-20-2013, 11:05 PM   #538
wj4play
How bout a Dana 60 ..... Just kidding, I can understand wanting to save a few bucks .... the hydra lock will be a lot better than what was in there
Also IRO found me a set of 4:88 for the 30/44 combo if you need a little extra umph - I have the quote if your interested
Sent from iPhone
Unread 05-21-2013, 12:00 AM   #539
85IrocZ-28
Looking good Chris. One of these days I will attempt gears, good luck with the install.
Unread 05-21-2013, 06:31 AM   #540
clgielin
2003 WJ
Nitro makes 4.88's for the 30/44a.
I should easily be ready for next month, Will. I am ready to get back over to Moab.
Chris
2003 WJ 4.7L
Utah JeepCrew #16
