clgielin's WJ build - Page 25 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > clgielin's WJ build
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 04-21-2012, 10:51 PM   #361
clgielin
2003 WJ
Originally Posted by PhantomWJ View Post
Looks good. painted black front/rear facia and cladding will make it look much Better.
I like the toupe cladding with the tan paint. As much as I drag my front and rear bumpers on the trail, the black paint wouldn't stand a chance. I wish the door handles and mirrors matched
Chris
2003 WJ 4.7L
Build Thread Here: 2003 WJ
Michigan Tech Jeepers #4
Utah JeepCrew #16
clgielin is offline   Reply With Quote Quick reply to this message
Unread 04-21-2012, 11:38 PM   #362
RedlegWJ
Try one of the silver or gray monstaliners. Order some chip samples and see if one matches your boy color. My brother just got some different silver chips for his silverado.
Gray 99 Laredo with '04 driveline wap. Tons of fun coming soon. Steel bumpers. 5 1/2" IRO coils, IRO adj. track bar. Rancho RS9000 Addco rear sway. 2"x.250" DOM long arms with johny joints. Custom A-arm with ball joint delete (J-joint). JK Moab wheels/ 33x 12.5 x 17 Cooper SST. Bushwacker Flares.
RedlegWJ is offline   Reply With Quote Quick reply to this message
Unread 04-22-2012, 09:27 AM   #363
GraKee99
Rapist Wit
GraKee99's Avatar
Leave it like it is Chris, it looks good.
Brian
WJ, WK, CJ5
GraKee99 is offline   Reply With Quote Quick reply to this message
Unread 04-22-2012, 11:48 AM   #364
801DubJay
Agreed.
'00 WJ Laredo V8 aka Katie
My Build Thread: http://www.jeepforum.com/forum/f197/801dubjay-build-thread-1114628/
801DubJay is offline   Reply With Quote Quick reply to this message
Unread 04-22-2012, 02:08 PM   #365
311LJ
311Popo
311LJ's Avatar
X3, I love it. Looks even better in person
John
04 TJ Unlimited, GenRight Armor, 37's Unlimited Build Thread
89 XJ Laredo, 31's
07 WK Overland, Hemi, Chrome bug deflector
[SOLD] Jimmer 01 WJ *2009 GCOTY* WJ Build Thread
*UTAH JEEPCREW #01*
I ♡ John
311LJ is offline   Reply With Quote Quick reply to this message
Unread 04-22-2012, 06:08 PM   #366
clgielin
2003 WJ
Sounds like I will have to put it on display next weekend at Travis' house...
Chris
2003 WJ 4.7L
Utah JeepCrew #16
Unread 04-27-2012, 10:15 PM   #367
clgielin
2003 WJ
What I thought was the locker acting weird actually turned out to be the tc. I put the 247 back in and the problem is gone. There is now almost no gear/bearing noise which makes me feel a lot better about my gear install. I guess I'll be rebuilding the 242 before June. I am expecting to find a toasted input bearing.
Chris
2003 WJ 4.7L
Utah JeepCrew #16
Unread 04-28-2012, 12:41 AM   #368
85IrocZ-28
That sucks, didn't the PO say it was in good working order?
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY --- [URL=http://www.jeepforum.com/forum/f197/project-yeti-abominable-wj-1125665/]Project Yeti Build Thread[/URL]
85IrocZ-28 is offline   Reply With Quote Quick reply to this message
Unread 04-28-2012, 01:46 AM   #369
801DubJay
That sucks it went out! At least it happened now than on the trail. Are you going to do a full rebuild, chain and all?
Unread 04-28-2012, 07:25 AM   #370
clgielin
2003 WJ
He said it worked, but it was also on a rig with d60/sterling, so it probably didn't see any street time.
I am not sure what I will do until I tear it down. The chain and sprockets looked great when I split the case after I bought it. I'll have to see what kind of debris (if any) is in the bottom of the case now. Don't worry, it will be ready to give Katie a run for her money in June
Chris
2003 WJ 4.7L
Utah JeepCrew #16
Unread 04-30-2012, 04:12 AM   #371
801DubJay
I'm counting on it! I'm going to be a few steps behind your for a while. I can't make up my mind on how I want to do my build... Atlas II, Currie F9 axles, 37's on Spyderlocks, Clayton LA's, yada yada... all on the list, but I don't know if I'm ready to pull the trigger. I may just sell Katie and buy a skate board. I just don't know. So in the mean time, I'm going to closely follow your build thread and imagine that it is my own Keep up the good work, Chris! I'll see you in a month!
Unread 04-30-2012, 08:02 PM   #372
311LJ
311Popo
311LJ's Avatar
Never hear a wrangler referred to as a skateboard ha ha JK..
Chris, jeeps still looking good!
John
89 XJ Laredo, 31's
*UTAH JEEPCREW #01*
I ♡ John
Unread 05-12-2012, 10:08 PM   #373
clgielin
2003 WJ
Found the culprit of the noise in my np242. The outer race of the input bearing is in the middle of a fatigue failure. I don't know if it is caused by miles or if it had been ran low on fluid at one time. Everything else looks good, so I am just going to rebearing the case.
Just for fun I thought I would scrub the case in the parts washer and paint. It should look pretty when it's done.
The two case halves are soaking overnight.
Chris
2003 WJ 4.7L
Utah JeepCrew #16
Unread 05-13-2012, 01:02 AM   #374
85IrocZ-28
Do you have a parts washer in your garage?
My parts washer was made by GE...but Emmy is starting to give me wierd looks when I run Jeep parts through the dish washer.
Unread 05-13-2012, 09:09 AM   #375
clgielin
2003 WJ
I do have a parts washer. It's getting a lot of use now between the Jeep and Goldwing project. I thought about a small benchtop blast cabinet, but the big one at work is working out quite nicely.
Chris
2003 WJ 4.7L
Utah JeepCrew #16
