ChrisHager's 04 WJ Build Thread - Page 22 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > ChrisHager's 04 WJ Build Thread
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 04-14-2014, 04:30 PM   #316
snobrdrkid07
snobrdrkid07's Avatar
Wonderful, I did mine around then too. Specifically June 22nd 2012. Haven't greased them since either... Hmmm.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 04-16-2014, 12:08 PM   #317
billzcat1
Chicken in a Turkey Suit
2003 WJ
Originally Posted by ChrisHager View Post
So, in about a month and a half, I went from a nice working WJ to one with the following parts [possibly] going bad:
Emergency Brake Pads (Normal maintenance - no biggie...)
Electric Radiator Fan Motor
Power Steering Pump (I think it's a leaky hose.)
A/C
Recirculation Door
Heater Core (perhaps)
TRE's
CKS
Awesome.
Mine has pulled similar shenanigans on me since December. One thing after another. Getting real close to 140k though, it's about time that everything original on it starts dying.
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 04-17-2014, 08:19 PM   #318
ChrisHager
ChrisHager's Avatar
That stinks. I hope mine plays nice again soon after I dump some money into it!
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 04-17-2014, 08:30 PM   #319
ZJPunk98
sounds like a typical jeep acting up. Soon as you are happy with everything, something goes bad.
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline   Reply With Quote Quick reply to this message
Unread 04-18-2014, 08:05 AM   #320
ZB_WJ
Hmm, makes me wonder if the fan is what's causing my cow poop smell. I guess it could be mistaken for a garbage smell... I figured it was from mudding in fields. I haven't been overheating, but will check the fan.
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline   Reply With Quote Quick reply to this message
Unread 04-18-2014, 08:17 AM   #321
ChrisHager
ChrisHager's Avatar
Words of wisdom...
I know Harrisburg has a ton of horses/cows. If your WJ literally smells like cow crap, I'd wager either some was missed and needs washed off OR you had a little on your hand when you wiped your nose. That brings a whole new meaning to brown nosing...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 04-18-2014, 09:26 AM   #322
ZB_WJ
Bwahahahaha. I'm going to change my cabin air filter, I think a bunch of cow crap mud got splashed up in there
Unread 05-20-2014, 09:42 AM   #323
ChrisHager
ChrisHager's Avatar
Back in September of 2012, I posted a couple pictures showing how the OME HD springs handled about 750 lbs of cargo weight. The pictures were of 3 kegs, ice, and wine for my wedding reception. Last night, the wife and I were going through our wedding pictures and I stumbled across my 'cooler' used to keep one of the kegs and the wine cool. It worked out very well. Keep in mind, it required a shop vac and a bunch of towels to remove all the water.
Anyway, I figured y'all may get a kick out of it. The first two pictures are from the post linked above.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 05-20-2014, 09:45 AM   #324
snobrdrkid07
Perfect use of the spare tire well! How'd you bail it out?
-Michael-
Unread 05-20-2014, 09:46 AM   #325
ChrisHager
ChrisHager's Avatar
I think I used a 32oz mug to lower the water level for the drive home (the next morning). Once home, I shop vac'ed it out then dried it up with some towels.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 05-20-2014, 09:49 AM   #326
snobrdrkid07
Nice! Not too bad, would be perfect for a tailgate application too. I've seen people plumb drain plugs too.
Any updates on the WJ?
-Michael-
Unread 05-20-2014, 09:55 AM   #327
ChrisHager
ChrisHager's Avatar
A drain would have been handy, though that's the only time I ever used it as a cooler.
The WJ is doing OK. It's kind of nickel-and-diming me right now but I'm hoping if I can get caught up on it, things will level out. Honestly my biggest issue is time. I have parking brake shoes for the WJ and a TON of parts for the J-10 but I have no time to work on either. After this weekend (brother's wedding and son's first birthday party), I hope things will slow down so I can get some parts installed.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 05-20-2014, 11:50 PM   #328
snobrdrkid07
I hear you man, hopefully things will settle down some for the summer. Parking brake shoes should not be too bad to do.
-Michael-
Unread 05-30-2014, 09:03 AM   #329
ChrisHager
ChrisHager's Avatar
Yesterday the family and I took a trip to St. Louis to hit up the Zoo for Elias' first birthday. Besides no air conditioning in the WJ, the trip went well. The WJ drove great and felt smooth the entire trip. I was thankful for no hiccups.
We were able to find close up parking at the zoo because no one was brave enough to squeeze in next to this princess:
Also, I feel it necessary to show off my son because, frankly, he's awesome...
That's about all for the moment. This weekend I may look into the air conditioning problem. I have a feeling it's compressor and/or recirculation door related. I'm open to advice if anyone has some to give!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 06-02-2014, 10:04 AM   #330
ChrisHager
ChrisHager's Avatar
Small update - I believe my recirculation door is perfectly fine AND I found out my compressor is actually working! A few weeks ago, I checked the pressure in the system and was surprised to find it reading high. We checked again yesterday and noted it was low. I threw in 2 cans of R-134a and was greeted with cold air! The only thing I can think of as to why it was reading high is when we checked it a few weeks ago, maybe the clutch on the compressor was stuck? Who knows...
Anyway, I currently have a working A/C system. I'll be watching it this week to see if it lasts. If it does, I may throw in another can of R-134a this weekend as it's still reading a little low on the gauge.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
build thread , chrishager , grand cherokee , ome hd , wj
