ChrisHager's 04 WJ Build Thread - Page 19 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > ChrisHager's 04 WJ Build Thread
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light BaRuffstuff 10 year sale
Unread 09-25-2013, 08:52 AM   #271
ChrisHager
ChrisHager's Avatar
Thanks! It's going to be a lot of fun!
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 10-12-2013, 09:53 PM   #272
question4u92
Why no sway bar disconnects?!?! D:
question4u92 is offline   Reply With Quote Quick reply to this message
Unread 10-13-2013, 09:04 AM   #273
ChrisHager
ChrisHager's Avatar
Haha. I don't take the WJ off-road too often so I skipped them. I just yank the two bolts/nuts on the sway bar when I do get to take her out!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 10-29-2013, 11:49 AM   #274
ChrisHager
ChrisHager's Avatar
Washed and waxed the WJ Friday before the snow (and salt) shows up. Pardon the mess in the reflection!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 10-29-2013, 12:08 PM   #275
billzcat1
Chicken in a Turkey Suit
2003 WJ
Too shiny! Needs more PNW pinstriping.
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 10-29-2013, 12:11 PM   #276
ChrisHager
ChrisHager's Avatar
It is quite shiny! I mainly wanted to protect the paint from salt!
I'd love to head to the PNW to collect some pinstriping! Perhaps someday...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 11-27-2013, 08:25 AM   #277
ChrisHager
ChrisHager's Avatar
My fill up this morning revealed a whopping 10.35 mpg. I'm hoping I let it idle too long or something. If that's not the case, I have an issue to track down.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 12-12-2013, 09:05 AM   #278
ChrisHager
ChrisHager's Avatar
I recently discussed how the WJ drives with my brother and his fiance. After thinking about it, I figured I'd post up what we talked about as a follow up to a previous discussion we've had here.
Back in July of 2012, I replaced my TRE's, Adjusting Sleeves, and aligned the WJ before taking it on a camping trip: http://www.jeepforum.com/forum/f197/...l#post13860475 On that specific trip, I felt that the WJ swayed quite a bit while driving down the interstate. We figured a combination of weight and tire pressure caused the issue.
A couple weeks later, I adjusted the angles of my front sway bar end links in hopes of correcting the issue: http://www.jeepforum.com/forum/f197/...l#post13977704
Fast forward to Tuesday, my brother's fiance confessed that she hates driving my WJ and that it is all over the road. My gears started turning and I realized I no longer have this issue. The WJ drives straight and smooth, even with 4 adults and a baby riding along. The sway bar end link adjustments must have helped as that's the last I've done to the suspension.
Next follow up, the misfire issue I was having back in September has also disappeared. I'm not sure what the issue was during that spell but I haven't witnessed it since then. http://www.jeepforum.com/forum/f197/...l#post15866387
Thirdly, I wanted to post my 3000th post in here. Haha!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 01-07-2014, 08:33 AM   #279
ChrisHager
ChrisHager's Avatar
Saturday night we checked the freezing temperature of the coolant in the vehicles to make sure they were good for the -15F temperatures. All was well until I popped the cap of on the WJ... After a trip to town for some coolant, I found I was about 2/3 of a gallon low. Crap.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 01-13-2014, 08:33 AM   #280
ChrisHager
ChrisHager's Avatar
Last night we hopped in the WJ to head to Fridays and both ReJeana and myself noticed the unmistakable sweet smell of antifreeze when I kicked the heater on. Most likely, my heater core has a small hole which explains the lost coolant. I'll keep an eye on the coolant level to verify a leak but I foresee a long Saturday ahead.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 01-13-2014, 09:13 AM   #281
billzcat1
2003 WJ
I fixed mine with the Blue Devil sealant product. Might be worth looking into.
Unread 01-13-2014, 09:14 AM   #282
ChrisHager
ChrisHager's Avatar
I shall look into that sir! Thanks!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 01-29-2014, 08:48 AM   #283
ChrisHager
ChrisHager's Avatar
After changing the oil and rotating the tires, we went to a friends house to watch the fights the other night. When we arrived, RJ parked a little crooked because the spot next to us had a bunch of snow piled up. My friend's roommate was teasing us because of our parking so I moved over for her... Needless to say, RJ had trouble getting in.
The quality isn't great but the pictures are still fun.
Curtis making sure she doesn't fall...
Almost dropped a spring...
Also, while grabbing the above pictures off of Photobucket, I saw these from a long time ago. Remember when the grass was green?
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 03-04-2014, 11:59 PM   #284
2GPS4ME
Someone probably asked already, but what receiver did you go with?
I like the fit
WJ (WIFE JEEP) PROJECT COMING SOON
2GPS4ME is offline   Reply With Quote Quick reply to this message
Unread 03-05-2014, 08:20 AM   #285
ChrisHager
ChrisHager's Avatar
The hitch, bezel, and wiring harness I installed is all factory. I think they're difficult to find new but a junk yard will probably have them!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
build thread , chrishager , grand cherokee , ome hd , wj
