ChrisHager's 04 WJ Build Thread - Page 16 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > ChrisHager's 04 WJ Build Thread
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 07-09-2013, 09:11 AM   #226
ChrisHager
ChrisHager's Avatar
Small little project this past weekend - while it isn't WJ related, perhaps someone with a TJ browsing through my thread may appreciate this.
The problem I had is every time I remove the doors on the TJ, I end up setting them on the floor. I don't prefer this because I'm afraid they'll either get knocked over or end up in the way. If they're not on the floor, they end up on the garage futon. Clearly, that can't happen!
Solution: Hang them on the wall.
I bought some 1/4" x 3-3/4" eye bolts with a center hole large enough to accept the door stud. I then attached a couple scrap 2x4 to the wall and threaded the eye bolts into the 2x4. This is necessary because the eye bolts aren't long enough mounted only into the wall to allow the doors to swing flat against said wall. End result, no doors on the floor to knock over!
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 07-10-2013, 12:53 AM   #227
Y0ungGunZJ
can you mount a hoop on the wall? so the doors stay against the wall. so it would act as a door latch. some sort of small u bolt should do with some 2x4
_______._____. << ----Mine------____.____.
//_|__l__,\____\,___------Dads>> /l __,[____],_
l_--\__\__l---\[]llllll[]| -----------l--|_|-L-OllllllllO-
(o) )-o---(o) )---o-) ) ---------(o) )-o-(o) )--o-) )
Y0ungGunZJ is offline   Reply With Quote Quick reply to this message
Unread 07-10-2013, 08:12 AM   #228
ChrisHager
ChrisHager's Avatar
That would work! The way mine worked out, they stay against the wall quite well. With that said, adding something to allow the door to latch to the wall would reduce the amount of weight on the eye bolts. Nice thinking!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 07-11-2013, 08:29 AM   #229
ChrisHager
ChrisHager's Avatar
I'll just put this here...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 07-17-2013, 12:29 PM   #230
Merc1973
Any luck with fixing the wandering issue? I'm at my whit's end with mine. Hopefull IRO front adj LCA's will do it.
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline   Reply With Quote Quick reply to this message
Unread 07-18-2013, 08:21 AM   #231
ChrisHager
ChrisHager's Avatar
I haven't noticed any major wandering like I did on the way to the camping trip last summer. I think my problem back then was the fact that it was loaded down. After that trip, I put the stock length sway bar end links back in the front which I feel helped a bit.
Ultimately, if you have a wandering issue or find your jeep is dog tracking, there's a very good chance it's caused by worn out bushings, especially in the A-arm...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 07-18-2013, 09:12 AM   #232
ChrisHager
ChrisHager's Avatar
Per tread wear on DuraTrac 245/75R16 C tires:
I mounted these tires right at about a year and a half ago and have put a little over 20,000 miles on them, rotated every 5-7k. Most has been city driving with a little highway and a little off road. They've seen all types of driving conditions and have performed wonderfully in everything.
They come with a tread depth of 18/32". After this long, mine are currently sitting at 13/32". That's 5/32" of wear in 1.5 years/20k miles. Not to bad!
Here's how they currently look:
About the picture above of my misfire codes - I haven't heard report that it has happened any more (the wife is still driving it). I bought new spark plugs I'm hoping may take care of the issue. They're cheap and about due to be changed any way. I'll be keeping a close eye on it, that's for sure!
Oh, this finally arrived as well!
If the heat doesn't run me out of the garage this weekend, I may see about installing these new parts.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 07-18-2013, 10:52 AM   #233
snobrdrkid07
snobrdrkid07's Avatar
My wondering issue greatly improved with a whole new a-arm. Keeps the back end where it should be. So check out those bushings on the a-arm!
Chris, what is up with all those codes?!
Tires look good, and the trans cooler will be a fun little project!
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 07-18-2013, 10:54 AM   #234
Merc1973
Yeah thats what everyone says. All ball joints, a-arm ball joint, steering gear, KOR JKS TB bushings, control arms (IRO front upper and crown all other) and bushings have been replaced this year. Even the TRE's seem tight and are 3 years old. I hope its just a caster issue. Even if I hold the wheel straight it zig-zags in the lane and have to be careful not to over-correct or i might run someone off the road. The local 4x4 shop couldn't find anything wrong and i'm Seriously thinking about selling it...
ΜΟΛΩΝ ΛΑΒΕ!
Unread 07-18-2013, 11:04 AM   #235
snobrdrkid07
Caster plays a big part in it as well. I'm running around 6.7* of caster with my OME HD lift.
-Michael-
Unread 07-18-2013, 11:23 AM   #236
ChrisHager
ChrisHager's Avatar
The EVAP codes have been there for ever - if I remember correctly, they showed up not long after I bought it. I haven't taken the time to replace what I assume to be cracked hoses. I'll probably get on it soon though...
As for the Cylinder 5 Misfire and Multiple Misfire codes that just popped up, I'm not sure. RJ was driving and called me telling me it was stumbling. I told her to park it, shut it off, then restart it. She did her shopping and when she went back to the WJ and started it, everything was fine.
When she got home, I hooked up the scanner and tried to clear the codes with no luck. I then revved it high in neutral to see what it would do. It ran smooth but flashed the CEL (I'm assuming it was missing just slightly enough that I couldn't feel it).
Since then, it appears to be driving fine.
Like I said above, I'm going to replace the plugs and see how that goes. Since it's not repeating the issue, I'm hoping all is well. I'm a little worried though because these are the same codes I was getting when I had to replace the cam and lifters. If it comes to that again, I have two options. The 'fun' option probably won't be what I choose.
Wow... That sounds really bad. I can't believe it's doing that with everything you've replaced.
I'm wondering if adjusting the caster would help too...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 07-18-2013, 11:33 AM   #237
snobrdrkid07
Well that is pretty weird man. I would really doubt that the new lifts and cam are already "worn" or such. Hopefully the spark plugs are just old and need replaced. I do spark plugs ever 20-25k miles just because.
Eeeek, lets hope again that it is just something simple!
Yeah that is way out of the ordinary, something is still definitely wrong. I would start by getting the torque wrench out and also doing a "shake down". Have someone get in there and turn the wheel back and forth and see if you can feel any clunks, pops, looseness, or anything out of the ordinary. Regardless of the outcome I would still get the torque wrench out and crank that baby up and make sure everything is TIGHT! I don't know how "correct" this is but, I set my torque wrench to about 10-15% above factory torque specs.
-Michael-
Unread 07-18-2013, 12:00 PM   #238
ChrisHager
ChrisHager's Avatar
In a good engine, they shouldn't be worn already. The thing that worries me is, while I installed everything properly, if there was something wrong with the lifter bore, it could cause the lifter to not rotate thus destroying itself and the camshaft.
I'm looking too far into this though. Spark plugs could clear it right up. My mind went to the worst case scenario because that's the same cylinder that had the problem last time.
I guess time will tell...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 07-18-2013, 12:05 PM   #239
85IrocZ-28
I had to return a set of Duratracs because they caused horrible wandering...It is too bad, I love the look and performance of them but they just didn't work for me. They were load range E though, that definately played a factor.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY --- [URL=http://www.jeepforum.com/forum/f197/project-yeti-abominable-wj-1125665/]Project Yeti Build Thread[/URL]
85IrocZ-28 is offline   Reply With Quote Quick reply to this message
Unread 07-18-2013, 12:06 PM   #240
snobrdrkid07
I am the same way, something small out of place or incorrect can really set me off sometimes towards the worst case scenario. Need to work on that for me haha.
I'm impressed though, would have never been able to dive into the engine like that.
-Michael-
build thread , chrishager , grand cherokee , ome hd , wj
