ChrisHager's 04 WJ Build Thread - Page 5 - JeepForum.com
post #61 of 469 Old 07-11-2012, 04:08 PM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
Yeah you have a good start on replacing possible bad components. I'm hoping I find something obvious here in the next half hour or so. I would be surprised if it's control arm bushings but then again, I've been surprised by less.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is online now
post #62 of 469 Old 07-11-2012, 04:10 PM
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Yeah, that's why I am concerned haha. Control arms, oh dear, please no haha.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #63 of 469 Old 07-11-2012, 05:32 PM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
Mind my ignorance on the technical terms. I know what everything does but I'm not well versed in the terminology. I believe I have it correct though. I *think* it's the TRE's on the drag link. The passenger side seems to have some play in it, the boot is dried out, and when turned by hand, it makes a clunk noise (the ends on the tie rod do not)...
There seems to be a tiny tiny bit of play on the driver side KOR bushing on the track bar but it's minimal of it is even truely moving.
My steering stabilizer seems to be good and one control arm bolt needed a few more ft-lbs on it. I also amped up the track bar bolts to 100 ft-lbs.
I'll start with the drag link ends and go from there. Unfortunately, I'm not going to be able to do that until after my trip to Missouri... :-(
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #64 of 469 Old 07-11-2012, 06:03 PM
snobrdrkid07
WJ for Life
Well, I guess we shall see if that tie rod will help out some. I just dont know what else it could be! Haha.
I may get some adjustable ball joints to add more caster or fixed ball joints to that add caster. I have a feeling that would help out and keep things more stable.
-Michael-
post #65 of 469 Old 07-11-2012, 08:34 PM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
Which brand did you get that was so beefy and if you don't mind, how much did it cost? I think I saw it in your thread but don't quite remember...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #66 of 469 Old 07-11-2012, 08:37 PM
snobrdrkid07
WJ for Life
All 4 Moog Greaseable tie rod ends and the Moog adjusting sleeves all for under 200 shipped. That might be high, ill have to x2 check.
Sometimes I wonder why I lifted the WJ, I knew it wouldn't be simple. Even at a BB height, still issues out the wazoo. I am pretty sure my JKS bushings are squeaking when I turn the wheel, awesome.
-Michael-
post #67 of 469 Old 07-11-2012, 09:00 PM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
Awesome I was hoping they were Moog.
We lift the WJ because we love the WJ!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #68 of 469 Old 07-11-2012, 09:06 PM
snobrdrkid07
WJ for Life
Yup Moog is awesome. Don't forget to add a discount coupon (that you can find on Google) for your Rock Auto Order.
I love my WJ too, I just need to realize it won't ride the same and just because it does not ride the same as stock, does not mean it is broken. I just have to get used to the differences. *knock on wood* Even with the bad stock track bar I hit a pot hole and it DW'd for a second and then came back and didn't KEEP wobbling. That says something. I am still getting used to the movement in the steering wheel on bumps and the little shake on the occasional bump.
-Michael-
post #69 of 469 Old 07-11-2012, 09:33 PM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
I doubt they would ever ride the same. We can work hard to make them ride like glass but unless long arms and countless hours are involved, there is a price to pay to customize a vehicle to how we want it. That being said, any lifted WJ (when done properly and in good form) should ride well.
Perhaps I have a stupid question but I really don't know the answer... Are the TRE's for the tie rod the same as the TRE's for the drag link? If so, I can get MOOG TRE's from O'Reilly Auto Parts for $43 (might be for the set). If that's the case, I could whip this out tomorrow night for a great price and be ready for the weekend trip!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #70 of 469 Old 07-11-2012, 09:39 PM
snobrdrkid07
WJ for Life
I just want to feel confident going down the road and not have to sweat over every bump? You know? Haha 4" long arm would be sick
All 4 Moog tie rods had different part numbers man. They were all different.
-Michael-
post #71 of 469 Old 07-11-2012, 09:56 PM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
I know what you mean!
After I sent that last message, I looked at the options they had and realized there were 4 which makes sense. Haha its getting late and I was being hopeful. Either way, if one of the 5 O'Reilly stores here in town have them in stock, I don't think that's a bad price, though they do have cheap ones for $20 (I prefer doing the job once with good parts though ). My hope is they have them in because my brother is coming into town tomorrow and with his help, we should be able to tackle them all tomorrow after I get off work. I might do all 4 and align it Friday morning before I leave. The only problem is I've been known to bite off more than I can chew...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #72 of 469 Old 07-11-2012, 10:03 PM
snobrdrkid07
WJ for Life
Oh yeah man. I've been scared with the Rubicon nightmare.
Yeah, I'd do it right the first time with Moog if possible. Who knows, maybe you will get lucky and get the Moog parts you need man. Don't feel like you have to know it all man, you should have seen some of the posts that I made when i first joined lol. We are all here to learn and help one another! Haha, kinda like me, I always seem to bite more then I can even chew, let alone swallow hahaha.
-Michael-
post #73 of 469 Old 07-11-2012, 10:12 PM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
It's funny how fast I've learned because of this site. A year ago, I was learning about lift heights and now I'm advising on them. I also never thought I would be tearing down my engine 6 months after buying the jeep. Live and learn and spend money. It's really the only way. Steering is new to me but I bet in the next week or two ill be an expert.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #74 of 469 Old 07-11-2012, 10:21 PM
snobrdrkid07
WJ for Life
This is my two year anniversary. Wow actually, dang. I stalk this site like I do with Facebook and others. Then my "build" aka chat and discussion thread has a stupid amount of pages. I can safely say that I have learned A LOT, but there is always more. I guess Arlo who had said, "don't lift on a budget" was not kidding at all!
Question, have you checked out your rear a-arm at all? Still in good shape?
-Michael-
post #75 of 469 Old 07-12-2012, 06:28 AM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
I haven't checked my rear a-arm. Besides a very slight occasional wandering (which might be cause by whatever is bad in the front), I haven't had any reason to check it out...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
build thread , chrishager , grand cherokee , ome hd , wj
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
AGs build thread AGDubyaJ Grand Cherokee General Discussion 2 03-13-2011 11:41 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
yet another 96 zj build thread b2k Grand Cherokee General Discussion 15 09-02-2010 07:35 PM
