ChrisHager's 04 WJ Build Thread - Page 18 - JeepForum.com
post #256 of 469 Old 08-28-2013, 10:18 AM
Ravie
Ah, makes sense. I've been a long user of photobucket too.
1999 WJ - Over 10k on the 4.0 rebuild. FB/BDS 2" lift (2.5") w/Bilstein 5125's. General Class Ham...KC0LUA
Burlbook48 sez "Nothing moves a project along faster than cubic dollars." Certified Thread Killer.
Ravie is offline
post #257 of 469 Old 08-29-2013, 08:28 AM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
My pictures should be back up! The combination of this and my grilled thread really must burn through the bandwidth at Photobucket!
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #258 of 469 Old 09-03-2013, 07:45 AM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
I forgot to post this last week but ReJeana had more issues with the WJ last Monday. As she described it, she said it felt like the transmission was revving high (50ish MPH and not shifting into overdrive). Shortly after that, the gas pedal seemed to sink to the floor yet the WJ started slowing down. All this was accompanied by a flashing CEL. She pulled over, turned it off, turned it back on, and everything was fine again - has been for over a week.
I'm starting to think TPS. Thoughts?
Here are the codes:
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #259 of 469 Old 09-03-2013, 08:31 AM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
Also, I received some parts for an upcoming project that may interest many of you...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #260 of 469 Old 09-03-2013, 08:34 AM
Ravie
OooOOoooo! Shiny things!
Ravie is offline
post #261 of 469 Old 09-03-2013, 02:17 PM
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
I'm not sure how the TPS would correlate to the Multiple Cylinder Misfire. Then again this is out of my area of knowledge.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #262 of 469 Old 09-05-2013, 07:45 AM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
TPS is known to do some crazy things. I'm going to let it go for a while and see what happens. Everything else seems fine and it only does this once in a while.
In other news, I think it's happened - I believe the wire in my driver's door has cracked! It was only a matter of time!
I think I need to give the WJ a little TLC - fix the wire in the door, tweak the CB, fix the EVAP leaks, and wash her up a bit. Maybe then the misfire codes will go away - she's just grumpy because I'm not giving her any attention.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #263 of 469 Old 09-05-2013, 08:33 PM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
Quick question and I'll do some searching when I'm not on my phone but why would my E-Brake light not light up when it is engaged yet the light isn't burned out?
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #264 of 469 Old 09-06-2013, 12:56 AM
85IrocZ-28
The wire could have come off of the sensor at the lever, or a problem with the sensor at the lever.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #265 of 469 Old 09-06-2013, 07:13 AM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
That's what it looks like:
Originally Posted by http://www.wjjeeps.com/parking_brake.htm
The parking brake switch is in circuit with the red warning lamp in the dash. The switch will cause the lamp to illuminate only when the parking brakes are applied. If the lamp remains on after parking brake release, the switch or wires are faulty.
That's another thing to add to the list of stuff to fix if I get time on Sunday.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #266 of 469 Old 09-22-2013, 07:17 AM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
Added another one to the stable last night! The parts pictures from a few weeks ago are for this vehicle. Teaser pic we lucked out to get on the drive home:
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #267 of 469 Old 09-22-2013, 12:51 PM
Ravie
hehehe. I KNOW! I KNOW!
Ravie is offline
post #268 of 469 Old 09-22-2013, 03:34 PM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
Hahaha yes you do! We've been tuning the old carb all day. We are thinking about slapping on the new ignition, intake manifold, and holley carb next weekend. Pictures will be up hopefully tomorrow along with a new build thread.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #269 of 469 Old 09-24-2013, 08:33 AM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
Here she is! ChrisHager's 79 J-10 Build Thread
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #270 of 469 Old 09-24-2013, 10:29 AM
motodude248
That is a very nice looking Jeep. Congrats.
motodude248 is offline
build thread , chrishager , grand cherokee , ome hd , wj
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
AGs build thread AGDubyaJ Grand Cherokee General Discussion 2 03-13-2011 11:41 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
yet another 96 zj build thread b2k Grand Cherokee General Discussion 15 09-02-2010 07:35 PM
