Can I remove front Ujoints and still drive? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Can I remove front Ujoints and still drive?
Smittybilt Hard Tops @ Oconee Off-Road! 706-534-9955XHD Heavy-Duty Hood Latches for JK and TJ available at OcoFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 08-30-2014, 07:11 PM   #1
tkplaster
1999 FSJ Cherokee
I've got a lot of front end noise and sounds like bearing grind from the
front wheel areas. After having the rear end rebuilt I can't quite afford to have
the front end and transfer case worked on. Can I just remove the U-joints of
the front wheels and the shaft from the transfer case and not hurt anything?
tkplaster is offline   Reply With Quote
Unread 08-30-2014, 08:06 PM   #2
derekmac
derekmac's Avatar
You can remove the front drive shaft and drive like that, it won't hurt anything.
2002 WJ Olympics Commemorative Edition
245/70-17 Duratracs
2" BB
Future: 4" lift and lockers
Build thread.
http://www.gofundme.com/d8jlwo
derekmac is offline   Reply With Quote
