Bushing help? Time to replace? - JeepForum.com
post #1 of 6 Old 11-14-2010, 01:33 PM Thread Starter
TontoKowalski
I don't know crap about this and could use some advice.
My ZJ is annoyingly squeaking over every bump in the road.
Do these bushings look like they need to be replaced?
If so, it's best to go with OEM rubber ones right? Doesn't that cut down on squeaking, right?
Oh yes, that white chalky sh*t is white lightning grease. It seems to help out just a little bit.
This one looks chewed up up in the front. Looks like something was ruptured and leaked out maybe? No clue. The lip up front is dented.
This one looks worn away on the bottom left side. Like it hasn't been replaced in 14 years or so...which I'm positive is the case.
And this one looks OK, but it's really soft. I can squeese it pretty easily with my fingers.
TontoKowalski is offline
post #2 of 6 Old 11-14-2010, 07:29 PM
BlackDaddyZJ
1994 ZJ
if you can swing it, id go with one of those bushing kits from energy suspension, the poly bushings will ride so much better than the oem rubber, plus they wear a lot longer and dont split if the get cold a lot. the first pic you showed i dont think that bushing can be replaced by istelf but im not 100% on that
Bob
'94 ZJ
5.2L
IRO 4.5" Lift
35x12.5 Mickey Thompson Baja MTZ's
98 5.9
Restored and daily driven
BlackDaddyZJ is offline
post #3 of 6 Old 11-14-2010, 10:00 PM Thread Starter
TontoKowalski
do you know how I can determine what kit I'll need?
they've got a bunch of different sizes here:
Energy Suspension Parts: Grand Cherokee, Jeep Grand Cherokee 1996
post #4 of 6 Old 11-14-2010, 10:27 PM
Kolak
Vendor
Kolak's Avatar
I'll be happy to assist you in replacing the various bushings on your Jeep. Send me a PM and we'll chat.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is online now
post #5 of 6 Old 11-15-2010, 08:53 AM
AlphaLorde
do not run a poly bushing on something you want to ride nice
they are squeaky and dont absorb the bumps as well as the rubber. they transmit the feeling right to you
oem rubbers lasted over 200k on mine so
now if you are racing polys might be the better an opition because they will keep everything a firmer
1998 ZJ Laredo 5.2L 139k 231 w/SYE artec trussed 8.8 4.25"F/5"R lift
AlphaLorde is offline
post #6 of 6 Old 11-15-2010, 09:58 AM
SnowLeopard
I have the Energy bushings on my swaybar, but one is coming apart, I believe. I'd have to crawl under the Jeep and check, but last I looked it wasn't look fantastic. I'm keeping an eye on it. I keep them greased, too.
SnowLeopard is offline
Time to replace O2 Sensors DRE97 ZJ Grand Cherokee Forum 7 01-20-2010 06:54 AM
what are these bushing called? trying to replace... 19psi ZJ Grand Cherokee Forum 12 10-24-2007 10:51 AM
Transmission- time to replace fluids etc...help! REDLYNER ZJ Grand Cherokee Forum 34 06-13-2007 08:17 AM
Time to replace the radiator - need help FishFan ZJ Grand Cherokee Forum 2 03-27-2004 08:47 AM
