Quantcast Building the White Whale (SaturnICL's build) - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Building the White Whale (SaturnICL's build)
Closed Thread
Old 07-29-2009, 09:22 PM   #91
Jones
Infowars.com
Jones's Avatar
Looks the same as three posts up.
What is it about Ron Paul?
Jones is online now
Old 07-29-2009, 09:31 PM   #92
-Shoey-
I'm no Sherlock, but that just might be the wrong pic.
2002 Grand Cherokee Limited
2004 Chevrolet Tahoe Z71
USN Jeep Club #115
-Shoey- is offline
Old 07-29-2009, 09:38 PM   #93
SaturnICL
SaturnICL's Avatar
I uninstaled the steering gear and broke it down.
I drilled and taped the top and side port!
I used 1/4 o-ring to 3/8 flair adapter.
SaturnICL is offline
Old 07-29-2009, 09:42 PM   #94
SaturnICL
SaturnICL's Avatar
It is I just wanted to show it in the build with the description of the ram I used
Keep reading the rest is coming I had to upload my pic's to photobucket My camera wont even take pictures with a small enough file size for this forum
Old 07-29-2009, 09:47 PM   #95
SaturnICL
SaturnICL's Avatar
Welded on the tabs for the draglink.
And the tab for the axle side I welded to the front of the spring perch.
This way the ram is high and tight to help protect it from rocks... I liked this location better than the usual place everyone mounts them (in place of the stock steering stabilizer) It seemed to vulnerable there!
Old 07-29-2009, 09:49 PM   #96
SaturnICL
SaturnICL's Avatar
Old 07-29-2009, 09:55 PM   #97
UTChavok
When are you planning on dumping the 30? I wouldnt of even wasted time with hydro assist on a 30 when your running 37s. Looks sweet though.
UTChavok is offline
Old 07-29-2009, 09:58 PM   #98
SaturnICL
SaturnICL's Avatar
And for Sandman here are some better pictures of the work in progress boatsides:
Here is a dark picture of the 3"x4"x3/8 box tube I welded to the uniframe between the link brackets.
I still need to finish off the front and rear of the "boatsides angle pieces" I am going to box it in so it is smooth in the front and rear. I also have to cut in pieces to smooth the transition from the boatsides to the link tabs. After I will run a piece of plate from the new frame-rail to frame-rail for a flat belly
Old 07-29-2009, 10:02 PM   #99
SaturnICL
SaturnICL's Avatar
The Superduty's are a few weeks off now so I didnt want to wait for the hydro assist regarless of axles it is nicer to turn the 37's. Now its done and the new axle will just need new tabs welded on!
Old 07-29-2009, 10:08 PM   #100
SaturnICL
SaturnICL's Avatar
I got ahead of myself and forgot to take pictures of the steering pump modification. I drilled out the high pressure side and added a spacer washer under the spring in the piston to increase pressure! I works awesome it almost turns to quick now instead of the lag most feel with a taped WJ box and stock pump
Old 07-29-2009, 10:10 PM   #101
-Shoey-
Pretty awesome dude!
USN Jeep Club #115
-Shoey- is offline
Old 07-29-2009, 10:14 PM   #102
Jones
Infowars.com
Jones's Avatar
I'm jealous. Ram assist would be badass, how much was it?
Jones is online now
Old 07-29-2009, 10:37 PM   #103
SaturnICL
SaturnICL's Avatar
Doing it myself made it low cost. $125 for ram + $19 shipping, hoses were $29 each full assembly's, and a quart of steering fluid. I'm into it $206.99 and my sweat
Old 07-29-2009, 11:06 PM   #104
-cAcHe-
Keeps getting better and better!!! i have said it once and will say it again.... I LOVE YOUR WJ!!!! hahaha...
www.desert-hooligans.webs.com
Originally Posted by CarolinaWK View Post
I like happy endings :2thumbsup:
RIP Troy Edwards (bigbluezj94)
-cAcHe- is offline
Old 07-29-2009, 11:19 PM   #105
Jones
Infowars.com
Jones's Avatar
That's it? I thought it would've been way more.
Jones is online now
Closed Thread
Glock Forum
