Build Thread - Project Lowis
| View Poll Results: How much lift? | |||
| 4.5" |
14 | 26.42% |
| 5.5" |
39 | 73.58% |
| Voters: 53. You may not vote on this poll | |||
#1306 | ||
Mongo-fabbed
With the Rubi's -No paying for regear -No sourcing parts/waiting for deals -Less risk of error (say brackets get welded on incorrectly, you find out you have cracks in the housing, etc etc) There was an article in a magazine about the swap . . . not sure if it was JP or 4 wheel and offroad or what, but it definitely make it look pretty straightforward as far as axle swaps go. I'll try to find the link. After all of this . . . keep in mind that I haven't done the swap myself. Just something I've put some thought into.
Think Twice Garage "I guess I'd just run it?" |
#1307 |
the jk 44s are just a really simple way to go about it. but you will have a lot more fun and feel more accomplished building the waggys. Plus my buddy has got a set in his garage and they are stout! haha Its really all up to you man. If it were me, i would realize that eventually you are going to graduate college, get a good job, move out and by something more reasonable as a daily driver. Then you'll wonder why you dont have 1tons under it. hhaha
94 Grand Cherokee Laredo ZJ, lifted, 37s, yada yada yada
BigBlue build 33s, 6in lift and short arms http://www.jeepforum.com/forum/f197/bigbluezj94-build-thread-679496/ BigBlue build 3/4 ton axles, LAs, 37s http://www.jeepforum.com/forum/f197/3-4-ton-zj-build-818891/ 99 Grand Cherokee Laredo WJ, 4.7 liter, 247 Quadra Trac II, fully loaded |
#1308 | |
Infowars.com
What is it about Ron Paul?
#1309 |
Mr. Hyde!
I thought that was a TJ thing as well...JKers are throwing 37's on the stock axles and I hear of more axle TUBES breaking then axle shafts.
'04 WJ, 6" Clayton LA's, 242 SYE, 35" BFG MT KM2's, 4.56 gears, & D44a locked |
#1310 |
Mongo-fabbed
AFAIK, the JK 44 is a true 44 . . . no D30 outers. That was TJ Rubicon.
#1311 |
yea I just realized you were talking about jk's haha yea jk's are better because they are true haha
My marshmallow build http://www.jeepforum.com/forum/f12/my-marshmallow-build-873442/ |
#1312 |
The JK 44's are a true 44, its the TJ 44 that uses Dana 30 outers.
#1313 |
OK OK OK lol I was wrong about the outers but the lockers do suck haha well if your into running stuff open they do
#1314 |
Infowars.com
I've been doing a lot of research today and the JK axls are selling for ~$4,500 for the pair (with no brakes) and not much cheaper if they're used and the price keeps going up. If I'm going to spend that much on axles I want them to be exactly how I want it and not have to compromise with gears, etc.
Here's some pictures of what the Waggy axles look like. They look like they're in pretty good shape. ![]() ![]()
#1315 |
just buy the waggys for heavens sake
#1316 |
Infowars.com
I got the real price of the JK 44's, $2900 for the front and $2300 for the rear.
Update: So I'm going with my orginal plan of building up the Waggy 44's. Picked them up today from the seller for $350. Holy crap, the front axle is so heavy and being 100+ degrees out didn't help much either. Well here they are sitting in the back of my jeep. They're gunna stay there till I can get some help to take them out. ![]() The plan is still the same. TnTcustoms.com Wagoneer Dana 44 Truss Upper Control Arm Mount (P) HD Lower Coil Mounts Upper Control Arm Mount (D) Factory Track Bar Mount HD Lower Control Arm Mounts bjsoffroad.com Detroit Lockers 4.56's w/ Master Installs Rotor/Hub Assemblies Warn Locking Hubs Wheel Bearing Kits Rear Axle Bearings and Seals Kits Ball Joint Kits Spindle Bearing Kits ClaytonOffroad.com Rear Long Arms Bilstein Shocks Coil Springs Axle Bracket Kit Track Bar Dutchmanms.com Custom Chromoly Shafts eastcoastgearsupply.com Alloy USA Chromoly Shafts Solidaxle.com Dana 44 Solid Diff Covers tsmmfg.com Disc Brake Conversion with Calipers TirePackage.com 5 BFG KM2’s
#1317 |
Good choice Brian, it will be a great build up thats for sure...
#1318 |
Nighthawk
Looks like you need some different rims...
Built Not Bought #037 Project Blue Moon Build Thread > > > http://www.jeepforum.com/forum/f197/moonyjohns-project-blue-moon-2000-wj-1009379/ 1996 ZJ 4.0 - [SOLD] 2000 WJ 4.7 - 5.5" Front IRO LA, 2" Front spacers, Bilstein 5125 12" travel, JKS BPE's, 35/12.5 Goodyear MT/R Kevlar, 15x8 3.75" MD 72 Series, SOLID D30 cover, BTF D44a cover, Cobra CB, 4' Firestik, Alpine iDA-X305, Alpine SWE-1243 Sub, Homemade sliders, Laredo Style Headlights, 20% window tint, D-ring shackle, Custom front bumper, Procomp 9" Lights, Gas tank lift, XRC-8 Winch w/ Synthetic, K&N FIPK Intake Kit, Magnaflow High-Flow Cat, FM50 series, Amsoil 6x9 Filter, LED tailights, Alpine Door Speakers & Tweeters, Custom Rear Swing Out Bumper w/ Spare |
#1319 |
Infowars.com
Yep, 6 on 5.5 wheels. I'll probably go with cragars.
#1320 |
Infowars.com
How the hell do I get the rotor of the front axle? Do I have to take off the hub cap? Yes I took off the caliper already.
Edit: for my front waggy 44 not the Dana 30.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
