Build Thread - Project Lowis - Page 177 - JeepForum.com
View Poll Results: How much lift?
4.5" 14 26.42%
5.5" 39 73.58%
Voters: 53. You may not vote on this poll
post #2641 of 2651 Old 06-06-2012, 05:29 PM
Ricochet88
Do it! Then John can have someone to wheel with at gsw!
Rick "woody"
93 zj wagoneer pkg, 5in iro lift, 33/10.5/15 bfgoodrich km2
my build thread
R.I.P. TROY EDWARDS "bigbluezj94"
Ricochet88 is offline
post #2642 of 2651 Old 06-06-2012, 10:53 PM
311LJ
311Popo
311LJ's Avatar
Originally Posted by Jones
Did I lock it? There's no Moderator log in your thread and I can't remember but I don't think I did. I guess it's one of the perks of being able to lock/unlock threads.
I miss Moab and I miss having a Jeep! I don't want another Grand Cherokee though. Maybe a JK Unlimited Rubicon.
I think it was Arlo, people would ask me questions about my build and he closed it.. Lame.
John
04 TJ Unlimited, GenRight Armor, 37's
89 XJ Laredo, 31's
07 WK Overland, Hemi, Chrome bug deflector
[SOLD] Jimmer 01 WJ *2009 GCOTY*
I ♡ John
311LJ is offline
post #2643 of 2651 Old 08-01-2012, 09:04 PM
LoPhat
OK ... I'll start by admitting that I suck for not keeping this thread more up to date. I'll have to post some build updates and pictures soon. For the moment, however, let me quote the following:
Originally Posted by Jones View Post
I'm about ready to push this thing off a cliff. In the last month I've had to replace the alternator, fix the A/C, replace the radiator, thermostat, and upper and lower radiator hoses. The exhaust has a huge crack in it before the cat and is falling off (it sounds really cool though lol), the steering wheel is off center (easy fix), the brakes pulsate, and there's a loud groaning noise when I let off the gas at freeway speeds.
I'm feeling a bit like pushing this Jeep off of a cliff myself at the moment. The A/C was fixed again, the exhaust system has been repaired three times, the brake rotors and pads have all been upgraded with new parts, the brake master cylinder has been replaced three times, the brakes have been bled more than a dozen times, and there is still a loud noise when letting off the gas at freeway speeds. We'll come to this stuff later...
What's bothering me right now is the Jeep's cooling system. In temperatures over (roughly) 95 degrees the ZJ runs too hot. I know the thermostat is OK because it will hold a perfect 195 in cooler weather. With the Arizona summer here, however, I see the temperature gauge showing around 215 to 225 degrees. It can take quite a few miles to get to that temperature (it gets there quickly at faster speeds), but once it is up there it won't come back down even at idle.
Brian replaced the radiator, thermostat, and hoses in July of 2011. Shortly after that I bought the Jeep and experienced problems with it running hot. It turned out to be the electric fan. It had so much dirt and carbon inside of it that the low speed setting wasn't even working. I thoroughly cleaned it, and the Jeep held a perfect 195 degrees for the remainder of that summer and then all through the winter. With it running hot again this summer, I once again checked the fan. It was working, but the high speed setting seemed a bit weak. This week I opted to replace the fan with a new one, but it didn't change a thing.
So other than the water pump, what's left that hasn't been replaced and/or could be causing the Jeep to run so hot?
LoPhat is offline
post #2644 of 2651 Old 08-01-2012, 10:06 PM
MurdaJs
well it is pretty damn hot in arizona
MurdaJs is offline
post #2645 of 2651 Old 08-02-2012, 02:03 AM
joze
You might want to check out last few pages of narnwv's build thread, he has a wj though but pretty same problem with the 4.7 running hot. He installed a Taurus fan and as far as I know now he's a happy camper.
Originally Posted by Ljohn221 View Post
You can't start a new civilization without jeeps
Originally Posted by dukie564 View Post
Epic boobs saving threads since 1978
joze is offline
post #2646 of 2651 Old 08-02-2012, 12:37 PM
LoPhat
I just found in this thread that the water pump was replaced on 11/27/2010. That rules out the likelihood of the water pump being the cause of the cooling issue.
Replaced the water pump yesterday because it was leaking pretty bad.
I'm now leaning toward the possibility that the thermostat is not opening all the way. Since a thermostat is inexpensive, I ordered a new one this morning.
EDIT: I replaced the thermostat early this evening. There was no improvement made by doing this.
LoPhat is offline
post #2647 of 2651 Old 08-02-2012, 12:54 PM
LoPhat
My guess is that the expression "hotter than hell" originated in the Arizona desert...
I don't think a Taurus fan would offer anything that the new two speed fan I installed isn't already doing. One thing I would like to do, however, is change the temperature sensors on the upper and lower radiator hoses. Jeep's factory fan settings are low speed at temperatures from 214 degrees to 219 degrees and high speed at temperatures of 220 degrees or higher. Other than a pursuit of cleaner emissions, why would they have chosen such high temperature settings?!
EDIT: I went to a junkyard today and looked at the Taurus fans. They seem to be identical to the 5.9 fan other than the plug. Interestingly enough, the replacement fan I just bought for the ZJ has the Taurus style plug on it, so I snagged a pigtail kit from one of the wrecked cars at the junkyard.
LoPhat is offline
post #2648 of 2651 Old 08-03-2012, 06:51 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
How old is the coolant itself?
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #2649 of 2651 Old 08-03-2012, 09:53 AM
WJHype
@LoPhat: That loud noise when you let off the gas is most likely your front pinion bearing. I had the same problem. Pull your front driveshaft and it should go away. If it goes away then you will know.
2001 4.7 WJ 2" BB 15x8 Cragar V5s 31x10.50 Duratracs
WJHype is offline
post #2650 of 2651 Old 08-08-2012, 03:58 PM
LoPhat
It should be about a year to a year and a half old.
I think a lot of the noise is coming from the front pinion bearing too, especially since I found the pinion nut was loose when I purchased the Jeep. I have had the front driveshaft out a few times, however, and the noise never went away.
LoPhat is offline
post #2651 of 2651 Old 08-08-2012, 10:39 PM
aircruiser
aircruiser's Avatar
Cant remember if this jeep has an SYE or not but check for play in the slip yoke if it does. As for the cooling issue, is it over-heating with the A/C on or off? Did you replace the thermostat with another 195 or did you do a 180 degree tstat?
aircruiser is offline
Bentley Project (WJ) Build Thread lvum4x4 Grand Cherokee General Discussion 312 08-18-2016 03:18 PM
Finally a build thread!!!!-cache-..project wannabe pre-runner!! -cAcHe- Grand Cherokee General Discussion 209 12-28-2014 05:30 PM
Project Iron Rock build thread tonymartin Grand Cherokee General Discussion 33 11-21-2011 09:52 PM
xJoshxx's Project About Damn Time. Build thread. xJoshxx Grand Cherokee General Discussion 55 05-26-2011 01:00 PM
My WJ Project Build Thread 22remud Grand Cherokee General Discussion 24 05-24-2011 07:30 AM
