Build Thread - Project Lowis
| View Poll Results: How much lift? | |||
| 4.5" |
14 | 26.42% |
| 5.5" |
39 | 73.58% |
| Voters: 53. You may not vote on this poll | |||
#1711 | |
Im 20 with a 2000 Grand SOLD! 4" Zone Offroad Kit, 16x7 Cragar Soft 8's, 265/75/16 Maxxis Bighorns, Rock-It Sliders, Rancho SS, Yakima Load Warrior, Flowmaster Super 40, Reverse Lights, 2 Lights Up Front, Custom 6 Switch Plate, Cobra 76 XTR CB with PA, Lightbar, Custom Hitch Tire Carrier, Fleabay Warm Air Intake |
#1712 |
Infowars.com
Lifting a front Dana 44 into a lifted jeep is no easy task when you do it alone.
Tomorrow morning I'm taking the axle to KOR so we can finish the disassembly and weld on the truss and lower control arm mounts. ![]()
What is it about Ron Paul?
#1713 |
Hahaha I couldn't resist. It was too perfect. And you are most welcome
1997 Jeep Cherokee, 4.0L, 30x9.50 Maxxis Bighorns, d-window wheels, cut fenders, chopped bumpers, flex-a-lite, flowmaster super 44 2003 Grand Cherokee Overland, 4.7L HO V8, 6000K HID's - SOLD IT 1996 Grand Cherokee Laredo, 5.2L V8, 3" Kolak exhaust w/ flowmaster 50 and magnaflow cat, K&N FIPK, 4300K HID's - SOLD IT My build thread http://www.myspace.com/HaleyChicoine http://www.facebook.com/home.php#/profile.php?id=1646857227&ref=profile |
#1714 | |
94 Grand Cherokee Laredo ZJ, lifted, 37s, yada yada yada
BigBlue build 33s, 6in lift and short arms http://www.jeepforum.com/forum/f197/bigbluezj94-build-thread-679496/ BigBlue build 3/4 ton axles, LAs, 37s http://www.jeepforum.com/forum/f197/3-4-ton-zj-build-818891/ 99 Grand Cherokee Laredo WJ, 4.7 liter, 247 Quadra Trac II, fully loaded |
#1715 |
Infowars.com
Update
Some progress pictures from today. I forgot the flippin axle socket so we couldn't take apart the hub.
First all the brackets were cut off with a plasma cutter then ground down. Didn't take any pictures of that but you can see where the backets use to be in the next picture. Next the cast was heated so the tubes could be welded. ![]() Tubes partially welded ![]() Truss mounted and welded. ![]() I also ordered some Warn locking hubs and wheel bearing kits today.
#1716 |
Nice, tool.
00' WJ 4'' IRO 285 Tire...Ect-SOLD 7/2/2009 98' ZJ STORM TROOPIN' SOLD 97' ZJ with 117K THE DD mi SOLD 01'WJ Project Cheap fix. |
#1717 |
Infowars.com
Forgot to mention that Bryant from KOR gave me these Ballistic Fab spring retainers because he's doing coilovers and doesn't need them.
![]() And somemore pictures of the axle. ![]() ![]() ![]()
#1718 |
nice!!!! good to see an update on this.
1993 Jeep ZJ. 4.0 |
#1719 |
good stuff. youll like those retainers, they work well.
BigBlue build 33s, 6in lift and short arms http://www.jeepforum.com/forum/showthread.php?t=679496 BigBlue build 3/4 ton axles, LAs, 37s http://www.jeepforum.com/forum/showthread.php?t=818891 99 Grand Cherokee Laredo WJ, 4.7 liter, 247 Quadra Trac II, fully loaded |
#1720 |
Infowars.com
Some stuff I picked up for a new project. Can anyone guess what the project is?
#1721 |
Bedlining the sides?
#1722 |
Duh, you're coating your truck's bed!
David. 2004 WJ Ltd. (steel blue pearlcoat) 4.7, QT-II, 3" lift on 32's BFG ATs, Aussie locked D44a. |
#1723 |
Infowars.com
#1724 |
Nice, I want to see how this turns out on a black grand cherokee. I'm considering doing this myself, but didn't know how good it would look black on black.
#1725 |
Infowars.com
I'm hoping it will turn out ok. I'm tired of looking at the claddingless sides and decided I'm going to grind down the nubs, fill in the holes, and bed line it. I got the idea from Bryant for KOR, he did this to his ZJ and it turned out great.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
