Build Thread - Project Lowis
| View Poll Results: How much lift? | |||
| 4.5" |
14 | 26.42% |
| 5.5" |
39 | 73.58% |
| Voters: 53. You may not vote on this poll | |||
#151 | |
this is exactly why i bought a WJ. and now all i want to do is lift and wheel it. no thanks to anyone on here of course. haha glad you got it back alright but i dont understand what exactly happened. maybe i missed something. what made the shock come loose and did the brake line just break? these dont seem like they need a shop to get fixed.
94 Grand Cherokee Laredo ZJ, lifted, 37s, yada yada yada
BigBlue build 33s, 6in lift and short arms http://www.jeepforum.com/forum/f197/bigbluezj94-build-thread-679496/ BigBlue build 3/4 ton axles, LAs, 37s http://www.jeepforum.com/forum/f197/3-4-ton-zj-build-818891/ 99 Grand Cherokee Laredo WJ, 4.7 liter, 247 Quadra Trac II, fully loaded |
#152 | |
Infowars.com
What is it about Ron Paul?
#153 |
you gave up to easy bro. you could have gotten the brake line and the bolt from autozone and had it fixed in an hour tops with bleeding the lines. then ordered the BPE and put them on later. that is if you are running stock lines.
actually, you could have gotten a ride to autozone got the parts and fixed it on the spot. saved you all the trouble and headache and you could have finished the day of wheelin
BigBlue build 33s, 6in lift and short arms http://www.jeepforum.com/forum/showthread.php?t=679496 BigBlue build 3/4 ton axles, LAs, 37s http://www.jeepforum.com/forum/showthread.php?t=818891 99 Grand Cherokee Laredo WJ, 4.7 liter, 247 Quadra Trac II, fully loaded |
#154 | |
Infowars.com
#155 |
na thats what i was saying, if you were running stock you could have done that. if it were me, there is no way i would ever pay for a trailer from Uhaul. i would make due with the stock line for 17 bucks at autozone. i really hope my shock doesnt come loose cos im still running stock lines. i just unbolted them from the unibody. im waiting on my IRO BPEs so i can put my MX6s up front.
#156 | |
Infowars.com
#157 |
to be honest, im not sure but i can go full articulation without putting stress on the line so thats good enough for me.
#158 |
Infowars.com
I might do that then too along with the extended brake lines so this doesn't happen again.
#159 |
well id say it was your shock bolt breaking and letting the susp droop too much is what snapped the line but there is definately no harm in unbolting the line.
#160 |
Infowars.com
Yep that's exactly what I think happened.
#161 |
i have my IRO lines unbolted and they can go down way more than i could flex..
o have a pic hold on |
#162 |
i was looking for a pic but ive got nothing. i unbolted the rear as well. there is no way that line is snapping.
#163 |
Infowars.com
If the brake lines had more slack they could have stayed connected and I could have drove home by myself.
#164 |
#165 |
Infowars.com
^^ Yep that's what I need to do, especially with the Claytons on the way.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
