Build Thread: Oscars 02 WJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Build Thread: Oscars 02 WJ
Year End Clearance Sale! Save 20%NEW!! HMF 50"-52" light bar mounting brackets!! Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 12-15-2014, 11:56 AM   #1
LeeIndy
picked her up today. ordered someparts to fix a few little things already.
2002 WJ limited Quadra Drive
00m0m_9PppI1sDTaB_600x450 by Oscar da Grouch, on Flickr
00K0K_hH8xKHqYbyL_600x450 by Oscar da Grouch, on Flickr
00a0a_90ZQlZhSL0L_600x450 by Oscar da Grouch, on Flickr
00202_d80ZiC24qpR_600x450 by Oscar da Grouch, on Flickr
4in long arm and JK rubicon takeoffs are already on order.
powersteering is whining a bit. I need to fix blend doors. rotors are warped. Still happy
I need a driver door retainer. they are expensive new anyone have a used source?
2012 JKR on 37s (built and beat on)
2002 Grand. new to the family. 4in longarm enroute
LeeIndy is offline   Reply With Quote Quick reply to this message
Unread 12-16-2014, 06:24 AM   #2
LeeIndy
blend doors enroute
Unread 12-17-2014, 06:33 AM   #3
LeeIndy
New blend door kit.
Hoping the parts I ordered before these aren't spread across i75 as we had a fedex truck turn over yesterday....
The Gleeping (Glamour Jeeping) Diary. Entry #2
Last week I bought a Grand Cherokee Limited. It had some typical issues one of which was a broken blend door for the heat. After a fairly simple fix the Gleep is up and hauling *** again. I love my JK but there is something nice about heated leather and a V8. Now to make it look like a Jeep. Thinking the 4in Long arm will help with that. And brakes. All of which should be here today.
Unread 12-18-2014, 06:26 AM   #4
LeeIndy
Door check fixed
Little helper
Lift kit
left turn signal is intermittently inop Im betting on the flasher relay failure that is common on these things. This jeep seems to be plauged by all the little common issues associated with the WJ.
Unread 12-23-2014, 06:14 AM   #5
LeeIndy
update 1
Small update I was in the process of installing the rear brackets for the lower longarms and decided to make a design change. This kit is designed as a bolt on and it probably would be. the two rear brackets they want you to drill 4 1.25in holes in the frame for the nutplate to slide into. This would have required removing the exhaust and moving some brake lines around to clear the hole saw........... Ill just weld it on. Much easier and doesnt involve more holes in the frame.
update 2
Minor setback today. Front is 90% assembled. Shocks brakes and arms are in. Old arm brackets are gone. Need to do the quick discos and track bar.... trackbar threads were Fed up so they are sending me another one. I also need new upper bushings as the oem ones are ripped.
