Build Thread: Ezflip - Page 5 - JeepForum.com
post #61 of 129 Old 07-10-2012, 05:57 PM Thread Starter
ezflip
ezflip's Avatar
2011 JK Wrangler
Originally Posted by TX-WJ
I'm assuming you already checked the vent / vent hose for patency
I didn't. But I have no reason to believe it would be clogged. I also don't think that would cause it to leak that badly, would it?
It sat for about two days on kind of a slant toward the drivers side and there was about a half quart of oil between what was in the wheel and what was on the ground.
The part that really scares me is that my varilocks weren't chattering at all. Idk if there was still enough fluid in it to be okay, or if they are shot at this point...
Sent from my Commodore 64 using JeepForum
~James
ezflip is online now
post #62 of 129 Old 07-12-2012, 08:10 PM Thread Starter
ezflip
ezflip's Avatar
2011 JK Wrangler
Got my Jeep back from the stealership. It turned out that the bearing I had put on there previously, the collar was not as thick as the Mopar bearing, so it had worked itself loose and was walking its way towards the diff in the axle tube. Im surprised there were no other symptoms or anything. But, all is well. He said I really didn't lose that much fluid, so he just topped it off, and my vari-locks are fine. Weird situation though....
~James
post #63 of 129 Old 08-26-2012, 11:32 AM Thread Starter
ezflip
ezflip's Avatar
2011 JK Wrangler
Okay, the time is almost here to start ordering parts for my build. Doing almost everything all at once and here is what is on list:
RC long arms
RC 1.5" wheel spacers
Tires (either 32" KM2 Rubi takeoffs, or 32" wardens from treadwright. Depends on if I can find a set of KM2's on CL for the right price)
New moog drag link adjuster sleeve with new moog TREs
Moog super trail boss steering stabilizer
TAG/KMA front winch bumper (purchasing from a member on here so all the fitment issues have already been worked out)
I should be ordering everything within the next two weeks. Only thing I plan on that Im not doing quite yet, is the winch.
~James
post #64 of 129 Old 08-31-2012, 03:24 PM Thread Starter
ezflip
ezflip's Avatar
2011 JK Wrangler
Well, just got the infamous random headlights turning on and off by themselves. So, ordered a new multifunction switch from rockauto. Seems to be the common fix for that, so hopefully it works. This will also give my 5% discount code for rockauto when I order my drag link, TREs, and steering stabilizer.
~James
post #65 of 129 Old 09-08-2012, 10:00 AM Thread Starter
ezflip
ezflip's Avatar
2011 JK Wrangler
Purchased a TAG front winch bumper from Bama_WJ which should be here sometime next week (Thanks Bama! ) Also sent a PM to casanova4x4 yesterday to order my Lift and wheel spacers. Just waiting to hear back from him to finalize that. And just waiting to get my discount code from rock auto to purchase the rest of the stuff from them. Hoping to do the install next weekend if everything gets here, if not, itll be the weekend after.
~James
post #66 of 129 Old 09-09-2012, 06:49 PM Thread Starter
ezflip
ezflip's Avatar
2011 JK Wrangler
New rubber! 255/75/17 BFG KMs. Only 4000 miles on them and got them for a steal on CL.
And the last pics Im going to get at stock ride height.
~James
post #67 of 129 Old 09-27-2012, 08:06 AM
Bama_WJ
You get the bumper mounted up yet?
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ, 2014 WK2
Bama_WJ is offline
post #68 of 129 Old 09-27-2012, 09:13 AM Thread Starter
ezflip
ezflip's Avatar
2011 JK Wrangler
No not yet. I just got my lift finished up and aligned, after 36 total hours of install time. But the bumper is just waiting on paint. Im getting it painted to match the body color.
Whenever I have time, Ill do a review on the RC long arm kit, for now I will just say it was a ***** to install, but rides very nice.
~James
post #69 of 129 Old 09-27-2012, 10:03 AM
adavis39
36 hours! holy crap. did it give you that many issues?
2002 WJ Limited 4.7: 6" Clayton REALLY long arms....yep, they are longer than yours SOLD : (
1998 Platinum 5.9 DD
2007 WK Overland 5.7 wifes DD
TNJEEPS.COM
BUILD:
"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"
adavis39 is offline
post #70 of 129 Old 09-27-2012, 01:42 PM
2000WJ4x4
I'll be waiting on a review and see how it flexes.
Please go into detail with LOTS of picsif you have them. i can't decide between the Rc long arms or the IRO 4" critical path.
2002 tj 4.0 d30-d44 2.5"RC prog. springs, JK shocks, 32x11.50 Cooper STT's
2000WJ4x4 is offline
post #71 of 129 Old 09-27-2012, 01:46 PM Thread Starter
ezflip
ezflip's Avatar
2011 JK Wrangler
The kit itself wasn't too bad other than the oddball sized drill bits needed. The entire first day (10 hours) was just removing old parts from the front with a few trips to the hardware store and one 2 hour trip to a machine shop. I broke the axle side track bar bolt trying to take it off and I had no way at all to get it out.
The second day was finishing up the front and starting the rear with several more trips to the hardware store to replace more bolts I broke. Then I also broke a couple of the flag nuts included with the kit.
The third day was finishing up the rear, doing the odds and ends of wheel spacers, bleeding brakes, checking fluids, replacing drag link, and clean up.
So, the actual install could have taken maybe 15-20 hours or less without all the broken parts and extra trips around town. Oh, and I forgot a part at my apt which was an hour away from the garage, so there went another 2+ hours.
~James
post #72 of 129 Old 09-27-2012, 02:04 PM
adavis39
was it the RC bolts that were breaking? that seems odd
TNJEEPS.COM
BUILD:
adavis39 is offline
post #73 of 129 Old 09-27-2012, 02:16 PM Thread Starter
ezflip
ezflip's Avatar
2011 JK Wrangler
No, they were all rusted stock bolts.
~James
post #74 of 129 Old 09-27-2012, 02:22 PM
2000WJ4x4
How does it ride compared to stock? And were you putting it on by yourself?
post #75 of 129 Old 09-27-2012, 02:22 PM
adavis39
gotcha....well u gotta get some pics up soon...i know that there are several people probably waiting on a few more reviews of this lift. hopefully it treats u well
TNJEEPS.COM
BUILD:
adavis39 is offline
WJ Build Thread tsconver Grand Cherokee General Discussion 251 08-30-2016 10:12 AM
Help on how to do a build thread coolio365 ZJ Grand Cherokee Forum 11 12-09-2011 05:14 PM
WK build thread WSPJeep Grand Cherokee General Discussion 95 11-01-2010 09:17 AM
RMFK13 Build Thread. RMFK13 Grand Cherokee General Discussion 89 01-20-2010 03:33 PM
? about starting a build thread zjzach Grand Cherokee General Discussion 5 04-17-2009 07:00 PM
