Brian's Black Betty Build - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Brian's Black Betty Build
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 03-31-2012, 07:51 PM   #76
gtg413i
gtg413i's Avatar
2003 WJ
Just installed coil spring retainers in the front- upper and lower from iro. These are required for hard wheeling disconnected with iro 3" lift and bilstein (probably others) shocks. I have to go back and weld the uppers in because the iro ones are not robust enough- no fault to them, just need to weld a bit. I also installed upper and lower front coil spring isolators. Finally got around to measuring fender to hub- 21" front, 20.75" rear. More pics to come- I'm jeep beat for now.
Brian's Black Betty Build: http://www.jeepforum.com/forum/f197/...build-1270544/
gtg413i is offline   Reply With Quote Quick reply to this message
Unread 04-10-2012, 12:11 AM   #77
gtg413i
gtg413i's Avatar
2003 WJ
Adding some more pics. First is of the wj washed, with painted overland sliders (end caps removed), bf Goodrich mud terrain km off rubicon 255/75-17 (32.1" new, but mine has 20-40% tread), and front bumper cover removed. Ready to wheel. 2nd pic is at tierra del sol desert safari wheelin.
Unread 04-10-2012, 09:01 AM   #78
gtg413i
gtg413i's Avatar
2003 WJ
First pic is disconnected, flexed and turning. You'll see I am rubbing metal, so just cut that piece off where the red line is in the 2nd pic. You also want to relocate the washer bottle and take the fender liner out. 3rd pic is trying to go over the small obstacle that broke my front drive shaft and ended wheeling for the day.
Unread 04-10-2012, 09:03 AM   #79
gtg413i
gtg413i's Avatar
2003 WJ
Back home from the trip- you can see where I had to cut the metal off to keep from rubbing.
Unread 04-16-2012, 04:08 PM   #80
=KZ=
What does that metal do. I am thinking of running 3.5" and JK takeoffs, is that possible at all with the stock front bumper with fogs?
Looking to buy 4" front BDS springs
=KZ= is offline   Reply With Quote Quick reply to this message
Unread 04-17-2012, 01:48 AM   #81
gtg413i
gtg413i's Avatar
2003 WJ
If you run disconnected, you'd need to extend the bump stop 3", relocate the washer bottle, trim that metal (all it did was hold the washer bottle on one side). I'd also suggest wheeling without the front bumper as you may take out the fog lights ( not sure though because i never wheeled with the jk takeoffs and bumper on). If you wheel hard, depending your shocks, you would need limiting straps or coil spring retainers. I got into some good spots wheeling where I was, but you could be fine if you don't get in those fully flexed, twisted positions.
Unread 04-17-2012, 03:24 AM   #82
=KZ=
I will be doing the coil spring retainers for sure, I already have the pipe to make them with. If I jack up from the front body the springs practically pop out connected! I don't know if I would go for the takeoffs if I can't run the front bumper, seems like a pain to have to remove it to wheel and don't want to go with an aftermarket bumper.
Unread 04-17-2012, 11:42 AM   #83
infernoredwj
Don't let the bumper removal deter you from the takeoffs...it's all of five bolts. Before my bumper build I had the removal down to 5 minutes, and then you're also guaranteed not to crack the plastic on a tall rock/stump or by kissing the ground in an off-camber situation.
http://www.jeepforum.com/forum/f197/large-marges-very-own-build-thread-1240982/
Finger Lakes 4x4; Enchanted Mountain Offroad; CNYJeep.org
infernoredwj is offline   Reply With Quote Quick reply to this message
Unread 04-17-2012, 01:18 PM   #84
=KZ=
I would have to relocate front license as well or re and re the bumper trailside. So I guess you have no real problems with the takeoffs connected as far as rubbing or hitting water bottle, fogs? Also in your opinion is there more of an advantage in going from 30.5" tires to 32" or in wheeling disconnecting if it becomes a choice?
Unread 04-18-2012, 11:30 PM   #85
gtg413i
gtg413i's Avatar
2003 WJ
X2 on the ease of removing the bumper. Then you drill one hole and zip tie the license plate. Two bolts to take the bumper off, two more for the front license plate. Not sure if you will hit the fogs or washer with 32's connected. If properly bump stopped, i really doubt you'll hit them. The 32" tires are a good size and from what I gather, about the max you can run with effective vari-lok axles. If it weren't for not having an easy place to put the spare, I would run 32" tires full time. After spending more time in the offroad community, which is very limited, I concede that the wj will only get you so far until something breaks or requires much more cash. To me, 32" and mild wheeling is about as far as I want to go / spend. As it sits, the rig iis still very capable off and on road.
Unread 04-19-2012, 12:00 AM   #86
=KZ=
I guess I am not too big on building a vehicle where I can't wheel at all without removing stuff. So if wheeling, swaybar connected would result in killing my fogs. I think I'd rather stay with 31's I don't mind removing the front bumper for bigger trips when I would disconnect. Kind of a good idea.
Unread 04-19-2012, 12:02 AM   #87
=KZ=
How loud are those bfg muds on the highway?
Unread 04-20-2012, 12:36 PM   #88
gtg413i
gtg413i's Avatar
2003 WJ
Way too loud for a daily driver commuter. I have to drive up to la a lot and would not want to do it on the mud terrains.
Unread 03-17-2013, 01:03 PM   #89
gtg413i
gtg413i's Avatar
2003 WJ
Figured for the cost of axles and lockers i could buy another jeep already built.
Unread 05-22-2013, 09:00 AM   #90
RIPNBST
Posting in here to mark this thread for reference when I do lift install and washer bottle install. Very well done. Thanks for the time you put into your write ups.
RIPNBST is offline   Reply With Quote Quick reply to this message
