Brian's Black Betty Build - Page 3 - JeepForum.com
post #31 of 109 Old 11-20-2011, 11:13 PM Thread Starter
gtg413i
2003 WJ
The lifted jeep. In my opinion, there wasn't much noticeable difference than with the upcountry suspension I already had, but I'm sure the difference will show on the trails.
gtg413i is offline
post #32 of 109 Old 11-20-2011, 11:15 PM Thread Starter
gtg413i
2003 WJ
Some pics after the new tires / wheels. The 2nd one below shows the painted rear bumper insert and the rear park sensors.
gtg413i is offline
post #33 of 109 Old 11-20-2011, 11:18 PM Thread Starter
gtg413i
2003 WJ
Front suspension- The orange box is the disconnect. The pink box is what stores the link when it is disconnected. I mounted this to the front skid plate. Note that someone said the rough country quick disconnect is too long for a 3" lift. In my opinion, that may be true, but all it did was make the front sway bar angle up more and I haven't had any problems.
Edit here: I found out that in order to add the thing in the pink box to hold the swaybar link connector when disconnected. Line up one at a time. Start with the driver side and make sure you are clear of any moving parts at full turn. Then, with the drivers side disconnected from the axle, put it on the holder. Then go to the passenger side to mark the holes for that side. If you line them up independently like I did the first time, they will not both reach the holder, just one at a time.
gtg413i is offline
post #34 of 109 Old 11-20-2011, 11:20 PM
eogg
Looks good.
Constantly emptying every pocket
Colorado Jeep Club Member #1010
eogg is offline
post #35 of 109 Old 11-20-2011, 11:22 PM Thread Starter
gtg413i
2003 WJ
More pics.
gtg413i is offline
post #36 of 109 Old 11-20-2011, 11:27 PM Thread Starter
gtg413i
2003 WJ
In summary, I need a daily driver and wanted a more capably offroad suspension, so I'm very happy and she drives better than stock in my opinion. I would have saved money to get a budget boost with my upcountry suspension and the jeep would have looked the same. However the IRO 3" kit will perform better offroad. I never experienced death wobble, but I did install the steering stabalizer. I've read a lot about clunking sounds, especially with the disconnects. I did hear rattling, and found that it was my fault for not tightening the rear top shock bolts. After that and alignment the jeep drives tighter / stiffer than before. Even though it is lifted a little more, it seems like it can corner faster. The rake of the lift looks fine to me and I shouldn't have to worry about rubbing with the bump stop extensions. I do need to take some lift measurements and flexed pics. Let me know if you have any questions...
gtg413i is offline
post #37 of 109 Old 11-21-2011, 05:46 AM
Geo-Nemesis
isn't the track bar mounted in a wrong position?
'02 Black Overland H.O. V8
Geo-Nemesis is offline
post #38 of 109 Old 11-21-2011, 09:19 AM Thread Starter
gtg413i
2003 WJ
Shouldn't be! I referenced this thread http://www.jeepforum.com/forum/f310/...bar-wj-976511/ for a pic and also followed the instructions that said the bent side goes on the passenger side and the thing kinda looks like a J. The instructions were not very concise, so this forum helped a lot.
gtg413i is offline
post #39 of 109 Old 11-21-2011, 09:30 AM
rockcrawlernut
WJ looks good I went with the IRO 4" lift and it's been great so far. The Moab's look great black too
Once you understand the way broadly you see it in all things.
2004 WJ Special Edition 4.0L Project "
4" IRO Lift | IRO HD Track Bar | Doetsch Tech 8000 | JKS Quicker Disconnects | JKS Bar Pin Eliminators | Cooper Discoverer ST Maxx 265/75/16
rockcrawlernut is offline
post #40 of 109 Old 11-21-2011, 09:51 PM Thread Starter
gtg413i
2003 WJ
Pic with the ski rack and short antennae. No idea why jeep stopped the black antennaes, but I think they did for my year, 2003.
gtg413i is offline
post #41 of 109 Old 12-10-2011, 03:52 PM Thread Starter
gtg413i
2003 WJ
Washed and Waxed Pic.
gtg413i is offline
post #42 of 109 Old 12-20-2011, 07:48 PM Thread Starter
gtg413i
2003 WJ
Did the folding seat, quick release pin mod today. If you look at the date I bought the materials, it only took about 3 months. It was worth the hour or so today to get those pins off the back floor board. The materials needed are 5/16" drill bit, 10mm socket and 4 lock pins 5/16" x 2-3/4" ($3 each). I'm sure there's been a write-up before, but I wanted to add a few more pictures.
gtg413i is offline
post #43 of 109 Old 12-20-2011, 07:50 PM Thread Starter
gtg413i
2003 WJ
The first step is to take a 10mm socket and unscrew the seat retaining bolts (4 per folding seat section).
gtg413i is offline
post #44 of 109 Old 12-20-2011, 07:53 PM Thread Starter
gtg413i
2003 WJ
Next, take both sections out the jeep. Then remove the existing pin. I tried 2 methods A. cut each of the pins with a grinder or dremmel like the pic below (if you have a good cutting wheel, you can cut all 4 pins in about 1 minute). Then knock the pins out.
gtg413i is offline
post #45 of 109 Old 12-20-2011, 07:56 PM Thread Starter
gtg413i
2003 WJ
B. The other method is to take the 5/16" drill bit and drill the pins out. The trick to doing this is a lot of pressure on the end of the pin that is hollow (vs. the other end that is a more solid head). Once you have the pins remove, ream out the holes a little larger than 5/16" (not too much or it will be loose, not to little or it will be tought to re-align the new pins).
gtg413i is offline
Black Coolant steelstr45 WJ Grand Cherokee Forum 16 04-02-2016 01:15 PM
Black Friday Deals?? jemrey81 Grand Cherokee General Discussion 9 11-26-2013 10:20 AM
All Black GRILL Siebz WJ Grand Cherokee Forum 7 07-27-2011 10:00 AM
Chrome og black rims ? Speedy WJ Grand Cherokee Forum 9 01-22-2011 09:30 AM
what's that black box in my 2000 wj? joshjones84 WJ Grand Cherokee Forum 8 04-14-2010 03:03 PM
