Brian's Black Betty Build - Page 2 - JeepForum.com
post #16 of 109 Old 11-20-2011, 10:42 PM Thread Starter
gtg413i
2003 WJ
My partner in crime was taking a break.
gtg413i is offline
post #17 of 109 Old 11-20-2011, 10:45 PM Thread Starter
gtg413i
2003 WJ
Pics of the front spring removed. To make this easier disconnect the control arm from the frame (the two red boxes on the left). You also need to disconnect the front sway bar end links. Then Jack up the body near the disconnected control arm and lower the jacks near the brakes and raise the jacks near the brakes of the opposite side you're working on. Note, I still had to use spring compressors (the orange box).
gtg413i is offline
post #18 of 109 Old 11-20-2011, 10:46 PM Thread Starter
gtg413i
2003 WJ
At 2:30 pm (3.5 hours into it with time off to get a haircut) New spring installed. I would say it was a pain getting the shocks removed, but even more of a pain getting the front springs in. The impact wrench really sped things up.
gtg413i is offline
post #19 of 109 Old 11-20-2011, 10:48 PM Thread Starter
gtg413i
2003 WJ
Another hydration break after the front passenger coil spring installed.
gtg413i is offline
post #20 of 109 Old 11-20-2011, 10:50 PM Thread Starter
gtg413i
2003 WJ
Quick Disconnect ready for install. I painted all the items with a VHT epoxy type spray paint, so everything matched the "black out" look.
gtg413i is offline
post #21 of 109 Old 11-20-2011, 10:52 PM Thread Starter
gtg413i
2003 WJ
Here is a picture of how I fit a square peg (bar pin in the green box) into a round whole (shock bushing). The instructions say use a vice clamp, but I didn't have one, so greased up the bushings with lithium grease and pounded it in with a hammer. It will fit, just keep at it.
gtg413i is offline
post #22 of 109 Old 11-20-2011, 10:55 PM Thread Starter
gtg413i
2003 WJ
Here is the bottom of the shock and bar pin installed (red box). This is a visual for people wondering what a bar pin eliminator (bpe) is. It takes that square peg and makes it a round one that slips into the shock, so no need to bang with a hammer. At first I started to wish I ordered these, but at the end, glad I saved the money and used the bar pins that came with the kit.
gtg413i is offline
post #23 of 109 Old 11-20-2011, 10:56 PM Thread Starter
gtg413i
2003 WJ
The directions don't tell you, so wanted to give a visual of how to install the front shock top mount. It looks like the part in the red box. I had to use a washer on the top of the engine bay.
gtg413i is offline
post #24 of 109 Old 11-20-2011, 10:59 PM Thread Starter
gtg413i
2003 WJ
This might be straight forward for most people, but yellow box is the front shock adapter, light blue box is the shock boot (note on montube shocks like the bilsteins, you can mount with the boot up or down), brown box is the coil spring, purple box is the front sway bar link and in this case a quick disconnect, the green circle is the bump stop extension.
gtg413i is offline
post #25 of 109 Old 11-20-2011, 11:01 PM Thread Starter
gtg413i
2003 WJ
At this point, at 14:48 the following day, the front shocks, bump stop extensions, coils, and quick disconnects are installed. Drop the vehicle and install the track bar and steering stablizer.
gtg413i is offline
post #26 of 109 Old 11-20-2011, 11:02 PM Thread Starter
gtg413i
2003 WJ
The steering stablizer on the ground in the green box, goes where the old one was removed in the top green box.
gtg413i is offline
post #27 of 109 Old 11-20-2011, 11:06 PM
g-off70
whats the craftsman thing for?
2000 WJ- midland cb w/PA, KOR leveling kit and shocks, 12 in infitity sub w/ 600 watt infinity amp, magnaflow highflow cat, dynomax cat back exhaust. much more to come
Geoff
WTB: Tow hooks- let me know if you have any
g-off70 is offline
post #28 of 109 Old 11-20-2011, 11:08 PM Thread Starter
gtg413i
2003 WJ
Rear shocks (between red lines), rear sway bar extended end links (green box), and rear bump stop extension (brown box) installed. The rear bump stop extensions use a self-tapping screw that seems like it wont work at first, but use a lot of pressure and it will tap.
gtg413i is offline
post #29 of 109 Old 11-20-2011, 11:11 PM Thread Starter
gtg413i
2003 WJ
The last bolt connecting the rear sway bar was naturally difficult. I had to push up on the gas tank with my feet to get it to line up.
gtg413i is offline
post #30 of 109 Old 11-20-2011, 11:12 PM Thread Starter
gtg413i
2003 WJ
At 11pm everything was installed and I just needed to torque everything.
gtg413i is offline
Black Coolant steelstr45 WJ Grand Cherokee Forum 16 04-02-2016 01:15 PM
Black Friday Deals?? jemrey81 Grand Cherokee General Discussion 9 11-26-2013 10:20 AM
All Black GRILL Siebz WJ Grand Cherokee Forum 7 07-27-2011 10:00 AM
Chrome og black rims ? Speedy WJ Grand Cherokee Forum 9 01-22-2011 09:30 AM
what's that black box in my 2000 wj? joshjones84 WJ Grand Cherokee Forum 8 04-14-2010 03:03 PM
