-   Grand Cherokee General Discussion (http://www.jeepforum.com/forum/f197/)
-   -   Bort62's Build Thread (http://www.jeepforum.com/forum/f197/bort62s-build-thread-742679/)
Bort62 03-31-2009 12:56 AM
Hello All. I'm fairly new here, and have been lurking for a few months. Recently got ahold of a '98 ZJ and this last weekend turned it from this :
http://lh6.ggpht.com/__OWBm0bEtWw/Sd...0/IMG_2219.jpg
Into This :
http://lh6.ggpht.com/__OWBm0bEtWw/Sd...0/IMG_2234.jpg
This forum helped a lot, and the operation went fairly smoothly. I used IRO's F>R setup strait out of the box. Only issue I had with it was the 1/2 bolts they provided for the front sway bar were the wrong size, and I had to use some 3/8" hardware I had on hand. No big deal.
This is just the beginning, and I hope to update this thread over the coming months with all of the other crap I'll be doing. I'm a fairly experienced welder/fabricator, so I've got big plans ;) I'm new to the Jeep/4x4 thing - but not the general car thing, so I'm excited to expand my envelope.
A few questions regarding what I've done so far:
Can someone help me figure out what speedo drive gear I need? Went from the stock 215/70/15's to 32s.
I still have to get an alignment - can anyone recommend specs for good street manners? Also, I called around today and the impression I got was that only the toe could be adjusted (and that makes some sense given the live axle and non adjustable control arms) - but I've got a noticeable amount of positive camber after the lift, maybe 1.5*-2*... any suggestions? I can't see how lifting a non IFS truck would mess w/ the camber, but I don't assume to know everything.
Recommended tire pressures? I'm running used BFG's w/ ~ 50% tread left.
I removed the rear sway bar when doing this... good idea or bad idea? I can easily throw it back on, and I've noticed a little bit of float in the rear when upsetting it cornering but nothing most people would even notice. I'd rather not have to screw w/ disconnects on the rear when on the trail.
Death Wobble! Get it pretty bad about 10% of the time around 45 mph. Hoping the alignment helps. I'll also be replacing the worn out stock SS as well as the sloppy drag link end I discovered while re-centering the wheel.
Thanks!
indredsnake99 03-31-2009 12:59 AM
no clicky....
http://lh6.ggpht.com/__OWBm0bEtWw/Sd...g/IMG_2219.jpg
Into This :
http://lh6.ggpht.com/__OWBm0bEtWw/Sd...o/IMG_2234.jpg
Thanks!
tizzdizz 03-31-2009 01:04 AM
try again for no click
Into This :
Thanks!
tfgnt16 03-31-2009 01:26 AM
I hope removal of that Obama/Biden sticker was part of the transformation ;)
rugermack 03-31-2009 09:02 AM
Looks good , nice stance.
blackjack12982 03-31-2009 09:16 AM
Looks really good. Looking at this is kinda making me rethink my 2.25" BB, and instead doing the F>R.
besthaticouldo 03-31-2009 10:53 AM
looks good...nice lift man!
Bort62 03-31-2009 11:12 AM
Can someone suggest a steering stabilizer? Inexpensive is good, cheap is not.
Thanks.
besthaticouldo 03-31-2009 11:46 AM
tenneco SS from IronRockOffroad.com
thats what i got, i have no problems with it at all. it does the job well.
DothanJeep 03-31-2009 11:51 AM
:hahaha::hahaha:
Falcor 04-06-2009 02:09 PM
My jeep looks exactly the same as this, except for it being stock :). How is the gas mileage and power with the 32's?
Bort62 04-21-2009 12:51 AM
Update:
Got a few minutes to work on the bumper the other day.
http://lh6.ggpht.com/__OWBm0bEtWw/Se...0/IMG_2646.jpg
theksmith 04-21-2009 01:18 AM
no clickity
Originally Posted by Bort62 (Post 7054683)
Update:
zjzach 08-31-2009 12:23 AM
bump for any progress on the bumper?
The time now is 04:56 PM.
